Question about Brother MFC9320CW All-In-One Printer
Brother mfc 9320cw poor print quality - Brother MFC9320CW All-In-One Printer
Mix-it-up
  • 832 Answers
SOURCE: Brother MFC-440CN won't print color
Did you use generic carts?
Do use only original brother ink carts!
Only these have special cleaning fluids mingled with the ink.
There are several advantages, too:
You can run a special cleaning mode (DO insert original carts at first!!!)
Press menue then start bk copy then fourtimes arrow-up.
machine should switch to maintenance mode (buttons will flash).
press 7 then 6 then 4 then start bk copy. machine will refresh ink within the tubes and the print head and run a special cleaning routine. when finished press 7 then 6 then 3 then start bk copy to run a power cleaning. leave the maintenance mode by pressing 9 then 9.
The machine should print without proböems. If there is a poor quality left, the printhead is affected by bad ink and cant be fixed anymore.
Posted on Jan 25, 2008
  • 265 Answers
SOURCE: How to clean the print head - Brother MFC-685CW Inkjet Printer?
Replace the printhead !
Posted on Dec 11, 2009
alphacheese
  • 68 Answers
SOURCE: BROTHER MFC-210 PRINTING IN BLACK INK POOR QUALITY
Try cleaning the black printer heads several times in a row, at least 5 times then print a black document with best quality setting.
Press the ink button, then down to select select cleaning and then press menu/set and menu/set again to select black.
Posted on Jan 08, 2010
pineworks
  • 4041 Answers
SOURCE: Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
pineworks
  • 4041 Answers
SOURCE: Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Posted on Mar 02, 2010
What are brother printers that take tn210 cartridges
Brother color machines use it:
Brother DCP Series: DCP-9010CN,
Brother HL Series: HL-3040CN, HL-3045CN, HL-3070CW, HL-3075CW,
Brother MFC Series: MFC-9010CN, MFC-9120CN, MFC-9125CN, MFC-9320CN, MFC-9320CW, MFC-9325CW
BR
Sep 29, 2017 | Brother Office Equipment & Supplies
Bad copy quality, prints are good
Could be a faulty optical sensor or crud on the glass?
Jul 24, 2014 | Brother MFC-9840CDW Laser Printer
Brother MFC-9320CW is printing blurred images
Click menu once and OK 3 times and reply the status of the test print
Oct 15, 2013 | Lexmark X7170 All-In-One InkJet Printer
Scan problem
What is it scaner or paper problem?
If it is a paper problem take out all of the paper and return few pages in the tray. Try and print out something.
But I still thing that you will have trouble.
If the things I tell you don\'t wotk you may have to change a spear part like drum unit or a toner cartridge.
Sometimes if the drum unit is at it\'s life end you may experiance this problem.
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
Faded printing issues with Brother MFC-9320
Try cleaning the corona wire on each toner cartridge. This may help solve your solution.
If this does not help try another thing.
Try and replace the toner cartridge. Maybe your toner cartridge needs to be replaced. Usualy when printed images are light or pale a toner cartridge replacement is recommended.
To see how to replace your toner cartridges check here
We have a Brother mfc-9320cw printer that is printing with a thick and ugly crust of ink on the right edge of every 8.5x11" sheet we print. What is causing this? We've replaced the belt. It...
This happened to mine, only my thick edge was blue. My problem was that the little green slider that cleans the wire on the toner holder was pushed to the wrong side. (Sorry, can't remember technical term for the green thing or the wire! It has an arrow on it and it's pretty easy to spot.) Push it all the way back to the left until it clicks and it should fix the problem.
May 25, 2011 | Brother MFC9320CW All-In-One Printer
Black lines when printing brother 9320cw
Vertical black lines means the printer requires maintenance or a new drum. Horizontal lines means a circuit board with problems.
I do recommend maintenance every 6 months at least.
I hope this helps.
Nov 23, 2010 | Brother MFC9320CW All-In-One Printer
Brother MFC-5890CN Printer
It sounds like your print heads may need cleaning. However, here is the link from Brother support for your MFC-5890CN on how to improve print quality:
Brother MFC 5890 Print Quality
Jan 14, 2010 | Brother MFC-5890CN All-In-One InkJet...
Brother MFC9320CW All-In-One Printer Logo
91 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
