Question about Apple MacBook Air
When l fold down my macair, and after a few minutes want to continue with my work, notification appears that l need to restart my computer, and everything is frozen. When l hold power button for a few second in order to restart it, it just shuts down. What is wrong?..
    Master:
  • Apple Master
  • 545 Answers
I would make sure that the screen is cutting power in clamshell mode. These are prone to overheating and it might be cooking your processor. Get SMC fan controller to boost your fans if you feel it getting warm often.
Posted on Nov 10, 2012
  • 1894 Answers
SOURCE: Mac Book Pro repeats Start Up Instructions
what instructions come at startup? please be clear
Posted on Mar 21, 2008
scottyfixit
  • 186 Answers
SOURCE: repated start up requests from the computer
That means Hardware Error. It is a gray iron curtain with a black dialog box. Most likely bad Ram/Memory, but If warranty, call Apple. Otherwise there should be a diagnostics CD or DVD that came with your recovery Disks. It should tell you what's wrong if it can boot before the Iron Curtain comes down again.
You can try swapping ram with a recent age mac or pc laptop and see if it repeats.
Posted on Apr 27, 2008
  • 25 Answers
SOURCE: mac book says you need to restart your computer .
Pressing and holding the power button will shut down your computer. Then you can restart it. You can also tell the computer to restart with the restart command but that does not alway work depending on the problem.
Posted on Sep 03, 2009
  • 87 Answers
SOURCE: macbook restarts when i shut it down
Try going into Utilities folder and open Disk Utility and repair disk permissions. That fixes a number of bizarre issues in Mac.
Posted on Sep 09, 2009
arnomonfort
  • 115 Answers
SOURCE: The power cord gets very hot as does the computer
be carreful, you may have an electrical problem with you're battery. Ask an apple reseller.
Posted on Jan 20, 2010
Tip
How to Remove a Program .
From the Start Menu in Windows .Go to your Contol Panel.From your Control Panel choose Add/Remove Programs. This may take a few minutes for your Programs to appear. Scroll down until you find the Program you want to Remove. Click on Add/Remove .This will uninstall your program. Follow any prompts that may appear. After you have successfully uninstalled your desired program .Restart your Computer. Always Restart your Computer after you Add or Removed a Program.
on Jul 31, 2010 | Computers & Internet
After update the windows i restart my computer but the bluse screen of HP come and come restart and restart i press f8 and after i press stafe mode put nothing happen the blue screen of HP come
Repair the Operating System.
  • Insert your Windows XP CD, save the bios settings and exit. Soon "Press any key to boot of CD" will appear on the screen, hit the space bar to continue.
  • Now setup will inspect your hardware and software, it then will load various files required for the repair. Just wait and be patient, this may take a few moments.
  • Soon a menu will appear (as pictured below), press enter to continue.
  • Now the "End User Agreement" Press "F8" if you agree, "ESC" if you don't.
  • You will now have to select the installation you wish to repair. Usually there is only one, but sometimes, there may be 2 or more (i.e. you have done a parallel install to resolve a problem), use the up/down arrow key to select the install, and then press "R" to continue.
  • Setup will now examine the disk be patient, it can take a few minutes.
  • Setup will go through a percentage - 1 to 100%
  • A screen will soon appear. Press "F3" to continue
  • Now setup will reboot system, wait 15 seconds or just press enter.
  • Now it is time to see if this has solved your problems.
Regards,
Riztech
May 23, 2011 | HP dc7100 SFF PC Desktop
Starts with disk drive 0 seek failure. hit f1to continue then blue screen with stop: 0X0000007E (0XC0000005, 0X83AF9630, 0X8A6BC7B4, 0X8A6BC4B0) appears. Any help?
I have had this problem and had to reset the CMOS. Simply removing the CMOS battery is not always enough. Shut off your computer and disconnect the power. Then find the CMOS jumper, usually near the battery, and remove it, taking careful note of the pins it connected. Move it to the far pins and wait a few minutes. Then move it back to its original position, plug your computer back in and restart it. You may need your Windows disk to get everything working properly again.
Feb 18, 2011 | Dell Inspiron 530s Desktop Computer
My machine counts down time, but the paddles don't rotate, they are free to do so as I took out the pan. when I restart the setting I get a Hor notification on the time area.
That may mean that your machine is detecting that it is not at the right temp and some machines heat up for a few minutes before the paddles start to turn. Try pushing the start button for the Basic bread program and wait 5 or 10 minutes. The paddles should start to turn.....Let me know if this works thanks!
Oct 10, 2010 | Black & Decker B2300 Bread Machine
Wireless Connection Problem
try uninstalling reboot then install again
hope this helps
Aug 01, 2010 | 2wire (2701HG-B) Wireless Router
Notification appears every few minutes suggests problem connecting to GPRS
You need to tap the 3G. Settings. Connections. Advanced tab, Select Network. My ISP drop down. Edit. Tap and hold on anything that appears in the box. Delete. There should be no connections left in the box. Done. Repeat for anything in the My work Network. Edit. Should be empty. IF not, delete any connections by taping on and holding.
Oct 09, 2008 | Palm Treo 750 Smartphone
Have HP Photosmart C7200 and want to scan document to computer but there is no 'Scan to computer' choice to slect on copier scan menu as instructions direct.
I had the same problem and just found the solution.
Solution one: Make sure that the Digital Imaging Monitor is ready The Digital Imaging Monitor must be running in order for the Scan To function to work. If it is running, the DIM icon (c01404188.gif ) is present in the notification area. The notification area is located in the lower-right corner of the computer by the clock. Figure 1: Notification area c01404189.gif If the DIM icon is in the system tray, you do not need to complete this procedure. Skip to the next solution. Follow these steps to set the computer to run the DIM.
  1. On the Windows taskbar, click the Windows icon (c01364735.gif ).
  2. In the Start Search text box, type msconfig , and then press Enter .
  3. On the User Account Control window, click Continue . The System Configuration Utility window appears.
  4. Click the Startup tab.
  5. Select the HP Digital Imaging Monitor check box. If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. Reinstall the software to resolve this issue.
  6. Click Apply , and then click Close .
  7. Click Yes to restart the computer.
  8. Attempt the scan again.
Jun 06, 2008 | Office Equipment & Supplies
2410 Malunction
This problem always hits after a power interruption. On another site I read the solution is to open the back and roll or move the paper wheels back and forth a few times. This worked for me.
Apr 21, 2008 | HP Photosmart 2410 All-In-One InkJet...
Apple MacBook Air Logo
26 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
