Question about Xerox WorkCentre Pro 416 All-In-One Laser Printer
Xerox workcentre 416 call for service message at start up
SOURCE: Xerox service manual
check out website www.service-manual.net and search for your printer.
Posted on Mar 15, 2009
  • 2072 Answers
SOURCE: Xerox Workcentre Pro 416 P
This would be the first thing to try..
  • Press the 0 and 8 keys simultaneously and switch on.
  • Input 400 using the numeric keys, and press the enter key.
  • Change displayed status counter to 0, and press the enter key.
  • Switch the machine off then on. Check that the machine returns to the normal standby mode. If the machine does not return to normal standby mode, perform the following checks.
  • Posted on Feb 18, 2008
    • 2072 Answers
    SOURCE: my xerox workcentre pe 220 machine have an error message on "low heat error"
    You will have to replace the fuser.
    Posted on Apr 19, 2009
    • 239 Answers
    SOURCE: CA1 error code on my xerox workcentre 416
    Before replacing the laser, make sure it has the latest revison of software.
    If installing a laser with old software on the machine, the machine will still give you that same code off and on.
    The software can be loaded by a Xerox representative, i do not know of other means you can load it with.
    The reason for having the new software is because of the drivers on the old software cannot work the timing of the laser, causing this error code.
    Take the service call, you may need to have the laser replaced anyway, there are about two differnt type lasers used in this machine. If you replace it, make sure you have the right one for this model.
    Good luck.
    Posted on Oct 17, 2009
    • 239 Answers
    I hope this messege come through.
    This is a call for a Xerox service rep to visit the machine.
    First you need to know if it has the latest software on the machine. If it has old software, and a new laser is installed, the error code will come back again.
    You will need to have the right model for this machine and the right main board to match it.
    Best to place a service call and let Xerox handle it.
    I have Workcenter PRO 416 and display says change toner but after replacing toner,the same message comes up.
    I had that happen before. It turns out the refilled toner cartridge I was using was the problem. When I bought the cartridge I thought I was getting a new one. They were refills. You may want to try another cartridge if you have one.
    Good Luck
    Nov 30, 2010 | Xerox WorkCentre Pro 416 All-In-One Laser...
    MY xerox work center pro copier 416 works well while photocopying,but i need a driver to operate from my PC
    Here is the xeros link to drivers from A-Z.  There is no workcentre pro 416 listed.  Check your model number and scroll down to workcentre.  Good luck.
    http://www.support.xerox.com/go/prodAtoZ.asp?Xlang=en_US
    Oct 13, 2010 | Computers & Internet
    Need to reset replace drum message on Xerox Workcentre Pro 416
    You can replace the chip on the drum unit. Or the drum unir itself.
    Google a business called " the parts drop". They will have both the chip and or the drum cartridge. It is not resettable with a diagnostic code.
    Aug 19, 2010 | Xerox WorkCentre Pro 416DC Copier
    Is it possible to reset pro 416 out of this problem.
    Limited information provided.<br /> Pressing 8 start may give you a error code. Or a 8 plus stop button.<br /> If the machine has a C4 code, this may require machine software to be installed on the machine in order to correct problems. The scanner will not operate correctly even with a new scanner. The software needs to be installed by the service representative in order to align the correct software to main board, to correct laser heas assay.<br /> Good luck.<!-- from fixya rte -->
    Jun 18, 2009 | Xerox WorkCentre Pro 416 All-In-One Laser...
    Pretty much yes. That message is that the Polygon mirror, is not spinning. That is the motor/mirror assembly inside the laser unit. There is a slight chance it is just sticky, but that motor failure is not uncommon at all in that product.
    You can try going on google and searching a business called " the parts drop" and call, ask for Britt. There are 2 different lasr units for that machine, simply called a large and small laser unit.
    Aug 22, 2008 | Xerox WorkCentre Pro 416 All-In-One Laser...
  • Feb 18, 2008 | Xerox WorkCentre Pro 416 All-In-One Laser...
    Xerox 416 Fuser
    Is it getting thru the "pinch of the fuser and catching on the stripper fingers? If so clean the fingers, ensure they are not worn or tips broken.(Running sheets with dark lead edge can cause sheets to stick to rollers,try running blank sheets to clean up, if they get thru then try normal copies)
    If the sheet stops before entering the rolls more likely to be dirty entry chute, drive problem or sensor problem....need more detail
    Jan 25, 2008 | Office Equipment & Supplies
    Xerox WorkCentre Pro 416 All-In-One Laser Printer Logo
    181 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
