Vokera 28se new. boiler fires up. water heats when called for but heating will not fire up. green light flashing no red light. wireless rf room thermostat fitted
Heating does fire up for about 20 seconds then shus down ./ any ideas
SOURCE: vokera combi boiler
air in system
Posted on Aug 11, 2008
johnsonr1
  • 91 Answers
SOURCE: CM67NG Programmable Thermostat-
Here is a link to the manual for your thermostat:
http://www.bvt.org.uk/shropshire/pdf/usermanuals/HoneywellCM67.pdf
Posted on Nov 04, 2009
  • 2557 Answers
SOURCE: Honeywell ST6400C programmer
Hi yes sound like it not working on hot water only it would check ou the wiring on this side
Posted on Feb 18, 2010
  • 2557 Answers
SOURCE: about a month ago red light was coming on my
Hi check ther pump is not stuck it will be hot to touch
Posted on Mar 02, 2010
SOURCE: My vokera linea ag plus domestic hot water cycles
I have the same problems, did you manage to get it fixed and what was wrong?
Posted on Mar 08, 2010
Boiler ries to fire on heating or hot water but then shuts down after 10 seconds to F1 with the flashing red light, any ideas. clearly same principle as any boiler but I'm looking for someone who has...
that would indicate that the boiler is not firing up
If oil fired, been there done that
it is out of oil
the oil filter is clogged
the nozzle could be clogged/burned
the igniter wires need adj/replacement
if gas fired - similar issues but no experience
Dec 08, 2014 | Water Water Heaters
Vokera boiler problems
need to change thermostat and a thermocouple
Jan 28, 2014 | Water Heaters
MY VOKERA BOILER IS NOT WORKING I HAVE NO HOT WATER AND NO HEATING
try check in the water pressure on the boiler should be on 1.5 bar
Jun 01, 2010 | Heating & Cooling
I have a vokera unica 28 which pulses when firing
your fan may need attension fan runs after boiler shuts down is normal on some Vokera,s too clear fumes out the flue 2mins approx
Oct 04, 2009 | Water Heaters
No heating and no hot water, my boiler won't fire up
If there is a hi-limit switch, maybe it's open, reset the switch, and monitor the temperature, if the temp. increases over the set temp. replace stat, and clean lime off from the tank, if does not have a filtering system
Apr 21, 2009 | Heating & Cooling
Fault light flashing 1 flash per second
Prior to writing the above fault I had asked the owner to turn the boiler temp controller , for the heating side, down just a fraction . I was phoned this morning to tell me that the boiler had stayed on allnight with no fault light . After consulting with the plumber who fitted the system it appears that there might not be a room stat ,
Nov 30, 2008 | Bosch Water Heaters
My Vokera Maxin 24e keeps tripping out
my vokera maxin 24e. it works for a while.. if i leave it on a timer its as if it cuts out and the red light on the front of the boiler goes on. i can press it and fire my boiler back up but not always its as if it heats up. obviusly a safety measure. any idea what part/parts i need to fix it??? help anyone
Nov 09, 2008 | Heating & Cooling
My Worcester Bosch 35cdi boiler is flashing temp then backwards t forwards t, whats wrong with it.?
35 cdi worcester combi about 3 years old,heating not working,hot water works fine.It's been serviced not long ago.Room stat turned up and trv's ,but boiler want fire up,there's power to the boiler and the room stat the built in time clock is switched to on, but still nothing. do you think it could be the diverter valve, when i got there it was flashing SE which mean's it needs a service,cleaned the heat exchanger and burner with the proper worceter brush etc then re set boiler with technical, they also said it could be the built in clock and told me to disconect it, and just use the heating stat to control it.It still want fire.
Sep 03, 2008 | Heating & Cooling
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
