I would like to disable my touchpad on my msi wind notebook so I can use the mouse. Right now when I use the mouse, the cursor jumps all over the place when I am typing.
  • 827 Answers
Go onto control panel and click on Mouse, then Device Settings and highlight the touchpad from the list and click Disable.
Chris (ziraffa)
Posted on Jan 05, 2009
On my CF-51 the touchpad is erratic and occasionally the screen cursor will jump. The OS is Windows XP. Everything else works perfectly.
I had similar issues with cursor jumping even while using a mouse.
Very simple & quick fix is to simply "disable" touch pad through "start up" mode use a mouse.
You have to disable in start up menu or pad will re-enable itself next time you boot.
I never liked a mouse before being forced to use it .... now it's not so bad.
Jun 22, 2011 | Panasonic Toughbook CF-51 Notebook
I have a Compaq Presario CQ62. When typing anywhere, the cursor randomly jumps to another spot in the text and continue inserting text there. How do I correct this?
This typically happens when the typist's palms touch the touchpad, which the pad treats as a mouse click. See if the cursor is jumping to where the pointer is.
Most touchpads have a control panel (usually part of the MOUSE Control Panel) where you can reduce the sensitivity (or disable) the left click function from tapping the touchpad.
Apr 20, 2011 | HEWLETT-PACKARD Compaq Presario CQ62210US...
My cursor jumps suddenly from one place to another, it's very annoying while typing emails, word documents, everywhere... pls help
The usual reason this happens in laptops is that as you're typing, you hit the touchpad with the heel of your hand and the cursor moves. I've done it myself. What I suggest is turning off the touchpad and using an external mouse if you do a lot of typing. This eliminates the accidental contact, and (to me, at least) a real mouse is more comfortable for frequent use. Most computers have a switch that turns the touchpad on or off, or you can disable it through the Windows Control Panel or touchpad utility program.
Mar 29, 2011 | MSI Wind U100 Netbook
Hey. I have an Acer One 532h which is driving me nuts as the cursor keeps on jumping while I'm typing. Sometimes my palms are just hovering above the touchpad and not even touching it with the cursor...
There's no real way to change the sensitivity of your mouse, aside from changing the speed. A possible solution would be to use a USB mouse and disable your touchpad. Hope this helps!
Mar 28, 2011 | Acer Aspire One PC Notebook
Cursor frequently jumping all over the screen when typing on my Sony VAIO VGN-FW340J/B 16.4 Notebook PC
I have had the same problem...The touchpad mouse is incredebly sensitive. What is likely happening, is your wrists are coming into contact with the pad and the sensor interprets it as a click and moving your cursor. My solution was to install a usb mouse (mine was wireless) and disable the touchpad.
Nov 18, 2010 | Sony VAIO(R) VGNFW530FB 164" Notebook ...
Jumping cursor
Open touchpad properties, touchpad settings section, enable Touchcheck, set the slider to minimum setting Click OK
TouchCheck disabled the touchpad while typing
Jul 10, 2010 | Dell Latitude E4300 Notebook
My cursor jumps back to the beginning when i'm trying to type. i'm constantly having to backspace and correct and reset my cursor. any suggestions?
Disable your touchpad if you consistently have this problem.
When you are typing something, and you suddenly touch the touchpad (tapping this touchpad moves the cursor) then your cursor will suddenly change position which then mess up your typing.
If you don'r have an external mouse connected, better be careful not to touch the touchpad. If you have an external mouse, better disable this touchpad.
Mar 03, 2010 | Compaq Presario 700 470024-192 Notebook
Cursor continually jumps all over when trying to type
Touch pad mouse.
This unit has a "seamless touchpad with four-way integrated scroll button".
Yours is probably faulty, causing the cursor to be random.
Try disabling it and connecting a USB mouse.
Apr 26, 2009 | Acer Aspire 5315 Notebook
Cursor(pointer) cannot be moved by using touchpad but possibe wit
This happens to me also. Check whether the touchpad is enabled (laptops do have an option of enabling / disabling the touchpad). Secondly, you can try reinstalling the touchpad driver. Uninstall and then re-install the driver. Re-boot the system. Try using the touchpad.
Hope this helps., if so, rate me.. thanks - billa
Dec 20, 2008 | Lenovo Thinkpad R61i Notebook PC
Jumping cursor when typing
Since you have a logitech mouse, lets just disable the touchpad. You should be able to disable the touchpad via one of these methods:
  1. Look on the top row of keys. You should have one that looks like a little mouse. If you do, hold down the "fn" key in the bottom, and press the key with the mouse on it. That *should* disable the touchpad.
  2. Go to the control panel, and find the keyboard and mouse settings. Digging through the menus, you should find a touchpad. You can disable it through there.
Sep 17, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
194 people viewed this question
David Payne
David Payne
