SOURCE: Directv Tivo recorder no remote programming code for Visio 37''
If it were a Tivo series 3 you might have better luck with it.
http://www.tivo.com/setupandsupport/technicalsupport/compatibilityhelp/Using_the_Learning_Feature_of_the_TiVo_Glo_or_Series3_Remote.html
I've had my series 2 Tivo for about 2 1/2 years and never found the correct codes for it. I think it works off of a list of TVs manufactures about 3 years ago.
SOURCE: I have a 37
U-verse remote control code 1004 provided the support I needed for my Visio VO37LHDTV10A 37 in. LCD TV
SOURCE: Code for digital remote control on Visio L15
Go here and click on the question about remote codes (they give several three, four, and five digit codes): http://www.vizio.com/FAQ.aspx#
SOURCE: visio tv model 42L
SUPER EASY!
The IR sensor is only about 1"x1" and is held by a single screw.
First, you must popped off the back cover (probably 25 screws)
Then the IR sensor will be in the bottom lower corner.
Un-do the screw, unplug the IR sensor, put in your new IR sensor and you're back running!
Hope this helped! It's an easy fix! please rate!
