My 8800 will no longer set to RAW.
If I try to set RAW from the mode dial, it takes the
command, but the camera remains in EXTRA.
If I try to set RAW from the main menu, the selections
rotate around among EXTRA and those below it, never going
to RAW or HI.
I haven't found any help in the manual. Anybody have
any ideas?
--Milt--
In order to select RAW mode, first check if your camera is in either Manual(M)/(A)/(AV)/(Ev) modes. Then go to setting-picture format-RAW/RAW+Basic.
In order to edit the RAW picture, you need to update the RAW version if you are using Adobe Photoshop for editing your pictures.
In the manual and shutter-priority modes (set the dial to "M" or "S"), turn the command dial to change the shutter speed. In the aperture-priority mode (set the dial to "A"), turning the command dial changes the aperture and the camera will set the shutter speed appropriately.
If you need a manual, you may download a copy from here.
That depends on what you want the command dial to do. If you're in either the Manual (M) or Shutter Priority (S) modes, the command dial will change the shutter speed. If you're in the Program (P) mode, the command dial will shift the program exposure. If you're in any other exposure mode, the command dial does nothing.
If you hold down the metering mode button, the command dial will change the exposure metering mode. If you hold down the exposure compensation button, the command dial will change the amount of the exposure compensation.
If you hold down the release mode button, the command dial will change the release mode.
If you hold down the AF button, the command dial will change the autofocus mode.
If you hold down the QUAL button, the command dial will change the image storage mode.
If you hold down the ISO button, the command dial will change the ISO.
If you hold down the WB button, the command dial will change the white balance setting.
If you're looking at the menus, the command dial will navigate the menu.
If you're reviewing pictures, the command dial will move to the previous or next picture.
Hope this helps. If you still have problems or other questions about this, please don't hesitate to reply to this post.
Hello mehran_vafae,is supposed tohaveputaDX lens. The mode dial,selectin what wayis goingtotake a picture. Youcanmakecombinationsaccording tothe modeset in themodedial,withtheFn key/commanddial,commanddial/apertureAmode,commanddial/shutterspeedSmode,FullAuto/+/-compensationsw,etc... Pleasecarefullyreadtheusermanualsuppliedwithyourcameraandif it failstake them toNikon service. Regards
You put the camera into one of the Continuous modes by holding the Release Mode button (to the right of the LCD control panel on the top of the camera, marked with a set of overlapping rectangles) and turning the command dial on the back. The two choices are Continuous Low and Continous High (marked with the overlapping rectangles and the letter "L" or "H"). Frame and shoot as normal.
In continous mode the camera will take pictures as long as your finger remains on the shutter release button or until the buffer fills up. In Continous High the camera will take as many as 4.5 pictures a second. Custom Setting #d6 controls how fast Continous Low shoots.
Bear in mind that the speeds mentioned are only maximums. If your shutter speed is set to half a second, you're obviously not going to take four pictures in one second.
Program: Puts the camera in charge of aperture and shutter speed, though all remaining camera settings are available. You can vary the combination of aperture and shutter speed the camera has selected by rotating the Command Dial. from:http://www.imaging-resource.com/PRODS/D40X/D40XMENUS.HTM The camera takes care of the shutter and aperture settings, and you control the other stuff...(presumably white balance, focus points...etc.?). I hav ea D70 and using the thumb wheel, I can, on 'P' mode, set the aperture...but the shutter speed is always 'auto' as far as I can tell. Best of luck! Nick Chapmanhttp://ChapmanIT.com
Make sure that the mode dial is not set to one of the 'Basic Zones', i.e. Auto, Portrait, Landscape, etc. You should be able to select RAW or RAW+L in P, Tv, Av, M, or A-DEP.
You can only change the aperture using the command/sub-command dial on your camera. The aperture ring on the camera must remain locked at the smallest setting (largest number).
