Question about Toshiba Satellite C655-s5140 Laptop
Connecting charger and letting charge for sometime...charging light doesnt turn on and laptop doesnt turn on...any advise?
    Novelist:
    Champion:
  • 233 Answers
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
http://www.chargerbuy.com/replacement-toshiba-satellite-c655-ac-adapter-19v-65w.html
http://www.chargerbuy.com/replacement-toshiba-satellite-c655-ac-adapter-19v-3-95a.html
Posted on Nov 08, 2012
My eee pc 1005hab laptop won't charge. I have it connected to the charger and nothing I don't know what to do. Please help
When this happends, the three usual suspects are the charger, the charging port (where the charger plugs into the laptop), or the motherboard itself.
Now to see where the problem lies. These would be my first steps...
1> Is there a light on the charger, if so, does it light up? If it does have a light, and it lights up then we can leave the charger out of the equation. If it has a light and it does not light up, we can assume the charger is the culprit. If it does not have a light, you will need a voltage tester.
2> Is where you plug the charger into the laptop loose? Sometimes, the charging port on the laptop can become loose (separation or partial separation (also known as a short) from the motherboard and loose the connection to the laptop. This keeps the energy from reaching both the laptop and the battery to create a charge.
God luck!
Mar 14, 2015 | Microsoft Computers & Internet
Battery wont charge
Let the battery drain out completely and then remove it from the laptop and leave it for about 5 - 6 hours then replace battery and connect charger - should fix the issue - It will take sometime for the charge light to come up - if it does not contact manufacturer
Oct 17, 2013 | ASUS Eee Computers & Internet
My MSI GT680 Notebook charging system doesnt work. when I plug my charger into the wall the green light indicator comes on, then when I put the plug into the laptop the light turns off and it doesn
Hello! It seems that you have a problem with the laptop charger connector. It maybe in short circuit. You can try to look for some electronic workshop that works with reballing, BGA solder, etc., that might change it. In Portugal we have some, so I think in other countries you can find them to.
Apr 03, 2013 | MSI Microstar GT680R-008US 15.6" Notebook...
Samsung R519-53S not charging
Please remove battery and connect charger and turn on computer. If on adapter working fine, now connect battery without removing charger , and check charging.
May 09, 2012 | Samsung R519-53S Notebook
Battery won't charge
connect the charger to the socket, then connect the charger to your laptop. if it does not charge remove it for 5mins, connect the charger back. it will work now. sometimes when the battery is fully charged and you remove the charger and connect it back it may not charge until the battery is low;lets say 99%.
Sep 23, 2011 | Advent 4211c Notebook
I have a compaq presario cq61 and have been having problems with the charger for quite a while but money is an issue so cannot get a new one just yet, the laptop has 2 lights to aknowledge that the...
YOUR PACK IS NO GOOD
IT MUST RUN WITH NO BATTERY
PACK CONNECTED
SINCE IT DONT THEN THE CHARGE IS WEAK TOO.
YOU KNOW PACKS CAN BE
GOOD
BAD
OR WEAK, OR EVEN ON FIRE, (loL)
Mar 01, 2017 | HP Compaq Presario CQ61420us Notebook
Normally when i charge my cameras battery a red light will turn on to let me know its charging and will stay on until it is fully charged but whn i went to charge my battery yesterday the red light began...
Charge your battery with an external power supply or a car battery charger for like 10 seconds (1 ampere will do the trick) by connecting the + and the - of the battery to the + and - of the power supply.
Now insert the battery in your normal charger. ìf it will still not charge do it again for 10 seconds.
Dec 27, 2009 | Casio Exilim EXZ75 Digital Camera
My acer aspire 5315 doesnt charge properly.
I'm sorry to say that your initial fears are correct and the pin that the adapter connects to in the laptop is loose. This is a common problem with laptop's and can be easily dealt with.
Now I'm not going to tell you to open the laptop up and de-solder the adapter (unless you want me to).
Because this is a fiddly job and you have to order the correct adapter i recommend you take it to a reputable repair store and have them replace the adapter for you, don't let them tell you that you need a new motherboard as this is not the case at all, adapters can and do get regularly get fixed and is not that expensive.
Good luck.
Aug 18, 2009 | Acer Aspire 5315 Notebook
Can't connect charger's cables to battery without sparks
NEVER connect positive to negative. You'll damage your electrical system in the car or fry the charger.
It is best to put the positive on first, and then the negative. Remember, it doesn't always have to be the negative post of the battery, it can be a really good ground on the bare metal of your car.
But sparks just go along with it - don't let them scare you. But I always connect the clamps first, then turn on the charger, with the dial on "off". Then make sure of the 6/12 volt settings, and the amp charge you want to put on. A long slow charge overnight fo 12 volt can be 10 amps. A relatively fast is 50. And then to jump it off, go to the setting.
Make sure the battery being charged is sitting in wood, not concrete. If you have the old fashioned battery with removeble water caps, don't breathe the vapors.
May 28, 2009 | Schumacher & Fast Charge Starter Charger
The batterie charger for my Casio Exilim EX-Z77 has a blinking red light instead of a continous red light when i try charging the batterie. also, it doesnt appear to be charging it at all. Left in in for...
The blinking light indicates a charging error. Try connecting a 9 volt battery to your camera battery. Sometimes if the battery has lost all charge, the charger doesn't recognize it properly.
Dec 05, 2008 | Cameras
Toshiba Satellite C655-s5140 Laptop Logo
93 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
