Question about David White 44 8834 1 22x Level Transit Package
My david white alp6-18 does not focus - David White 44 8834 1 22x Level Transit Package
How to fix crooked cross hairs on David White transit level
don't believe that is a consumer fix . has to be sent in to them
Apr 27, 2015 | David White 44 8834 1 22x Level Transit...
Where can I download or how can I get the manual for this total station?
David White has gone trough a lot of changes. A number of years ago it was bought by CST (Chicago Steel Tape). CST was bought by Stanley tools around 2007ish. Stanley sold CST to Bosch in 2010ish. Bosch has kept CST but shut down David White, as well as all parts.
If you call the old CST office in Chicago 815.432.9200 • 800.435.1859 they might be willing to share an old manual.
Feb 01, 2014 | David White DTS05 Electronic Total Station
Taking a close up of an item 6" long is not
According to the manual, the C310 has a fixed-focus lens with a working range of 0.85 m (about 33 inches) to infinity. So, anything only ten inches from the camera will be out of focus.
Nov 06, 2010 | Kodak EasyShare C310 Digital Camera
Nikon D90,,,brandnew..the LCD screen flickers when recording a movie and when playback pictures they first come up a little blurry and then when they come to sharp focus the picture shrinks slightly....do...
The D90 movie mode is not perfect.
Keep the camera steady when shooting movies to reduce flicker.
It sound like you are not in focus when you start recording the movie. Press the shutter button halfway to focus, then press ok to record.
If you do not want the camera to change focus in shot keep the shutter halfway down.
I hope this helps.
Mar 10, 2010 | Nikon D90 Digital Camera with 18-105mm...
How to change fuel filter and where is the fuel filter on ford focus lx 1999
It's located under the body of the 1999 Ford Focus.
Hope this tip helps.
r/
David
Feb 05, 2010 | 2000 Ford Focus
Ford focus spec
it has a vehicle anti theft system or vats system with out the factory programed key it will not start .
Mar 04, 2009 | 2006 Ford Focus
AF flashing green, red AF sign on screen - won't take pictures
When you depress the picture button you should both hear the camera making motor noises and see the image focus changing as it seeks the proper focus for the image. If no focus movement takes place and you hear nothing then the focus motor is either completely jammed or malfunctioning. Alternatively focus movement may take place but it never finds the right focus point. Or you may hear a buzzing or clicking sound when it should be focusing. These symptoms can be caused by impact or, more commonly, sand or other contaminants making their way into the delicate system which moves the focus element. The camera will require professional repair in either of these cases. David Millier Advance Camera Repair
Feb 22, 2007 | Nikon Coolpix 4600 Digital Camera
David White 44 8834 1 22x Level Transit Package Logo
54 people viewed this question
Top David Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a David Measuring Tool and Sensor Expert? Answer questions, earn points and help others
