Question about Vacuums
Where is the switch to turn on dirt devil vaccum cleaner
  • Vacuums Master
  • 1,238 Answers
It is usually found near the power cord
Posted on Nov 08, 2012
5 Suggested Answers
SOURCE: changing a vaccum belt
I have a problem putting a new belt on the hoover tempo upright U5140-900 vacuum.
earlinerayburn@yahoo.co
I tried to get the manual
Posted on Feb 19, 2009
ukvacfan
  • 328 Answers
SOURCE: Dirt Devil Extreme Quick Vac - Won't turn on
Check that the filters are completely clear and not blocked - especially the top filter on top of the bin assembly. If its clogged completely brush it free of dirt and then reassemble. Make sure the inner cone filter and mesh filter is also completely clean. Then check the hose and main dust channel - something is clogged that makes this machine overheat and stop working - and often with this model (Hoover also make it in the UK under the Alyx name) its down to clogged filters or small clogs of dust in the dust channels.
Don't forget to rate, thanks.
Posted on Mar 06, 2009
SOURCE: dirt devil dynamite spinning thing isn't spinning
does the unit have a belt?
Posted on Feb 01, 2010
  • 159 Answers
SOURCE: The Dirt Devil Featherlite vacuum cleaner throws
You have a blocked vacuum hose take hose off and out side. Push the garden hose from one end to the other, this will push out the blockage
Posted on May 10, 2010
My dirt devil spot cleaner doesnt have suction for vaccume??
You either have a blockage or the bag needs emptying or cleaning.
Mar 09, 2018 | Dirt Devil Vacuums
Won't turn on
change the switch with a brand new one and that will fix the problem the switch has gone out on another dirt devil vacuum and that is so common it is hard to explain it is a defect in the way the switches are made
Mar 17, 2014 | Dirt Devil SD30035 Express Bagged Canister...
No suction in vaccum cleaner
Look for a clog somehere in the intake path, perhaps right at the top of the canister.
Feb 13, 2014 | Dirt Devil Featherlite Bagless Vacuum...
My vaccum cleaner doesnt show the gathering dirt in the transparent section while vaccuming
my vacuum was working for a few minutes and just stop in middle of doing its job and no problem with electricity
Feb 09, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Belt pulley is broken
sad to say but as far as i know you cannot get any parts for dirt devil vacs only filters and belts and bags sorry
Nov 03, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Wont shut off when I press the power button
the switch has failed inside the unit so it is stuck in the on position
Oct 27, 2009 | Dirt Devil Featherlite Deluxe Bagged...
How do you replace the belt on the dirt devil feather lite vaccum.
not a expert just trying to help,,turn vaccum over take plate of and pull brush out and install new belt,,hope this help you
Oct 20, 2009 | Dirt Devil CE6100 Featherlite Upright...
My dirt devil vacuum cleaner is not working
Please specify whether the vacuum motor does not turn on when you flip the switch or it simply does not have suction.
Aug 05, 2009 | Dirt Devil M130000 ''i'' Dual Cyclonic...
Cleaner is not picking up debris from pool bottom
Have you check the filter/baskets to make sure that you don't have a large piece of debris that is preventing suctions? You will also want to check each section on the vaccum systematically to make sure that there are not cracks or noticable areas of damage that would prevent the pool cleaner from working. Is is not moving at all or just not sucking properly? Can you give me more details as to what it, exactly, it is doing?
Apr 19, 2009 | Dirt Devil Rampage Robotic Pool Cleaner...
Dirt devil vaccum #088915 won't pick up.
well the first thing i would look for is if the brushes turn turn it over bump the on off switch if it turns the belt is fine but u might have a clog in the bottom if that the case have to pull cover from thhe bottom take the belt and roller brush off and look up insde where the junk sucks up use a wire hanger if u need and after that clean out where the dirt goes in bag or canister........hope this helps
Dec 16, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
