Question about Dishwashers
Teka DW7 59 F1 dishwasher bottom spinner arm not spinning have replaced arm but made no difference top arm /top section of dishwasher working fine
Bottom section of dishwasher not working. spinner arm not moving have replaced arm made no difference. top half working fine.
SOURCE: Kenmore Ultra Wash Dishwasher
Thank you Catriver! You were in the zone! It's working like new! Many thanks!
Posted on Apr 02, 2007
  • 1462 Answers
SOURCE: I replaced the spray arm seal, but the arm still wont spin.
arms should turn freely. spray arms are only rotated by water spraying out from angled jets at end. check for blockage in spray arms - sweet corn and rice are the worst offenders. take spray arms off and run water in centre hole and see it runs out of all the jets freely
Posted on Apr 08, 2007
catriver
  • 878 Answers
SOURCE: small plastic top and mid spray arm do not turn, bottom does
decrete, you want to get down to the chopper and screen. If the screen is plugged up with gunk there won't be enough pressure to reach the top spray arms. Check out the posted pics. Remove the lower spray arm. Rotate the rear feed arm to the right until it unsnaps from the tube going up the back. See the 4 torq screws holding the filter on. Remove them. Lift the filter up. Now you will see the chopper inlet cover. 1 torq screw holding it in. Lift it up and there's the chopper and screen. Catriver..post back
Posted on Apr 09, 2007
  • 1462 Answers
SOURCE: bottom wash arm
there is a blockage but may not be obvious. arm turns only by water spraying out of the angled jets at the end of the arm. take arm off, run water thro the centre hole and this is udually enough to force the debris to the jets. clean out and check
Posted on Jul 09, 2007
jsrock516
  • 5911 Answers
SOURCE: maytag jet clean dishwasher model# dwc7400aaw
Normally when you have low water pressure and/or cleaning issues, this an indication of a clog in your main wash pump. You will need to remove the lower spray arm and the coarse screen to get to the main wash pump sump. Inspect the impeller area of the pump. This area is usually where accumulations of debris collect and keep the pump from pulling enough water. Things like orange seeds, lemon seeds, bottle cap liners, chicken bones, and jar labels are just a few of the items I have personally found. Although, dishwashers do a good job at removing most food particles, they are not garbage disposals. I bet you will find a clog in the sump somewhere. Let me know if this helps.
Posted on Jul 31, 2007
You wil have to excuse my lack of knowledge. I am not getting an error code so I don't know what the problem is. The washer has 3 spinners. The top and bottom spinner are spraying water fine, the middle...
Take out the top rack and inspect the pipe nipple that the rack slides onto. Make sure that there isn't any debris stuck in it. Next pull the wash arm in question off (it just pulls off) check for debris (toothpicks are the biggest culprits and food particles (sometimes glass so be careful). You should find something in there. The wash pipe goes from the bottom to the top of the unit, if the bottom one works and the top one works then your clog HAS to be in the middle wash arm. The water clearly makes from point A to point C so C has to have an obstruction or the wash arm is sticking and not spinning freely. Try to spin it my have but really inspect it for debris. Good Luck.
Feb 15, 2011 | Samsung DMR57LF Builtin Dishwasher
Whirlpool Gold Dishwasher - GU2700XTSB The top rack of the dishwasher is not cleaning. The bottom rack dishes clean fine. There are no clogs in either the bottom or top spinner arms, the plastic tube...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Jan 20, 2011 | Whirlpool GU2700XTSB / GU2700XTSQ /...
The top water spinner arm fell off, how to get it
This just happened to me. The spinner arm fell off. It left behind two pieces of plastic attached to the roof of the machine: a grey sunburst shape, and within that, a white circle with two prongs. It looks like the spinner arm should snap onto the white circle with prongs . . . but you can't just press it back on, because there is no resistance on the other side and the white circle just becomes displaced instead of snapping together.
But the good news is that the grey sunburst screws on and off! Unscrew it until it comes free from the roof of your machine. Now snap the white circle and the spinner arm together, with the grey sunburst between them. Give it a test spin to make sure it's all together and working, and then screw the whole assembly back onto the roof of your dishwasher.
Apologies for the lack of pictures . . . this must sound crazy to anyone who's not looking at what I'm looking at--but it worked!
Feb 25, 2010 | Frigidaire PLD2855RFC Dishwasher
Top Wash Arm not Spinning
water is not circlating, you need a circulation pump
Feb 24, 2010 | Bosch 24 in. SHV55M03GB Built-In...
Whirlpool dishwasher top spinner and top rack spinner is not putting out water or very little and not spinning. I have taken apart and cleaned everything including the sump / chopper, can't find any...
First, confirm that the holes are not blocked on these arms. (I did not want to assume you have done this.)
Then check the impeller on top of the motor stem for being loose or worn/damaged - to rule the impeller out. If it is fine, then the motor is failing and too weak to drive the spray arms.
To answer your question, I think the answer is "They don't make them like they used too!"
Sep 12, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Clean on bottom rack but dirty on top
Clean the filter at the bottom of the tub. If it is dirty or clogged the water pressure may not be strong enough to spin the top arm. Make sure also the there is nothing blocking the holes of the spinner arm. If the filter and arm are clear then the pump may be failing.
Aug 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Top sprayer wont spin . dishwasher goes through cycles and only partially cleans. bottom sprayer does spin.
The sprayers are not powered but rely on the water pressure to spin them. If it's not spinning it could be
the spinner isn't engaging in the top rack as you slide it in
blocked jets on the spray arm
blocked feedpipe to the spray arm
faulty pump
Most dishwashers are fairly easy to dismantle to check the first few
Jul 02, 2009 | Maytag Dishwashers
Wash Arms not spinning --Dishes not clean
Without the model number of your Maytag number, I can not determine if when you order a wash pump motor you also get the impeller.
Sounds like you are on the right path to getting your dishwasher to wash dishes again.
Oh, while you have the dishwasher open, check that the heating element has not failed using a Multimeter.
Good Luck!
Feb 01, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Model 665 16874
removed and disassembled inlet water valve - minature basket filter was clogged with white particulate which felt gritty.  cleaned and reassembled and reinstalled.  Works fine now.  Idiot repairman never mentioned a filter but wanted to replace entire valve at cost of 140 dollars including service call.   sears sux bigtime. And, from my experience with Fixya, so does your service since I never heard a thing since July EXCEPT for an offer to upgrade.  Thanks for nothing.
Jul 11, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher
  This dishwasher does not feed water to top and bottom arms at same time.  It starts with bottom and then after awhile it switches to top and then cycles.  If water comes out arms but arms won't turn,  check all holes in arms.  It's the water spraying out these that causes arms to turn.   If arms spin freely by hand,  it's a plugged arm or holes in arm or insufficient water in tank.
  Being that it only sprays 4 inches suggests a water level problem or possible mineral build up restricting flow.
Oct 11, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Dishwashers Logo
23 people viewed this question
Top Dishwashers Experts
Owen Barnes
