Question about Behringer XENYX 2442FX Mixer
How to work fader in x32 behringer - Behringer XENYX 2442FX Mixer
3 Suggested Answers
  • 5603 Answers
SOURCE: Can the faders on the behringer sl2442 be cleaned
I will give you something to try and beyond that, you have to replace the fader.
Try spraying a LITTLE CRC 226 into the fader slot. Procure this at a Home Depot store in a small blue spray can in the electrical department. (about $2.60) DO NOT USE CONTACT CLEANER such as De-Oxit.
Spray a bit in and see if it improves the situation.
IF NOT what has happened is the sliding fingers have worn through and folded back and dug into the resistance element in the fader. That is fatal!
The faders, once you find the right type are not very expensive say less than $5 BUT there are usually massive number of screws to take out and knobs to remove to get the board out. SOMETIMES the ones you get have to have the "handle" shortened by a quarter inch. Do this with tin snips and clean off burrs with a file.
You need to match the resistance, the hole pattern, AND the "taper" which for those will be an "audio taper" The fader will have a part number on the side and MOST are made by "ALPS". Digikey and Mouser are my usual sources online.
Un-soldering the old fader takes care and solder removal tools. DO NOT force the leads out till the solder is all out and the lead is free. You will lift the circuit traces off the board.
Clean the residue of soldering flux when done and re-assemble.
Posted on Oct 27, 2009
  • 5603 Answers
SOURCE: I have a behringer xenyx 2442 and the main output
The utput fader has probably been broken. If the knob takes a hit, it breaks the resistance element. The part is inexpensive but it takes a lot of work to access and replace the part.
Posted on Jul 17, 2010
No Sound From Main 1 BMP6000
It's always possible, but I doubt it's the fader. I'd suggest taking it to the shop for a hands on diagnosis.
Nov 18, 2016 | Behringer Music
Powering on and off
Like as not, Behringer is a disposable brand once the warranty (which does not cover wearing parts like pots and faders which wear out quickly and are not worth replacing due to the design in most cases)
We normally sell behringer kit if it still works just before warranty expires.
Feb 13, 2014 | Behringer Eurolive B205D Active 150-Watt...
I can't get my Behringer XENYX X1222 USB to control any of the faders within Sonar X1 Producer.
It may require the driver to be installed for the Behringer, or re-installed.
Go into the settings section of Sonar and if you can "De-select" M-audio as the default controler, or you may need to go through the preferences of M-Audio to find it.
To me it sounds like a driver is missing.
Jan 30, 2012 | Music
Hi - I have had no problems programming or using the unit - its ok in its own way - the behringer LC 2412 ontroller. The problem comes in the form of what on old desks I would have called "pre...
The LED cans are not easily dimmable to very low levels. The signals sent are all digital. It is POSSIBLE that the A channel fader doesn't go low enough electrically within the console and the conversion to the control stream of data is NOT commanding a low enough level. LED's are HARD to dim below a certain point and what would happen is that in the multiple strings of each color, some stings would go completely out before others... SO it is possible they have a minimum SET in the PAR can that is the lowest level that can be done without dropping off some of the internal groups and making a mess of the color. There would be NO solution available to you in this case.
Jul 05, 2011 | Behringer Eurolight Lc2412 24channel...
I have a Behringer PMP 6000 that I just bought. With the power amp switch in Main L/Main R it works fine, but if I switch it to Main/Mon, only the Mon works, nothing from the Main. Bridge mode doesn't...
Bridge mode you use chan B (left connector on the back) using a SPECIALLY wired Speakon. The impedance of a speaker connected as such CANNOT be LESS than 8 ohms.
In the Main/Mon mode, the two amplifiers are separated in function. The monitor knobs for EACH channel input control the mix sent to Channel A which is for the monitor speakers. The Mon1 controls the level sent to Output A for the monitor speakers. Mon2 fader is NOT used.
The individual channel faders control the main mix and the Main fader controls the level sent to Output B which goes to the main speakers.
Apr 02, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
HI, My behringer 32 channel eurodesk mixer's some of the channels not working. No sound for the mike input. Please help. I am in phoenix, where can i take this?
Has somebody spilled liquid into the unit? Are you using XLR to XLR mic cables? If using condenser mics you need Phantom power on else NOT.
If the faders are noisy, use CRC226 in them. You can get that at Home Depot in the electrical dept.
NEVER use contact cleaner such as Deox.it or BlueShower in faders... it wrecks them
Feb 28, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
How to use a mixer board
Input at each channel XLR or 1/4 ", at faders(bottom) are assignment buttons for sub groups or to stereo out put and main faders drive audio to amps.
Feb 27, 2011 | Behringer Sx2442fx Eurodesk 24channel...
I have a behringer xenyx 2442 and the main output fader no longer works. Each individual channel fader now seems to go direct to the main mix and appears to bypass the main fader
Oct 14, 2009 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Behringer XENYX 2442FX Mixer Logo
66 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
