Question about HP Officejet 5510 All-In-One Thermal Printer
Where is the sensor located on an OfficeJet 5510?
I have an OfficeJet 5510 that takes a VERY long time to print. I read somewhere that the problem may be the sensor. Do you know where it is located?
    Guru:
  • HP Master
  • 829 Answers
Hi I suppose its would not be advisable for you to remove the sensor unless you know about the printer status. Please give it to a service provider who can diagnose and replace the sensor, Mostly sensors are basically for paper trays to pick up and print the printouts
Posted on Jan 05, 2009
HP OfficeJet 5510 All-in-One print slowly -
Hi
you need to replace your cartridges
one of it will stop printing and a message will come in
you monitor "cartridge error" and it must be replaced
In case I had help you pls vote me
Nov 06, 2010 | HP Officejet 5510 All-In-One Thermal...
I have an HP officejet 5510. I want to print in black only/
Go into the printer options and set it for grayscale only.
Jul 28, 2009 | HP Officejet 5610 All-In-One InkJet...
Not printing hp officejet 5510
plz delete all the printing job from the printer and reinstall the printer. plz post your findings
Dec 17, 2008 | HP Officejet 5510 All-In-One Thermal...
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
Ink location
Hi, I can help you. The ink is behind the print-carraige access door. Here is a link to the printer manual, go to page 63. But by all means download it and save it to your desktop. That is a good printer, but pretty complicated sometimes. Good luck.
http://h10032.www1.hp.com/ctg/Manual/bpu72474.pdf
Mar 09, 2008 | HP Officejet 5510 All-In-One Thermal...
The ink carthridge location
how do I get to the ink cartridge on a hp 5510 all-in one?
Feb 15, 2008 | HP Officejet 5510 All-In-One Thermal...
Printer installation
ok how is the computer hook to printer ,
(usb? or serial cord) ?
what operating system are you using
and what software are you using for print drivers
let me know and i can help you in greater detail but here is a link to hp for your printer
i hope this is somewhat helpful
feel free to reply back if you cant get it working im shure i can help
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Officejet+5510+All-in-One&opname=HP+Officejet+5510+All-in-One&qry=I+am+having+trouble+with+the+computer+recognizing+the+HP+Officejet+5510.++What+can+I+do%3F&method=prodFinder&ctry=us&lang=en&dlc=en&sni=311255&search=0&submit.x=0&submit.y=0
Oct 31, 2007 | HP Officejet 5510 All-In-One Thermal...
HP Officejet 5510 All-In-One Thermal Printer Logo
248 people viewed this question
Ben Johnson
