I have a Junghans Mega alarm clock (radio-controlled). The 'minus' button has recently stopped working - you can press it, but nothing happens. Do you know if this can be fixed? I don't
Http://www.mridout.force9.co.uk/ecw/radio.htm - picture shown on this site.
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Posted on Feb 17, 2008
SOURCE: How to set time/alarm GE Auto Clock Set Radio Model 7-4892A
I have a solution for the GE Auto set clock and radio model number 7-4892A. The only way that I had found out just by accident is that you are suppose to hold down the manual clock set until you start to see the Year and then the Date. There you will be able to set it to the correct date or year.
Idea from
Guest
Posted on Mar 11, 2008
SOURCE: Remote code required for UK Bush tv model WS6680SIL/C7
Found the correct code for my TV & Sky remote... I searched a fair bit more on google for... "WS6680SIL/C7 code" and found... http://www.sjstv.co.uk/skycodelistNEW.html which the correct code for my Bush TV - 0742. Others you may want to try are Bush 0157 246, 263, 377, 037, 064, 065, 310,300,383, 399, 391, 402, 339. or Beko 0125 514, 398. Further, Alba Group are the firm whom own Bush brand amongst others. Google Alba Group to get their site and links to Bush sites.
Posted on May 20, 2008
SOURCE: Water spill on Bose Wave Radio - Radio now buzzes.
Hi i needed my subwoofer repairing andtook it to my local bose stockest for it to be repaired.
Posted on Oct 17, 2008
SOURCE: I can't set the time, the alarm time, or do anything of that sort
AHAH! I had this problem also, so i tried google and it led me here. Luckily, I kept trying and figured it out so I will share my knowledge with you although you may have found it out already...
First, make sure the radio and ipod are off and it's in clock display mode.
Then, click and hold "alm set" while clicking the left "timer set" arrow to set the hour of your alarm and the right "timer set" arrow to set minutes for your alarm.
Then click "alm on/off" to turn it on and off.
Posted on Oct 19, 2009
Need a user manual for skyscan model 31420e atom travel clock
Late to the party I guess. Lots of entries for setting the clock, but not for the alarm. Press the plus or minus button. That's it. After you have the time set, you can then press the ALARM button above the WAVE/SET button to turn it on.
May 06, 2012 | Audio Players & Recorders
I just got a Memorex Digital CD Alarm Clock with no manul the modle number is MC 7101. I'm not able to set the clock or alarm. I just need the instructions.
To set the clock:
1. With the power off, press the TIME button; the time will blink.
2. Press the MINUTE button to set the present minute and the HOUR button to set the present hour.
Make sure to set the correct AM/PM setting.
3 Press the TIME button (or wait approx. 15 seconds) and the time will be set.
To set or reset alarm time:
1. With the power off, press the desired ALARM, Press and hold the desired ALARM 1 or ALARM 2 button; the alarm time will blink. The Alarm 1 or Alarm 2 time and settings will appear.
Press the MINUTE button to set the alarm.
2. Press and hold the desired ALARM 1 or ALARM 2button; the alarm time will blink.
Press the MINUTE button to set the alarm minute and the HOUR button to set the alarm hour. Make sure
to set AM/PM setting. Press the ALARM 1 or ALARM 2button again (or wait approx. 15 seconds).
3. Repeatedly press the ALARM 1 or ALARM 2 button to select alarm off, alarm on, for buzzer, radio or CD.
If you needed the manual it could be downloaded:
http://www.retrevo.com/support/Memorex-MC7101-Clock-Radios-manual/id/1081dj880/t/2/
Thanks.
gylacz
Aug 01, 2011 | Memorex MC7101 Clock Radio
I need help setting the alarm on my radio controlled digital clock.
1- Turn over your Seth Thomas digital clock. Use your finger to remove the cover to the unit's battery compartment. Insert two AA-size alkaline batteries into the battery compartment and replace the cover. Certain Seth Thomas digital clock units will also have an optional alternate power source in the form of a standard AC power cable that plugs into a wall outlet in your home.
  • 2 Place your Seth Thomas solar-powered digital clock in front of a light source, such as on a window sill or beneath a lamp. The black strip on the top of the unit is the solar sensor, so as long as light is shining down on that strip, your clock will be powered on and ready to use. The sensor stores energy throughout the day so that it can work at night with no direct light contact on the sensor.
  • 3 Press the time zone button that indicates your current time zone. These buttons are located on the back of the unit. For example, if you are in the eastern time zone select the "EST" button. Turn the unit back over. It will now be displaying the correct time on its digital screen.
  • 4 Use the "Alarm" switch (if applicable) to enable and disable the clock's alarm. Press the "Alarm" button, followed by the "Hour" and "Minute" buttons, to set the appropriate alarm time based on your needs. Use the "Alarm HI LO" switch to set the volume for the alarm.
  • 5 Press the "Weather" button to tune your Seth Thomas digital clock to its built-in local weather radio station (if applicable). Certain Seth Thomas clocks have this radio weather functionality built in, while others don't. If yours does, the aforementioned "Weather" button will be located on the front of the unit.
  • May 28, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    How do I set the alarm so it will activate on weekdays. It only works for Saturday and Sunday. Thanks
    Hello
    Sure Alarm battery Back-Up System
    This SmartSet® Clock Radio includes a Sure Alarm battery back-up circuit that can
    wake you up even if the power is 'Off'at the selected wake up time. If your power
    is 'Off'at the selected wake up time the clock display will be off and the radio will
    not operate, but a separate mini-buzzer will turn 'On'automatically to wake you up,
    even if you had selected the "Wake to Radio"option.
    The Sure Alarm will sound for 30 seconds and then shut off automatically.
    To stop the Sure Alarm buzzer immediately, press the RADIO ON/OFF button.
    Pressing the SNOOZE button has no effect during Sure Alarm operation.
    Note: In order to maximize the life of the built in lithium battery, please be sure
    to set the ALARM 1 and ALARM 2 switches to the "OFF"position if the radio
    will be disconnected from the AC outlet for more than a few hours. This will
    prevent the Sure Alarm from turning 'On'unnecessarily.
    1.) Depress and hold either the ALARM 1 or ALARM 2 setting button.
    The display will change from the correct time
    to the Alarm 1 or Alarm 2 wake up time.
    2.) While holding the ALARM 1 or ALARM 2 setting button, depress either the
    SET + or - button to move the display ahead or back to your desired wake up
    time.
    3.) When the desired wake up time appears on the display, release the SET + or
    - buttons.
    Note: Be sure that you have set the wake up time correctly by observing
    the AM indicator. If the AM indicator is 'On'the wake up time is "AM". If the
    AM indicator is 'Off', the wake up time is "PM".
    4.) When the desired wake up time (AM or PM) appears on the display, release
    the ALARM 1 or ALARM 2 setting buttons
    Apr 20, 2011 | Emerson Smartset Clock Radio
    I don't know how to set the clock for a MA4203 model
    I couldn't find the information for your particular model, but I did figure out the general procedure for Memorex alarm clocks currently in production:
    1. Make sure power is turned off (no radio or whatever playing). Press the Time Set button (on some models, this is the Skip Search Back button for an iPod docked in the unit).
    2. When the display blinks (on one model, the volume control knob lights up), press the Hour button (Vol. -) to set the hour, then press the Minutes button (Vol. +) to set the minutes. On the model with the light-up volume control, rotate the volume control knob to set the time.
    3. When you have the time set, either wait 15 seconds or press the Time Set button again to start the clock.
    Setting the alarm works the same way on single alarm models, but the Alarm Set button may be the Skip Search Forward button. Dual alarm models have separate Alarm A and Alarm B buttons.
    Feb 05, 2011 | Memorex Audio Players & Recorders
    Instructions to 'science museum' radio controlled alarm clock
    press the alarm button (so the alarm time is on the screen) then the + button. do the same to deactivate the alarm.
    it took me forever to work this out after losing my instructions, feel a bit of an idiot now it seems so simple
    Jan 05, 2010 | La Crosse Radio Controlled Atomic Clock
    Oregon Scientific RRM326P Snooze button won't work with radio
    this is internal speaker control volume defect, please send to repair shop for repair.
    Nov 29, 2009 | Audio Players & Recorders
    I have 2 clocks (model 40009,40010)that have inaccurate time
    I read the manual which said to depress the alarm button. That wasn't the right button but I found that depressing the button next to it, the DST button, that that fixed the problem.
    Thanks.
    Oct 24, 2009 | Equity Time USA 30731 LED Digital Electric...
    ISymphony CRDCD clock radio alarm programming
    Play around with the Alarm1 button, test it every minute and when it goes off press Alarm1 again to stop it, not snooze. Then try pressing vol + as nothing is playing. Keep trying until your alarm goes off at the desired volume that you put in your Alarm1 settings
    Mar 07, 2009 | iSymphony CR8CD CLOCK RADIO MUSIC SYSTEM...
    1,036 people viewed this question
     Grubhead
    Grubhead
