Question about HP LaserJet P4014n Printer
When we run envelopes through the envelope feeder we get smudges - what can we do
jaylex
  • 417 Answers
SOURCE: ink smudges off envelope
You will need to select in the drive that the media type you are putting in is envelopes this will adjust the printer fusing section to increase the heat.
Also you must select to go through tray one when doing this open the back door and the printed envelope will come out of the back and should be fine. If not try a lesser grade of envelope if still the same problem then the fuser unit is slipping and will need to be replaced.
Hope this helps you
Thanks J
Posted on Jan 06, 2008
SOURCE: envelopes smudge
I have been informed that these fusers have a seperate heating element in the middle of the heat roller for envelopes to save energy and it's temperature is not sensed by the thermistor.If I trick the printer (with paper path tests) into printing envvelopes while thinking that it is letter the fusing is ok.
Posted on Apr 24, 2008
SOURCE: HP laserjet 4250 evelope smudge
This is a common problem with 4250/4350 fusers.They have a seperate heating element for envelopes in the middle of the heat roller that is not controled by the thermistor.If I trick the printer (with paper path tests) into printing on an envelope while thinking it is letter the problem dissapears.I think HP will have to fix this, perhaps with driver or firmware upgrades.
wheatlandsvc
  • 1110 Answers
SOURCE: How do I install the envelope feeder tray on the
As long as you have the correct envelope feeder then it just locks into place on the front of the printer. Simply open the tray 1 feed door (the one with the model number 4050 on it) and your envelope feeder just "locks" in just above the open tray. If you look at the printer you will see a small square connector block. Now look at the envelope feeder and you will see where the 2 meet together. Then match up the 2 and "lock" it in place.
Posted on Dec 08, 2009
Ranglo
  • 1194 Answers
SOURCE: envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools , click Letters and Mailings and then click Envelopes and Labels .
2) Type the Delivery and Return address information.
3) Click Options .
4) On the Envelope Options tab, set the following options:-
  • Envelope size : set to match the loaded envelopes.
  • US only : if desired, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
  • Return address : for Size 10 envelopes only, set the Return Address position .8 inch in the From left section.
5) Select the Printing Options tab and verify that the following settings are selected:
  • Select the Feed Method option that shows the envelope on the far right side with the short edge first.
  • Select Face down .
  • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is on the right, select or deselect Clockwise rotation.
6) Click OK and then click Print .
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
  • Print envelopes at a higher quality setting so envelope is pulled through the unit more slowly. e.g:- Switch fast to slow mode or slow to best mode.
  • Tuck the flap inside the envelope before loading it into the printer.
Have a nice day...don't forget to rate the solution.
Posted on Feb 20, 2010
HP Laserjet 4200 with optional Envelope Feeder will not automatically pull #10 envelopes from Envelope Feeder?
Use a damp lint free cloth and clean the feeder rollers.
Print out a configuration page to make sure that the printer recognizes that the feeder is installed.
Usually the envelope feeder problems stem from age and/or dirty rollers.
Make sure that your software app sees that the feeder is attached.
Feb 08, 2011 | HP LaserJet 4200 Printer
4250 HP. Loses settings. Correct to show envelope
In the paper-handling menu set the envelope feeder size to the size of your envelope and the envelope feeder type to *any type.
Then ensure you are printing envelopes from your application.
Nov 25, 2009 | HP LaserJet 4350 Printer
Not sure how to feed the envlope into the printer
Follow these steps to use the photo/envelope feeder for single envelopes:
1. Insert the envelope into the photo/envelope feeder with the side to be printed on
facing down and the flap to the left.
Push the envelope into the printer as far as it will go without bending.
3. Slide the photo/envelope feeder forward as far as it will go.
Thank you for using Fixya
Oct 08, 2009 | HP DeskJet 6988 Printer
Envelope Feeder for Dell 5210N wrinkles envelopes
Hey,
This may be a bit late, but I just posted a solution to the Dell 5210 envelope problem here
http://www.laserprintercenter.com/laser-printer-news/2010/10/envelope-printing-and-laser-printers/
Basically, it has to do with the envelope enhance feature...
Oct 13, 2008 | Dell 5210n Laser Printer
My printer willnot print envelopes.It states paper size or type is incorrect. On all sizes.
Some printers have an extra feeder under a door on the front or side which allows you to insert an envelope. These types usually will not rcognize an envelope when inserted into the sheet feeders.
If you are using Microsoft Word, you may be able to do it from the "Tools"/"Envelopes & Labels" tab, but you more likely need to find the envelope feeder on your printer, if it exists.
Good luck !!
Oct 10, 2008 | HP Office Equipment & Supplies
Cannot print odd-sized envelope with 4250 LJ
I got to HP tech support, and they tell me that the envelope feeder is intended only for a few standard envelope sizes. If we're trying to use a different sized envelope, as in this case, it must be fed manually, and the feeder bin will not work. So that answers that. Thanks for the help, though.
Apr 29, 2008 | HP 4250 Monochrome LaserJet Printer
Envelope Feeder is not accepting the command
> Home > Support & Drivers > Knowledge Base
Solution --> Phaser 4400 Printer: Printing envelopes
Printing EnvelopesEnvelopes can be printed from the optional envelope feeder, the Multi-Purpose Tray, or Tray 1, 2, or 3.
Guidelines for envelope printing
  • Use only paper envelopes.
  • Do not print on the back of the envelope.
  • Never use envelopes with windows, metal clasps, or exposed gummed surfaces.
  • Keep unused envelopes in their packaging to avoid the effects of moisture and dryness, which can affect print quality and cause wrinkling.
  • Envelopes may wrinkle depending on weight and stiffness of the envelope.
Many applications include a tool for creating an envelope document. For example, Microsoft Word includes an Envelopes and Labels feature in the Tools menu. Be sure to:
  • Select faceup.
  • Clear Clockwise Rotation.
  • Select the feed method with the image centered and the stamp on the envelope to the upper left.
caution_image88x30.gif Never use envelopes with windows, metal clasps, or exposed gummed surfaces; they can damage the printer. Damage caused by using unsupported envelopes might not be covered by your printer's warranty.
note_image33x30.gif Note: The heat from the printing process can melt certain types of envelope glue. If the envelope flap sticks shut after printing the test print, tuck the flaps inside the envelopes when printing the remaining envelopes. Printing envelopes from the envelope feeder
  1. Insert the envelopes into the envelope feeder. For more information, refer to the Trays section of the Trays and Paper Guide on the Interactive Documentation CD-ROM.
    • Place the side to be printed faceup.
    • The top of the envelopes should be toward the left of the printer.
Feb 19, 2008 | Xerox Phaser 4400B Laser Printer
PIXMA 830 Smudges when printing envelopes
On my MP780, be careful to select the appropriate paper type; I was getting black smudges on the left side of my envelopes until I explicitly set that my paper type was "envelope" from "plain paper".
Another idea is to adjust the "ink drying wait time" to a higher level.
Dec 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Ink smudging
Run a cleaning sheet through the printer- absorbant papaer- blotting paper. If this machine has had a lot of service it may be your waste tank is filling up and leaking out - have you had a service warning yet?
Sep 16, 2007 | Epson Stylus RX500 All-In-One InkJet...
Paper / Envelope feed
Envelopes Follow the steps below to load envelopes into this product. Lower the output tray and slide out the extension. Move the feeder guard towards you. While holding down its locking tab, slide the left edge guide so that the distance between the two edge guides is slightly wider than the width of your envelopes. Load envelopes short edge first with the flap side down, as shown in the illustration. Use the line on the feeder guard as the indicator when loading envelope. The right edge of envelope is aligned with the line on the feeder guard. Set the feeder guard back. Note: * The folding quality and thickness of envelopes vary widely. If the total thickness of the stack of envelopes exceeds 10 mm, press each envelope in the stack flat before loading. If print quality declines when a stack of envelopes is loaded, load one envelope at a time. * Do not use envelopes that are curled or folded. * Flatten the envelope flaps before loading. * Avoid using envelopes that are too thin as they may curl during printing. Extract from CX3200 user manual
Sep 25, 2006 | Epson Stylus CX3200 All-In-One InkJet...
HP LaserJet P4014n Printer Logo
49 people viewed this question
Seeker5211
Seeker5211
