Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
My pc does not see my printer but my copierand scanner is ok he
It keeps saying to check the power, but power is ok
  • dougie84 Jan 07, 2009
    Thanks for trying for a solution, after further investigation I found the usb connecter open circuit new cable all ok
    Guru:
  • 829 Answers
Check if the drivers are properly installed
Posted on Jan 06, 2009
HP photosmart all-in-one printer/scanner/copier b110A
Hi
Try disconnecting the printer completely from power and the PC.
Reboot the PC.
Clear any print queues.
Connect everything again and try printing now.
Hope it helps.
Feb 22, 2012 | HP Office Equipment & Supplies
My cannon MG5220 printer will not scan but prints fine. i keep getting an error that says "cannot communicate with scanner for these reasons: -scanner is turned off. -scanner is disconnected (It is...
Many printers will not scan over a network, even when they are supposed to. Try connect to it with a standard USB cable and scan to PC directly. If that doesn't work - you have probably got a faulty scanner.
If the scanner works OK directly to a printer, then your issue is either LAN/WLAN bandwidth or an unstable IP address. Try fixing the IP Address rather than running DHCP address allocation eg set it at 192.168.x.150 where x is the range value for your network. Then set the printer port address on your devices to the same values and try again.
Nov 27, 2017 | Canon PIXMA MX870 Wireless Office...
Replacing HP 7580 all in one scanner fax with HP 7590 all in one scanner fax. I did not have install CD for 7590 so downloaded drivers from HP site. Error message keeps saying that does not recognize...
first Step - Try another USB Cable.. If this does not solve, try the steps below.
Power off the Printer
Disconnect the USB Cable from Printer to PC ( from PC )
Disconnect the power cord of printer frmo wall outlet
Power off the PC
Disconnect the Power cable from back of PC and from wall outlet as well
wait for 10 minutes
Connect the PC power cables to PC and Turn on the PC
When you login to your Desktop, Turn on the Printer
Connect the Cable,
It should get recognised.
Regards,
Ron
Feb 22, 2011 | HP Computers & Internet
I have problem with my scanner. when I want scan whith that show this message: cannot communicate with scanner cable may be disconnected or scanner may be turn off.check status.scanner driver will be...
Ok but its saying to check your usb cable and you need to check if both the pc and this scanner is plugged in with this usb cable and that the scanner has it's power plugged in too.
It could also mean that you did not properly install the drive or the drive is old and you need to replace it or update it.
Please let me know what happens after ok?
Mar 05, 2010 | Canon PIXMA MP160 All-In-One InkJet...
HP Officejet Pro L7500 - printer installation ok, fax installation ok, but scanner driver does not work
This must be scanner driver not communicating with the hardware.Try the following steps and i'm sure it will work.
1.Click start - >run then type "twain_32" click OK.
2.A window will open and click EDIT menu-> select all, then delete all the files and folders.
3.Click start - >run then type "services.msc" click OK.
4.Look for service called "HPZ PML Driver", Doubled click on it, check whether the "startup type" is "Automatic", if not changed it to automatic.Checked the "Service status" is "started".If not click on "start" button.Click Apply and OK.
5.Right click on "HPZ PML Driver" and click "Restart".Close the window.Click start - >run then type "%temp%"(without quotes) click OK. A window will open and click EDIT menu-> select all, then delete all the files and folders.If u cant delete them its ok, just close the window and go to step 6.
6.Disconnect the Printer USB cable, Insert the
installation disk of your printer.If Installation wizard
pops up, click on cancel/exit.
7.open My Computer, right click on your CD/DVD ROM Drive , then click "open".Look for folder called "UTIL" then look for folder called "CCC".There you will see a file that says "Uninstall_4". Double click on that file.
8.A run box will poppup, click OK, now you will see the command windows, hit enter the Driver that is necessary for comunication which are corrupted will be removed.
9.After that, restart the PC and Insert the Disk and
install the printer.Connect the Printer USB only if the PC prompts you to connect.After installaton completes, check the scanner.
Please let me know, once you have done this
Thanks
Rizwan
rizwan84tx@gmail.com
Dec 08, 2008 | HP Officejet Pro L7680 All-In-One Printer
Printing problems
offline means it cannot detect the presence of the printer, though virtually present, check the ff
1- cable are intact, USB or Parallel to PC
2- power line, light on the printer itself
if ok, then reset all queued jobs and restart the PC once again
dont forget to mark my suggestion pls
Jul 31, 2008 | HP PSC 1315 All-In-One InkJet Printer
Not responding to PC instructions to print data
You need to load the PRINTED ALIGNMENT PAGE on the scanner glass, then press on "OK" button. It should start scanning the alignment page. That way, you are completing the PROCESS of ALIGNMENT.
Thank you so much.
adonscott
Jul 01, 2008 | HP PSC 1315 All-In-One InkJet Printer
I need to scan a document and save it to my computer... but the printer/fax/scan just says "scan mode" and doesn't do anything. It uses a creative array of beeps when I press the buttons (OK,...
You need to check compatiblity issues between your scanner and your PC install or reinstall the scanner to your pc may answer driver issues that may be causing your problem check manuals
May 31, 2008 | Office Equipment & Supplies
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
18 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
