Question about Leviton COMBINATION SINGLE POLE TOGGLE SWITCH
I have two lights on the same circuit. Recently had my house sided and when I replace the light bulb on one of the outside lights, it came on when the switch inside the house was off. I turned thw switch on and the light stay on and the other light lit up. So, it appears the switch is fine so I replaced the fixture and the same thing happened, the light stays on regardless of the position of the switch while the other light, on the same circuit goes on and off with the switch. What should I do? Thank you,
  • Leviton Master
  • 5,245 Answers
11-8-12
Clarify: One switch controls 2 outdoor lights.
One turns on-off with switch.
Other stays ON all the time.
If this is not what you mean, then add a comment.
Might have a nail in a wire.
http://waterheatertimer.org/images/nail-in-wire-500.jpg
http://waterheatertimer.org/How-to-wire-switches.html
This is absolute fire hazard.
Notify contractor, call electrician.
We used to do siding, and put nails in water pipes and AC tubes.
Problem would probably be located near light that stays ON.
Posted on Nov 08, 2012
VtToolMan
  • 704 Answers
SOURCE: new Leviton 'lighted, decorative' switch flickers when off
You cannot use standard electronic dimmer switches with CFL bulbs, only incandesant bulbs! That is why you are getting the flickering.
With CFL's bulbs installed in a light fixture that has a non-flouresant rated dimmer switch on that circuit, you will cause the standard dimmer to fail.
You have to look at the dimmer package (sometimes printed on the back of the dimmer itself too) to see if it can be used with CFL bulbs,as many are not rated for use with anything other than standard incandesant bulbs.
Hope you found this very helpful and best regards!
Posted on Aug 07, 2009
buffalonyman
  • 1865 Answers
SOURCE: wiring a leviton 5625-W switch receptacle combination
You cannot replace the switch with a switch/receptacle combo because there is no neutral wire. The black and white that you see are both used as hot wires. One is the Line and the other is the Load.
You have to install another 2 wire cable or replace the existing with a 3-wire cable. A 3-wire cable has a black, red, and white, plus the bare ground wire
Posted on Sep 02, 2009
SOURCE: Have a switch from ceiling light cat # 573, very
You are looking for a 2-circuit 4 position rotary switch, sometimes called a canopy switch. These still made by Leviton available at grandbrass.com and the same type of switch is made by Raco, their part number 6357 which is available through Ace Hardware.
The sequence of these switches are generally low, medium and high. This is achieved by dividing the number of bulbs into two groups. For your five-bulb fixture, it could likely be a group of two and a group of 3 bulbs. The switch has four positions: off, on (2 bulbs), on (3 bulbs), on (2+3 bulbs)
Posted on Nov 19, 2009
al_kupchella
  • 843 Answers
SOURCE: Light switch is off but lights stay on.
If the product is as pictured, (two single pole switches in the space of a single switch), then it probably has 4 terminal screws (in addition to the ground). Look closely at the terminals on one side of the switch. If two terminal screws are brass colored and two are silver colored, look on the brass colored side. There is probably a strip of metal that connects the two terminals together - this is what is keeping your light "on". You need to move one of these wires to the other side of the switch. I assume the other switch operates OK and you only have 3 wires (besides the ground). On the other hand, if you have a total of 4 wires, then one of the wires is probably for powering something else (an outlet, or even another switch that is not supposed to be controlled by this switch). You will probably find that other device is currently being controlled by this switch. You will have to swap two wires, but without more info I can't tell you which ones.
If you found this helpful, please vote.
Posted on Feb 22, 2010
gotgeek2
  • 565 Answers
SOURCE: I installed the PR180 switch
There is nothing wrong with the switch or your wiring. The Leviton R01-PR180-1LI is not designed to work with flourescent lights. A lot of electronic controls will bleed through a small voltage when in the "OFF" state. It's just enough voltage to make the ballast in the flourescent light try to fire but not enough to let it fire the way it is supposed too.
What you need is a motion switch that is rated for flourescent lights, such as this :-( :
http://www.smarthome.com/2520W/Leviton-ODS10-IDW-Commercial-Grade-Wall-Mounted-Occupancy-Sensor-White/p.aspx
Posted on Nov 29, 2010
How to change the light bulb in the outside ice/water dispenser
Question about Maytag 22.6 cu. ft. Side-By-Side Refrigerator with PuriClean II Ice and Water
The light on the outside door (where the ice/water dispenser is) won't turn off. It is dimmer than when you hit the 'light' button, but it stays on constantly when the door is shut. The 'light' button works and turns the bulb brighter, but when you turn it off, it just dims and doesn't go out. The light shuts off when the door is open and turns back on when its closed. Model Number MSD2456GEB
Posted by linsdesk on Aug 31, 2011
Aparajita Batabyal
  • 3,513 Answers
Re: The light on the outside door (where the ice/water...
Hi
Reprogramming your refrigerator to only light up when the dispenser is in use saves energy and keepsyour house darker at night. The light is controlled using the buttons above the water dispenser mechanism.Press and hold the "Lock" or "Lock Controls" button for three seconds to activate the controls if they currently are locked.Tap the "Light" button to switch off the light.Press and hold the "Lock" button for another three seconds to lock the controls from further changes. The light now only comes on when the dispenser is active.
If the above procedure won't work then this will be the cause of a faulty switch. This light switch is an integrated part of the dispenser control circuit board. This will require you, or your service tech to replace the entire dispenser/ice maker control board. It will be located just behind the dispenser fascia, mounted on a bracket. the actual light switch circuit is mounted on this board.
Try this procedure:-
Shutdown the unit for five minutes. Simply unplug the unit for this length of time. This will reset the board, and possibly, fix this fault if it is not to severe. If the shutdown dose not correct the switch action, simply replace the dispenser/switch control circuit board.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Jul 25, 2015 | Maytag Refrigerators
I have a honda accord LX 1991 and the brak lights don't work, the only light that works is the driver side brake light. also I have all new bulbs in the car.
Sounds like the brake bulb sensor unit is short circuited. It is located inside the rear driver's side, trunk mounted tail light housing. It will have to be replaced or opened and repaired, to eliminate the short circuit.
Aug 04, 2011 | Honda Accord Cars & Trucks
How to replace bulb in front bumper turn signal housing 1995 jag xj6
hello,
  • Identify the blown bulb. Note that if a headlight bulb has blown, the dip beam is on the outside and the high beam is on the inside. Turn off the ignition switch and light switches.
  • Open the hood and replace any blown headlight bulbs. Press the plastic spring clips and remove the bulb holder from the assembly. Pull the bulb out of the bulb holder and replace it with a new bulb. It only fits one way. Be sure not to touch the bulb's glass. Replace any parking lights at the same time, they are in the headlamp unit too.
  • Remove the front turn signal light unit in the bumper to change the turn signal bulb. Push gently on the inside edge and insert a blade between the bumper and the lens at the outside edge. Compress the spring and remove the lens. Fit a new lamp by inserting it into the plug. The side marker light is changed using a similar process.
  • Open the trunk to replace the rear fog light, stop light, tail light, reversing light and turn signal light. Remove the rear light cover and turn the bulb holder fastener 90 degrees counter clockwise. Remove the expired bulb, fit a new one and replace the parts, turning the bulb holder clockwise.
  • Thanks..
    May 21, 2011 | 1995 Jaguar XJ6
    How to replace light bulb on side view mirror
    It's not possible to replace bulb in the light it's one unit with neon bulb you have to replace compleat light for that not the jest a bulb. it's most common fault in this model most of lights not working because of wiring broken or short circuit inside the mirror housing for remove and install light housing it's need experience to do that otherwise can damaged some parts inside the mirror mechanism I would like to advice you see the experience technician for mercedes to do that. and ask him to check wiring inside the mechanism first.
    Sep 03, 2010 | 2000 Mercedes-Benz S-Class
    How to change side marker bulb in 1997 altima
    The marker lights are removed by depressing the tab (arrow) with a thin bladed tool. Take care not to scratch the paint
    1. Disengage the bulb and socket assembly from the lens housing.
    2. Gently grasp the light bulb and pull it straight out of the socket.
    To install:
    1. Before installing the light bulb into the socket, ensure that all electrical contact surfaces are free of corrosion or dirt.
    2. Line up the base of the light bulb with the socket, then insert the light bulb into the socket until it is fully seated.
    3. To ensure that the replacement bulb functions properly, activate the applicable switch to illuminate the bulb which was just replaced. If the replacement light bulb does not illuminate, either it too is faulty or there is a problem in the bulb circuit or switch. Correct as necessary.
    4. Install the socket and bulb assembly into the lens housing.
    Dec 07, 2009 | 1997 Nissan.5 Altima
    Bulb replacement
    Look inside the trunk for the back side of the light module housing. Unscrew the large black knob. Before unscrewing it all the way push on the knob to pop out the light module housing from the outside fender, or place your fingers under the lip and gently pull on the housing once the knob is removed. Once pulled out of the housing the bulb sockets will be visible outside of the trunk. replace the l;amps and reverse the procedure to put the light module back into the socket. Screw back on the black knob.
    The front lights are similar but have tension springs instead of knobs.
    Jul 03, 2009 | 2000 Volkswagen Beetle
    1996 Ford Thunderbird LX (lights on outside of trunk) The brake lights and turn signials work and the left side of the trunk lights up but the right side dosen't and I can't figure out where the bulb is to...
    The housing for the bulb is behind the cover. You will need to remove the screws (sometimes just push in clips that can be pulled out) and pull this cover off. At this point you should be able to see the wires going to the bulb/housing.
    May 17, 2009 | 1993 Ford Thunderbird
    No brake light one side
    It is likely that the bulb is just out as the left and right brake lights would be on the same circuit. Unless there is a strange wiring issue simply replacing the bulbs should correct your problem.
    Apr 18, 2009 | 2008 Toyota Highlander
    Drivers Side brake light bulb is burned out.
    Pull the panel back on the INSIDE of the car's hatchback or trunk. The bulbs twist in from the back.
    Dec 03, 2008 | 1993 Ford Mustang
    Both my rear license tag lights are out How do I change the light bulbs?
    if you squeeze the plastic housing around the light they will pop out with little force from the outside. then you just change your bulb and replace
    Aug 30, 2008 | 1999 Chevrolet Blazer
    Leviton COMBINATION SINGLE POLE TOGGLE SWITCH Logo
    62 people viewed this question
    Top Leviton Electrical Supplies Experts
     Kenneth
    Kenneth
    Hippy_dd
    jdthefixer
    Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
