Question about Acer Aspire Computers & Internet
Aspire Aspire SA10 is shutting off abruptly. I have to remove the power cord for 5sc then plug it back in, but this cant be good, help please
  • Acer Master
  • 32,281 Answers
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Posted on Nov 08, 2012
itszspot
  • 4 Answers
SOURCE: dell latitude d600 doesn't turn on
The test Dell advises to narrow down this issue is to remove the battery, hard drive, ram, and optical drive.  Next plug in the a/c power cord and you should get some LED's coming on. If not it points to the motherboard.
Posted on Aug 16, 2008
levetate
  • 10 Answers
SOURCE: Shuts down abruptly after starting
you mention that the power just dies,there is a fault with the Acer aspire 5630,when i opened up the system,i noticed that the dc port at the back of the system was a little loose,the terminals were loose,and it was not charging or powering up,the reason why this is happening on most laptops is because the dc jack that plugs into the dc port on your laptop is heavy,and it tugs at the port,if they made the jacks lighter for the ports,it would not be a problem,i have hard wired a mobile pord and took out the old one and fixed the problem,the problem i find with manufacturers is that they dont design laptops that well,the design them to break down,so people like me are always finding new ways to make them function longer,get some one to have a look at it,it could be that,maybe you have a old batery?
Posted on Nov 11, 2008
SOURCE: my acer aspire 5810tz can not be started in
how old this battary ?
Posted on Mar 06, 2010
ginko
  • 19396 Answers
Hi.
The problem is likely a dead battery.The best way to test the battery is by fitting in a replacement battery. Battery can also be tested using a multimeter on Amps, this will not tell you if the battery is holding charge.
In some case the problem is not the battery, but wiring to the battery.
Laptops also have an internal battery power charger circuit, that can be integrated on main board or on a separate board.
As said, the most common failure is the battery itself.
Regards.
Ginko.
Posted on May 19, 2010
Testimonial: "Thanks a lot. It was really helpful but the laptop is a new one and was working normally untill it went off last week when it was fully charged and the charger was removed. "
duane_wong
  • 6826 Answers
SOURCE: Power problem
Press the power button and if it goes on keep pressing the button until it shuts off. Then try to power it up by tapping the power button once.
How have you tested the battery? In my Acer laptop I'm on my third one in 2 years and recently got a 9 cell high capacity one that lasts 3.5 to 4 hours when my original lasted only 1 or 2 hours tops.
Posted on Jul 22, 2010
ACER ASPIRE ONE
Unplug the computer, hold the power button down until the laptop shuts down, then remove the battery. Plug in the charger, and try powering up. If all is okay, shut it back down, unplug it, and reinstall the battery. Then, plug it in and let it fully charge. Restart it, plugged in and with the battery installed. Good luck.
Apr 06, 2014 | Acer Aspire One PC Notebook
I have an acer aspire 5734z-4836 is is plugged in but says not charging. also if i unplug the power cord from the computer it shuts off.
Remove your battery pack, and plug in the live power source, and switch on your laptop, just to test if the if your laptop turn on. If it does, your battery had reached end life usage, so you need to replace the battery pack.
Hope it helps.
Jun 30, 2011 | Acer Aspire 5520-5908 Notebook
I have an Acer Aspire One. The screen says it is "configuring Windows updates 30% complete". It has been like this for hours and I can't turn it off or go to another screen. What should I do?
hi
well i guess by now that the acer has run outta of battery if you still cant stop it manualy then i would unplug the electric power cord and let the battery run out and then the laptop would shut down
and when this happens plug the power cord back in to recharge the laptop and switch back on and hopefully windows will sort it out
if it dosent then i would be tempted to do a system restore back to before the updates and try the updates again
Jan 30, 2011 | Acer Aspire One PC Notebook
My acer aspire one labtop is show only power light not show screen help me what i do
First thing to try would be to unplug the power cord and then remove battery. Then put just power plug back in and see if the computer comes up correctly. If it does then shut it back off and put the battery back in and that should fix it.
If not, after you have tried the above, repost.
Jan 19, 2010 | Acer Aspire One PC Notebook
Acer Aspire SA10 Display Issue
Get an update for your video card's driver.
Jan 18, 2010 | Acer Aspire SA20 PC Desktop
My acer 4520 laptop shuts off while using it. why? cant seem to complete any task without powering it back on.
This may sound stupid, but it could be as simple as your battery being low. If the battery is charged and it is still shutting off on you, the battery may need to be replaced.
One way to verify this would be to remove the battery, and plug the computer into the AC Adapter and see if it runs properly.
If it works fine, then you know that there's a problem with the battery. If not, then it may be something more serious like a motherboard issue. If it gets to that point, I suggest you take it somewhere that it can be physically looked at.
Hope this helped :)
Nov 29, 2009 | Acer Aspire 4520-5582 Notebook
The exact same thing is happening to mine.
have a computer tech analyze the problem.
Jul 14, 2009 | Acer Aspire 5920-6727 Notebook
Cant power up acer aspire 3690 laptop
did you try booting with just the power cord in (battery and all other devices disconnected) if it boots then put in battery and make sure its charged. then try the video recorder wit out any other devices connected
Dec 25, 2008 | Acer Aspire 3690-2196 Notebook
Nov 09, 2008 | Acer Aspire 5630 Notebook
Computers & Internet Logo
149 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
