I have a Junghans Mega alarm clock (radio-controlled). The 'minus' button does not work - you can press it, but nothing happens. Do you know if this can be fixed? I don't know if this i
Http://www.mridout.force9.co.uk/ecw/radio.htm - picture shown on this site.
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Posted on Feb 17, 2008
SOURCE: How to set time/alarm GE Auto Clock Set Radio Model 7-4892A
I have a solution for the GE Auto set clock and radio model number 7-4892A. The only way that I had found out just by accident is that you are suppose to hold down the manual clock set until you start to see the Year and then the Date. There you will be able to set it to the correct date or year.
Idea from
Guest
Posted on Mar 11, 2008
SOURCE: Remote code required for UK Bush tv model WS6680SIL/C7
Found the correct code for my TV & Sky remote... I searched a fair bit more on google for... "WS6680SIL/C7 code" and found... http://www.sjstv.co.uk/skycodelistNEW.html which the correct code for my Bush TV - 0742. Others you may want to try are Bush 0157 246, 263, 377, 037, 064, 065, 310,300,383, 399, 391, 402, 339. or Beko 0125 514, 398. Further, Alba Group are the firm whom own Bush brand amongst others. Google Alba Group to get their site and links to Bush sites.
Posted on May 20, 2008
SOURCE: Water spill on Bose Wave Radio - Radio now buzzes.
Hi i needed my subwoofer repairing andtook it to my local bose stockest for it to be repaired.
Posted on Oct 17, 2008
SOURCE: I can't set the time, the alarm time, or do anything of that sort
AHAH! I had this problem also, so i tried google and it led me here. Luckily, I kept trying and figured it out so I will share my knowledge with you although you may have found it out already...
First, make sure the radio and ipod are off and it's in clock display mode.
Then, click and hold "alm set" while clicking the left "timer set" arrow to set the hour of your alarm and the right "timer set" arrow to set minutes for your alarm.
Then click "alm on/off" to turn it on and off.
Posted on Oct 19, 2009
Need a user manual for skyscan model 31420e atom travel clock
Late to the party I guess. Lots of entries for setting the clock, but not for the alarm. Press the plus or minus button. That's it. After you have the time set, you can then press the ALARM button above the WAVE/SET button to turn it on.
May 06, 2012 | Audio Players & Recorders
I need help setting the alarm on my radio controlled digital clock.
1- Turn over your Seth Thomas digital clock. Use your finger to remove the cover to the unit's battery compartment. Insert two AA-size alkaline batteries into the battery compartment and replace the cover. Certain Seth Thomas digital clock units will also have an optional alternate power source in the form of a standard AC power cable that plugs into a wall outlet in your home.
  • 2 Place your Seth Thomas solar-powered digital clock in front of a light source, such as on a window sill or beneath a lamp. The black strip on the top of the unit is the solar sensor, so as long as light is shining down on that strip, your clock will be powered on and ready to use. The sensor stores energy throughout the day so that it can work at night with no direct light contact on the sensor.
  • 3 Press the time zone button that indicates your current time zone. These buttons are located on the back of the unit. For example, if you are in the eastern time zone select the "EST" button. Turn the unit back over. It will now be displaying the correct time on its digital screen.
  • 4 Use the "Alarm" switch (if applicable) to enable and disable the clock's alarm. Press the "Alarm" button, followed by the "Hour" and "Minute" buttons, to set the appropriate alarm time based on your needs. Use the "Alarm HI LO" switch to set the volume for the alarm.
  • 5 Press the "Weather" button to tune your Seth Thomas digital clock to its built-in local weather radio station (if applicable). Certain Seth Thomas clocks have this radio weather functionality built in, while others don't. If yours does, the aforementioned "Weather" button will be located on the front of the unit.
  • May 28, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    I don't know how to set the clock for a MA4203 model
    I couldn't find the information for your particular model, but I did figure out the general procedure for Memorex alarm clocks currently in production:
    1. Make sure power is turned off (no radio or whatever playing). Press the Time Set button (on some models, this is the Skip Search Back button for an iPod docked in the unit).
    2. When the display blinks (on one model, the volume control knob lights up), press the Hour button (Vol. -) to set the hour, then press the Minutes button (Vol. +) to set the minutes. On the model with the light-up volume control, rotate the volume control knob to set the time.
    3. When you have the time set, either wait 15 seconds or press the Time Set button again to start the clock.
    Setting the alarm works the same way on single alarm models, but the Alarm Set button may be the Skip Search Forward button. Dual alarm models have separate Alarm A and Alarm B buttons.
    Feb 05, 2011 | Memorex Audio Players & Recorders
    Instructions to 'science museum' radio controlled alarm clock
    press the alarm button (so the alarm time is on the screen) then the + button. do the same to deactivate the alarm.
    it took me forever to work this out after losing my instructions, feel a bit of an idiot now it seems so simple
    Jan 05, 2010 | La Crosse Radio Controlled Atomic Clock
    Oregon Scientific RRM326P Snooze button won't work with radio
    this is internal speaker control volume defect, please send to repair shop for repair.
    Nov 29, 2009 | Audio Players & Recorders
    I have 2 clocks (model 40009,40010)that have inaccurate time
    I read the manual which said to depress the alarm button. That wasn't the right button but I found that depressing the button next to it, the DST button, that that fixed the problem.
    Thanks.
    Oct 24, 2009 | Equity Time USA 30731 LED Digital Electric...
    I have a Zenith ZG120M alarm clock radio. I can't set it.
    Here is how I set my ZENITH ZG120M radio alarm clock.
    1) PRESS AND HOLD DOWN the HOUR BUTTON and then PRESS the TIME BUTTON to set the correct hour.
    2) PRESS AND HOLD DOWN the MINUTE BUTTON and then PRESS the TIME BUTTON to set the correct minute.
    To Set The Wake Up Time
    1) PRESS and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the HOUR BUTTON to set the desired hour.
    2) Press and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the MINUTE BUTTON to set the desired minute.
    There are two light indicators that light up on the left side of the LED display...the top light indicator will come
    on once the time turns to PM. The bottom light indicates the alarm is set.
    Mar 25, 2009 | Timex T309TT Clock Radio
    Radio?
    I'm having this same problem. All of a sudden, the radio button doesn't work. I set the radio alarm to go off and when it does, only the buzzer goes off. I don't know what happened. Is the manual available online somewhere?
    Oct 14, 2007 | Timex T309TT Clock Radio
    183 people viewed this question
     Grubhead
    Grubhead
