Question about Mitsubishi WD-62528 62" LCD HDTV
TV getting no signal, it is on channel 3. - Mitsubishi WD-62528 62" LCD HDTV
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Base on model number: make sure none of the inputs work---will narrow things a bit.
This model should have two resets(not the one on front of set) , a soft and a hard---the soft is done with the original remote:
Set turned on: Menu, 1,2,3 and enter.
Posted on Nov 08, 2012
How do i get the TV to play satellite? it just says weak signal when I turn the tv on. JVC RM-C18G
It has to be on the right channel. If you are supposed to be on channel 3, 61, 73, 113 (ask the satellite company which one you should be on) then you'll have to change the channel. If you are not supposed to be on a channel you have to find out which input you're supposed to be on (video 1, video 2, video 3, av 1, av 2, av 3, hdmi 1, hdmi 2, input 1, input 2, input 3 for example).
Jul 19, 2011 | Televison & Video
What channel does my tv have to be on to get a picture? right now it says no signal I accidentally changed the channel on the tv and now I can't find a signal
The most likely channels to get a signal is channel 3 or 4. This is typical output channel for VCR's, cable, etc.
Oct 22, 2009 | Televison & Video
New tv. won't work
Press the input button and select where you have the satellite plugged in.
Aug 12, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
How do I get it to channel 3 to use my converter box
turn on the converter box and then scan for channels on the tv. Channel 3 should be picked up by the tv as having a signal.
Mar 09, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
Get channel 3 on tv with autoprogramming
When you select channels, the one that comes in the channel number will be green and if you manually select 03 it will probably be red. Hit menu and add channel 03
Jan 16, 2009 | GE 32GT740 32" TV
Converter box
You'll need to keep your TV on channel 3 or 4 depending on what channel you set the converter box. All your channel changing will be done through the converter using its remote control after that. If you change channels on the TV itself and go off channel 3 or 4, the TV will not get a signal and will show you that "no signal" message.
Nov 24, 2008 | Sanyo AVM-3259S TV
HDTV converter box only brings in 3 channels
We have a pretty good signal when we use the antenna but when we hook up the converter box we get no channel weak signal no channels we have a amplipher on it it does not help .
Nov 22, 2008 | Insignia Digital-to-Analog Converter for...
My daughter brought her tv home from college without the remote. I'm now trying to hook it up to digital cable. It needs to be on channel 3. When I try to manually change the channel to 3 using the...
The easiest will be to make sure that the cable box is on and sending out a signal to Channel 3 and auto-programming the set. Channel 3 is skipped because the last time it was auto-programmed, there was no signal on that channel.
Dan
Jul 10, 2008 | Televison & Video
Mitsubishi WD-62528 62" LCD HDTV Logo
16 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
