Question about Casio TE-4500F Electronic Management Cash Register
Hi, I have a 2nd hand casio te4500f till. I have two problems that I can't seem to solve. I've purchased the dealers manuel but not sure if a total re-program is necessary (and not sure that I
  • lemoynecass
    lemoynecass Nov 07, 2012
    Sorry, the rest of the message got left out.....Hi, I have a 2nd hand casio te4500f till. I have two problems that I can't seem to solve. I've purchased the dealers manuel but not sure if a total re-program is necessary (and not sure that I'd be able to do it)Problem 1. I have been unable to change the clerk names...( program mode, 2, subtotal, code, subtotal, enter new name, press cash button then subtotal...this is where it won't work! cash button refuses to work and loud beep sound is made. The cash/tend button does work though in reg mode for transations. Problem 2. I can not print x or z reports as a password is needed which I obviously don't have
Scott Ellin
  • 558 Answers
SOURCE: casio tk-7000 scanning and PLU programming
You can add a Hand held Scannerbar with your Casio Tk -7000
Hand held bar code scanner(HHS-15) *
Essential functions for the scanning environment such as Not Found PLU(NFP),PLU batch maintenance file,bottle link and Mix & Match functions are available on the TK-7000 model.
You can attach a Voyager Scanner with your TK-7000 model.
How to add in Casio Cash Register:
1. connection to cash register - unscrew and screw back in.
2. connection to scanner, unplug using paper clip into hole and push back in again.
3. rescan default sheet given whe nyou purchased the machine.
4. clean head of scanner.
5. check for cracks on scanner, ie. loss of vacuum.
For MOre Information visit the following sites:
1. Multisoft India
2. Cash Register
3. Bar Code Basic
4. Scanner Model
5. Casio 7000
Regards
Ellin
Posted on Oct 07, 2008
flexion1
  • 737 Answers
SOURCE: Casio TE4500F Programming Departments & linking to PLU's
Hi.
To link a PLU to a dept:
Turn key to program mode.
3 SUBTOTAL
1166 SUBTOTAL
Now type the PLU number and press the 'PLU' button (eg 1 PLU for the first plu)
Now type the dept number to link to. Use two digits eg 01
Now press 00 (double zero)
CASH
SUBTOTAL
To set a dept name:
Turn key to program.
2 SUBTOTAL
Type dept no in 2 digits eg 01
Type 05
SUBTOTAL
Type new dept name using character sheet
00 (double zero)
CASH
SUBTOTAL
That should do it.
Let me know if you have problems.
Mark
Posted on Dec 18, 2008
SOURCE: programming of the casio pcr-t275
Hi program the taxes like the book says but fix the gst rate, then go to program mode and push 1 subtotal, then push t/s1(taxtable 1 which is gst) and the dept number you want to use, then subtotal and cash and that will be the dept you will use for just gst. Hope I'm making sense. Took me forever to figure this out.
Posted on Mar 17, 2009
SOURCE: I have a casio te4500f, problem changing prices
I know its been about 2 weeks in coming, but this is really easy to do. Generally casio does all its pricing from P1(program1 to get there turn the key to PGM). The machine will recognize the position of the key and automatically go to P1. Once there you can enter a price without decimals and press the button that you want that price on. That is providing the PLU's are set up. The PLU's are the items that you sell like hamburger, milk, coke etc. When done press subtotal and turn your key back to REG and keep on pluggin!!!!!
Chris
Posted on Jul 07, 2009
SOURCE: problem programming PLU s on casio SE-S2000
i got an error in my casio ses 2000. the error no is E008. i can't sign on
Posted on May 28, 2011
Casio tk-7000 scanning and PLU programming
1. Multisoft India
2. Cash Register
3. Bar Code Basic
4. Scanner Model
5. Casio 7000
Regards
Ellin
Oct 07, 2008 | Casio Parts Cash Register PC Desktop
In the pass 4 years when I purchased my truck I have problems with the ac unit. I have had this gased up every year since I have had the truck from the company I purchased the truck from and this year here...
Problem is that the "new" R134 is somewhat "thinner" than the older, more reliable R12. Therefore, every seal in the entire system needs to be absolutely perfect, otherwise, it leaks out. I've even seen hoses that will bleed freon though they appear normal in every respect. Don't be tempted to add "do it yourself" freon that has sealant in it. I've never seen any of that work and further, I know it will gum up the expensive equipment repair shops use.
The problem is not isolated to GM vehicles. Therefore, switching to another make won't cure the problem. Only difference is that some, regardless of make seem to bleed off less than others. Why?
I've got no idea. Likely the dealer has gone over your system several times already and found nothing.
Reason being that it bleeds off so slowly that most leak detection equipment won't pick it up.
The most common leak area is from the front seal on the compressor. Replacing the seal or compressor is expensive and there's no guarantee that it will actually fix the problem. So, 'till someone comes up with a better refrigerant, or a way to make the system less prone to leaks, we're all pretty much stuck with it.
May 12, 2011 | 1999 Chevrolet Tahoe
Casio TE4500F Cash register - password ???
Hi. It has probably lost all of the system and user memory. If you have the dealer manual then I can help you to get it running again and work out any passwords.
If you need the manual, there is one here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-3000S_and_TE-4000F_and_TE-4500F_dealers_manual.html
Apr 10, 2010 | Casio Parts Cash Register PC Desktop
Chris
Jun 25, 2009 | Casio Parts Cash Register PC Desktop
Weekly sales reports on Casio TE4500f
Hi.
It depends upon the way it was setup by your dealer.
If you turn the key to Z mode, then press CASH, it should print a daily report. If it has been setup for periodic reports, then you turn to Z2, press 1 then CASH and it should give a weekly report.
Mark
Feb 04, 2009 | Casio Parts Cash Register PC Desktop
Hi.
3 SUBTOTAL
1166 SUBTOTAL
CASH
SUBTOTAL
To set a dept name:
2 SUBTOTAL
Type 05
SUBTOTAL
00 (double zero)
CASH
SUBTOTAL
That should do it.
Mark
Dec 18, 2008 | Casio Parts Cash Register PC Desktop
Casio TE-4500F Electronic Management Cash Register Logo
52 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
