Question about Tools & Hardware - Others
How do I put a powershot pro 8000 back together
My handle was getting stuck so I took my staple gun apart. I had an emergency and when I started to re assemble my staple gun I could'nt remember what piece went where.
    Top Expert:
  • Tools & Hard... Master
  • 50,503 Answers
I had the same problem
found it cheaper and easier to junk the bits and get a newer model
Posted on Jan 01, 2017
ginko
  • 19396 Answers
SOURCE: ASSEMBLY
Check this link here it is not a diagram but there is a view of the disassembled tool, and some instructions.
Posted on Sep 04, 2008
lessmith49
  • 5 Answers
SOURCE: see above
317b762.jpg4a538aa.jpg067f3f0.jpg5077a62.jpgca392ef.jpge76904e.jpg77309d5.jpgThis is an older b&d stapler but the designs are similar in most cases. The position of the springs, and the order you put them in, are an obvious factor.
The parts that overlap go in after the parts underneath.
When you have one half assembeled you should not have to force the cover to go on, it should just sit in place while you put the screws back in.
If the handle coil spring and the flat spring are not seated properly the top cover will not go on easily.
These types of staplers are designed to clear from jamming without being taken apart, the staples, under normal circumstances, do not have access to the body of the unit past the flat spring.
As with any tool forcing the tool after a fault will only make matters worse, I would try some light oil or spray lubricant first before taking anything apart, these springs can be a pain to get back in, which is why I have not taken this one any further apart. Hope this helps you. If it does please let fixya know.
Regards
Les
Posted on Feb 12, 2009
SOURCE: Can't get my Black and Decker 5700 powershot back together.
Need instruction manual on how to put it back together
Posted on Nov 17, 2009
SOURCE: powershot pro staple gun
just purchased a Powershot model 5700m. how do you load the staples?
Posted on Feb 23, 2011
SOURCE: Stanley TR 250 Staple Gun Staple cartridge problem
very simple to fix it 1 pull the trigger all the way out 2 there is a little piece of metal, pull it all the way out (detach the piece out from the gun) an connect one side of the spring 3 push the piece back on the gun. 4 on the other side of the spring tide a little fishing line 5 pass the fishing line over a small rounded piece and pull it hard 6 finally connect the side of the spring onto a little hock on the base of the trigger
Posted on Apr 21, 2011
Can't get the handle on my staple gun to go down
Most staple guns have a flat piece of metal that strikes the staple and drives it into the item you wish to staple.
If the handle will not go down, it is likely "stuck:"
You or someone else must "unstick" it by cleaning it, and while you are at it, add a tiny drop of oil to the mechanism.
God bless your efforts.
Aug 24, 2017 | Tools & Hardware - Others
How too release the emergency brake foot pedal when the cable is broken?
About 73,400 results (0.87 seconds) Search Results
    Parking brake release cable snaps - Chevy Avalanche Fan Club of ...
    chevyavalanchefanclub.com > ... > Problems: Brakes
    24 posts - ‎16 authors
    Went to release the parking brake on my 04 and the cable snapped. ... More like the end cap coming of the cable that attaches to the foot pedal. ..... Then I released the parking brake, pulled out the broken release cable/handle assembly, ...
    How To Install Repair Replace Parking Brake Release ...
    ? 5:54
    https://www.youtube.com/watch?v=qx0oGfV62NQ
    Jun 23, 2011 - Uploaded by 1A Auto Parts
    How To Install Repair Replace Parking Brake Release CableHandle ... or replace a broken or worn out parking brake release cable handle.
    Emergency Brake Pedal Assembly & Stuck Brake Cable ...
    ? 10:13
    https://www.youtube.com/watch?v=0jYfvthBzhU
    Apr 17, 2014 - Uploaded by corgLLC
    Emergency (Parking) Brake Pedal Assembly & Stuck Emergency (Parking) Rear Brake Cable The emergency ...
    E-Brake Cable Broken? Stuck Emergency Brake... Help Please ' Chevy ...
    www.tahoeyukonforum.com > ... > Engine & Drivetrain
Jan 25, 2016 | Cars & Trucks
WHEN STAPLE GUN IS PLUGGED IN IT WON'T START. PLEASE ADVISE.
Take the entire staple feed assembly on the bottom apart. Sometimes a staple or part of one jams in the back/inside of the mechanism and can only be pried out with needle nose pliers. Good luck.
Sep 14, 2015 | Tools & Hardware - Others
Tools & Hardware - Others Logo
506 people viewed this question
Top Tools & Hardware - Others Experts
John Trevino
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
