posted by crayv on May 22, 2007
I have a Kitchnaid Superba KSRS25QDWH01, and the ice maker is not working properly. The water line in the freezer puts out too much water , causing the ice tray to overflow and spill out into the freezer. Also, the tray, once filled and frozen, does not dump into the bin (ie the rotator does not drop the ice into the bin). Any suggestions. Thanks.
Solution #1
posted on Dec 19, 2007
If you pop the front cover off the ice maker you will find a screw with a plus and minus on it. Adjust it and that will cut the water fill down and should solve the overfill problem.If the ice is not dumping spray the tray with Pam and that should solve the dump problem.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for KitchenAid Superba Architect
Email this problem
Email this problem
Can you Help with these Refrigerators problems?
KitchenAid Superba Architect KSCS25INSS Side...
overactive ice maker
the wire that triggers the ice... Answer This...
WATER FILTER LEAKS
WATER FILTER LEAKS
water leaks from the water... Answer This...
Ice dispenser and water filter
Ice dispenser stopped working... Answer This...
water filter location
where is the water filter... Answer This...
ice maker kitchenaid
ice maker stopped working.... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
Find Parts
