Question about Lakewood Oil-Filled Electric Radiator Heater
KSD301 replacement part KSD301
    New Friend:
Try Grainger - snap disc controls.
Also, see my post, in response to "The heater does not work when switched on I have", under this same topic, 'Problem with: Lakewood Oil-Filled Electric Radiator Heater'.
Posted on Nov 28, 2012
Heating element KSD301-D. 250V. 140
Any appliance parts store in your area can order it if it's not in stock.
Jan 22, 2017 | Washing Machines
Purchased focus sport 2006 model no service manual. Mileage 43,000 kms. Need to know service intervals either time/mileage perhaps a copy of the service schedule will suffice.
These maintenance intervals come from the maintenance interval calculator
at www.autozone.com, using a starting point of 25,800 miles (43000 km), and
assuming 1000 miles (1666 km) driven per month, and "severe driving conditions," which
are actually normal usage characteristics, such as frequent short trips, urban driving, waiting in traffic, driving in hot weather, trips under 16 km in cold weather, etc.
STARTING MILEAGE: 25800 (43,000 Kilometers)
Item
Action
Service History
20000 miles or 32000 kilometers
Battery Check
Oil Filter, Engine Replace
Engine Oil Replace
Vehicle Inspect
Brakes and Traction Control Inspect
Tires Rotate
21000 miles or 33600 kilometers
Steering and Suspension Lubricate
Engine Oil Replace
24000 miles or 38400 kilometers
Engine Oil Replace
25000 miles or 40000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
27000 miles or 43200 kilometers
Engine Oil Replace
30000 miles or 48000 kilometers
Battery Check
Air Filter Element Check
Wheel Bearing Lubricate
Fuel Filter Replace
Engine Oil Replace
Fluid - A/T Replace
Cabin Air Filter Replace
Vehicle Inspect
Cooling System Inspect
Wheel Bearing Inspect
Ball Joint Inspect
Drive/Propeller Shaft Inspect
Exhaust System Inspect
Steering and Suspension Inspect
Heat Shield, Exhaust Inspect
Tires Rotate
33000 miles or 52800 kilometers
Engine Oil Replace
35000 miles or 56000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
36000 miles or 57600 kilometers
Engine Oil Replace
39000 miles or 62400 kilometers
Engine Oil Replace
40000 miles or 64000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
42000 miles or 67200 kilometers
Engine Oil Replace
45000 miles or 72000 kilometers
Battery Check
Fuel Filter Replace
Engine Oil Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
48000 miles or 76800 kilometers
Engine Oil Replace
50000 miles or 80000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
51000 miles or 81600 kilometers
Engine Oil Replace
54000 miles or 86400 kilometers
Engine Oil Replace
55000 miles or 88000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
57000 miles or 91200 kilometers
Engine Oil Replace
60000 miles or 96000 kilometers
Battery Check
Fuel Filter Replace
Spark Plug Replace
Fluid Filter - A/T Replace
Engine Oil Replace
Fluid - A/T Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
63000 miles or 100800 kilometers
Engine Oil Replace
65000 miles or 104000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
66000 miles or 105600 kilometers
Engine Oil Replace
69000 miles or 110400 kilometers
Engine Oil Replace
70000 miles or 112000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
72000 miles or 115200 kilometers
Engine Oil Replace
75000 miles or 120000 kilometers
Battery Check
Fuel Filter Replace
Engine Oil Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
78000 miles or 124800 kilometers
Engine Oil Replace
80000 miles or 128000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
And you can continue the pattern from there...
May 14, 2011 | Ford Focus Cars & Trucks
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 18, 2009 | Ovens
I have a Lakewood mdl 5600/7 oil heater. Love it. It seems to have given up. I unplugged it for a while, relocated to different power source, still no lights or anything else. Internal fuse? If so, where?
I had the exact same problem and I took the front panel off and found the bottom thermostat was burned up when I bipassed it the heater worked so I know this is the problem. Its the small thermostat attached with two small screwes to the heater. It is a KSD301 16amp 125volt 160degree themostat but I am having trouble locating one. They seem to be chinese made and mostly have to be ordered in bulk. When/if I find one I will post again
Dec 13, 2009 | Lakewood Oil-Filled Electric Radiator...
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The Pelonis oil filled radiator heater does turn on
visit this page for parts:http://www.lakewoodeng.com/html/parts.html
Mar 13, 2009 | Lakewood (5500) Oil Filled Radiator Heater
I need a part
For replacement parts on LC Penney Cooks merchandise, please call 1-800-933-7115.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 22, 2008 | Microwave Ovens
Lakewood Oil-Filled Electric Radiator Heater Logo
393 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
