Question about Keurig B60 Coffee Maker
Not ready fill water - Keurig B60 Coffee Maker
  • 1,238 Answers
Try to check the floating magnet on reservoir tank.
Posted on Nov 08, 2012
What can I do to have the Ready to Brew light come on? I tried to slowly pour in water and fill water tank but doesnt work.
Be sure spray disk and brew gasket are properly installed in the
brew head.
Be sure the water supply is properly connected and the water
supply valve is turned
ON
Be sure the WATER TANK IS FILLED
BEFORE plugging the brewer into a receptacle, or otherwise
connecting brewer to electrical power
THE WATER TANK MUST BE FILLED
Place an empty decanter under the brew head. Lift
the pour-over cover then pour warm tap water into the pour-over
opening until water flows from the brew head. When water stops
dripping from the brew head, empty the container.
Once the tank is full of water,
connect the brewer to electrical
power. The heating elements will begin heating the water in the
tank.
When the water has reached the proper temperature, the
"READY To BREW" light will glow. http://www.cdccoffee.com/pdf/bloomfield-8571-8572-user-manual.pdf
May 12, 2015 | Bloomfield 8571 Coffee Maker
I need to know why the Hoover Max Extreme keeps telling me t check the tank?
Hi! The solution and water goes in the top tank. Dirty water is suctioned into the bottom tank as you're scrubbing your floors. To fill the clean water tank, remove the clean water tank cap. The cap serves as a measuring cap for the solution. Fill the cap with Hoover carpet washer solution to the fill line. Pour detergent into tank. Fill the rest of the clean water tank with hot tap water and twist the cap back on. You are now ready to clean. Hope this helps!
Aug 20, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Keurig b31 mini. Power light on, brew light not on
Water reservoir may not be seated properly or filled above the Max line. Did you do a purge and establish filling the hot water reservoir?
Feb 08, 2013 | Keurig B30 Mini Coffee Maker
Just bought a Bunn coffee maker at a garage sale great condition how do you make the coffee I have poured water in turned the side switch on and the warmer switch yet nothing?????
The machine requires an initial set up to be completed before using it. Fill the decanter with cold water and close the lid. It will take 3 minutes to partially fill the water tank in the back. Then fill the decanter again with cold water and pour in and close the lid. Then plug in the machine and turn the vacation switch on the side of the machine on. After 15 minutes, you will be ready to brew coffee. Then you will get your filter basket ready with the filter and grounds. Pour in from 4-10 cups of water and place the decanter on the base. Close the lid and the coffee will begin to brew. If you will call customer service with the model and date code, a use and care manual can be sent out to you at no cost.
Sep 06, 2009 | Bunn NHB Coffee Maker
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
"Fill water tank" prompt
Make sure the magnet in the water tank flow up when you fill it with water.
Best regards
/Mirran
Oct 26, 2008 | Saeco Vienna SuperAutomatica Coffee...
Nespresso Magimix M300 'Fill Water'
it just means that the pump needs primed. Turn on at the wall and on the machine, wait until screen says ready (make sure water tank full), then turn steam handle on RHS to on (do not push the steam button). the pump will prime until water comes out of the steam nozzle. now turn off the steam handle and you are ready to go!
Sep 16, 2007 | Coffee Makers & Espresso Machines
Keurig B60 Coffee Maker Logo
14 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
