Question about Dell E176FP 17" LCD Monitor
Messed up color settings
First of all: (make sure the 'Caps Lock' on your keyboard isn't on, writing in all Caps is impolite) <- lol Hello, I have following problem...i am sure you have already had this problem for quite a few times, but I couldn't find any solution in the short run. I have one of these Dell E176FP Color Monitors and I accidentally changed the color values. I didn't know how this could happen because I only pressed the + button (like 1000 times) which should actually cause the monitor to go back to the normal settings. I wanted to make it a bit brighter but I messed it up completely. I also tried to use different settings but it didn't really help. Now there is too much green but every time I try to change it to something different the colors don't really fit. I tried to adjust the settings with Adobe Gamma but it didn't really help. I also tried a program called "QuickGamma" which didn't help either. Now I would really appreciate it if anyone could either tell me the color values I need to put or could give me any other useful information. I also might have changed the color profile (I don't really know the name in English) which should be Adobe RGB1998? Or doesn't this affect the colors? Thanks in advance, Phill PS: Sry for bad grammar...>.>
  • Anonymous Mar 24, 2008
    every thing looks very red
Try the auto adjust button, usually by holding the + button for a sec
Posted on Oct 22, 2007
My caps wont turn off
Try this. Press: Start>Accessories>Accessibility>On Screen keyboard. Try turning it off from there. If that doesn't work:
1. Choose Start'Settings'Control Panel and double-click Regional and Language Options.
2. In the Languages tab, click the Details button.
3. In the Settings tab, you should see a button called Key Settings. It may be grayed out. If it is, click the Add button and add another keyboard layout (it doesn't matter which one). Press OK.
4. Back in the Settings tab, click to make sure your original keyboard is highlighted and press the Key Settings button.
5. Now under To turn off Caps Lock, click the radio button next to Press the Shift key. Click OK.
6. Click OK twice more to exit the other two dialog boxes.
Jan 13, 2011 | HP Computers & Internet
I can not get lower case
Check for a light on the keyboard, caps lock could be on.
The caps lock key might be sticking press down on it a few times might loosen it a bit.
Jan 22, 2010 | Acer NSK8458AN Keyboard
I recenty purchased a Logitech keyboard and find it diffult to describe my disappointment. Since I had a stroke I only have the use of my left hand and have to watch the the keyboard rather than the...
Unfortunately, by design this model indicates the status of "caps lock" and "num lock" on the computer screen. I do not see a work-around for your problem. A huge majority of keyboards have a "caps lock" indicator on board. Perhaps you need one of these?
Nov 26, 2009 | Logitech Cordless Desktop EX110...
Stuck caps lock condition -- even if caps lock LED is off
disasemble the key board and clean it very well unplugged from pc of course..keyboards can go quick with a slight drop to the floor and will mess up buttons..walmart has them for 15 or 20 bucks..if all else fails.
Jun 09, 2009 | Apple Computers & Internet
CAPs lock key is on al the time
When you start your PC, Num Lock, Scroll Lock, and Caps Lock don’t automatically toggle on. You can automatically turn each of them on or off whenever your PC starts, for all accounts on the PC. As a practical matter, most people probably want to have only Num Lock automatically turned on, but this Registry hack gives you the power to force any combination of keys on or off.
Start>Run then type in "regedit" whithout quotes.
HKEY_USERS.DefaultControl PanelKeyboard.
3eaaaca.jpg Find the String value
InitialKeyboardIndicators. By default, it is set to 0, which means that Num Lock, Scroll Lock, and Caps Lock are all turned off. Set it to any of the following values, depending on the combination of keys you want turned on or off:
0 Turns off Num Lock, Caps Lock, and Scroll Lock
1 Turns on Caps Lock
2 Turns on Num Lock
3 Turns on Caps Lock and Num Lock
4 Turns on Scroll Lock
5 Turns on Caps Lock and Scroll Lock
6 Turns on Num Lock and Scroll Lock
7 Turns on Caps Lock, Num Lock, and Scroll Lock
Exit the Registry. When you restart, the new setting will take effect.
Note: You have problem with Caps Lock so just modify Caps lock option on Regedit.
And do not forget to run virus scan on your computer once you are done.
Rate always the all answers.
Thank you
Jan 02, 2009 | EzKey EZ8000 Smart Office Keyboard PS2
Problems with laptop keyboard
Sounds like some of the keyboard settings have gotten changed. Begin by checking the System Parameters for Keyboard/Mice and verify that these are as follows:
Caps Lock = Caps Lock
Control Key = Control Key
Option Key = Option Key
Command = Command
If they are not, just press the RESTORE DEFAULTS setting and LOCK your Systems Parameter Page before closing it. Reboot your system and check keyboard operation.
Hope this helps,
Keith
Nov 14, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Laptop keyboard is not working correctly
Accoring to the problem you have mentioned i am sure the keys are not connected properly. The tab key is connected on the Caps lock key. Moreover make sure you press the fn key to check for any changes as it is the key which helps you toggle in Laptop
Oct 08, 2008 | Dell INSPIRON 6000 CENTRINO...
I have a Medion keyboard with my purchase of Medion PC model MT7. There is no light to indicate that Caps Lock is on - this creates difficulty when writing passwords with caps lock as the result is...
If this is a wireless keyboard there should be some kind of software that comes with it. The software should alert you when you push like scroll lock, caps lock, or num lock.
Or you can use this nifty little program that costs about $25. It stays in the icon tray and will notify you when you push any of those buttons. Here is a link to that website http://www.programurl.com/clever-keyboard-indicator.htm
I hope I have helped you.
Please rate my answer.
Aug 17, 2008 | Medion Computers & Internet
No ring tones
Writing Tips: Choose the category your answer is valid for in the select box on the left. Please make sure that the 'Caps Lock' key isn't on, writing in all Caps is regarded as 'shouting' and is impolite. Please don't use shorthand writing, don't write '4 u' write 'for you'.
Jan 31, 2007 | Sony Ericsson P800
Dell E176FP 17" LCD Monitor Logo
195 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
