Question about Nikon Coolpix L310
Coolpic L310 flash problem
When i pres the button for the flash lid thing to open, the manual says flashs hould automatically work, this does not work for me, the camera is brand new today.
4 Suggested Answers
Steve5
  • 423 Answers
SOURCE: flash not automatically opening up.
Check the flash setting in the shooting mode (on Auto). Press the "?" button twice. You should see the flash mode window. Small box on the lower left for flash settings (hi-lighted in yellow, or navigate to it). Press OK to see and change flash settings to your preference.
Posted on Apr 21, 2008
ARTGIRTNY575
  • 96 Answers
SOURCE: NIkon Coolpix 2100 Digital Camera
Change the setting off from automatic. Choose Flash for all your pictures.
Artgirlny
Posted on Jul 08, 2008
  • 148 Answers
SOURCE: Nikon D40X built in flash doesn't pop up automatically
This is a common fault with the D40x. You will need to contact Nikon for repair details.
Posted on Apr 02, 2009
Nikon D5100 Built in flash won't pop up
Not even when you press the button on the left side of the class? the one with the flash symbol.
Switch on the camera and then press the button.
Look in the manual how you can setup the flash in all other than the automatic mode.
Nov 27, 2013 | Nikon D5100 Digital Camera
Our 7 year old Kodak digital camera works as good as new. But the flash door will not open. We have a new battery and that has not helped. Can we open the door with out damage to the camera?
Hello Martha, Sounds like the spring mechanism that operates the flash lid has a spring problem, you can manually open the flash but it will not stay in the raised position without the spring unit working,it has nothing to do with the battery,it is an internal mechanical problem.
Best Regards, Russell
Nov 03, 2012 | Kodak EasyShare DX7590 Digital Camera
My auto built in flash won't open on my canon 30D
The built in flash will (or should) pop up automatically if you are in the basic zones and the camera detects a slow shutter speed. If you are on a creative zone you need to manually push the button on the front of the camera it's a little button with a lightning bolt beside it. The flash will pop up take a few seconds to charge and you are on your way to flash photography. Two other things the internal flash will not pop up if you have another flash or accessory mounted in the camera hot shoe. When the flash is ready you should see in the viewfinder a green lightning bolt that telly you the flash is charged and ready for use.
Dec 21, 2010 | Canon EOS 30D Body Only Digital Camera
Set of 4 alternating orange and green flashes. No carriage movement when opening lid. All started with waste ink tank issue and then trying multiple 'fixes' from online
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
Mar 26, 2010 | Canon BJC S600 InkJet Printer
Paper jam light continues to flash when there is no jam
Sometimes opening and closing the top or ink cartridge lid will reset the printer or unplugging the unit might do the same thing. If those don't work, you may want to try using the advance button to manually feed paper thru the unit. I hope this helps.
Feb 24, 2010 | Lexmark E250d Laser Printer
Flash won't open on Canon Rebel XSi? It has been working fine but yesterday I went to take a picture and the flash wouldn't open. It won't open on any setting and it won't open if I push the manual flash...
The openning flash button only works on non automatic shooting modes.
On creative zone (automatic options with predefined options) the flash will rise automatically, based on the current exposure conditions. On "Flash Off" mode won't rise the flash ever.
Let me know, please if it solve the problem
Jul 10, 2009 | Canon EOS Rebel XSi Digital Camera
Flash not automatically opening up.
Apr 18, 2008 | Nikon D40x Digital Camera
Automatic flash problems
I have the same problem as Irichard, in that the flash won't pop up automatically, the camera wont work when you pop it up manually all all modes that allow flash photography do not work.
Nov 01, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Flash button won't select mode.
you cannot set anything on auto mode! The camera sets itself automatically. try taking shot(AutoMode)in dimlit area or no light at all. If it's taking shots and flash isn't firing, your flash bulb is already busted! I suggest you buy a separate flash unit (they cost the same as replacing parts and service fee), a cheap one is comparable or works the same as the costly one, if you know how to set up on manual mode ( they call it compose or advance or creative mode!)
Sep 03, 2007 | Fuji FinePix S5000 Digital Camera
Flash Problem
Using the flash When shooting with the built-in flash, open the flash manually. The flash does not pop-up automatically. The flash will not fire if it is closed. The flash will work when it is opened up. When the flash is open, the (flash on) icon or (automatic) icon will appear on the LCD monitor (or in the viewfinder). Flash on: The flash fires in every shot. Automatic: The flash fires automatically. Press the (flash) button to switch between the and flash modes while the flash is open. In some shooting modes, the flash mode does not switch even if the flash button is pressed. Please refer to Functions Available in Each Shooting Mode in the Camera User Guide provided with your camera for more information. When you are not using the flash, close it manually. When the flash is closed, the flash will not fire and the icon appears on the LCD monitor (or in the viewfinder).
Aug 31, 2005 | Canon PowerShot S2 IS Digital Camera
Nikon Coolpix L310 Logo
276 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
