Question about Pentair 2.0 Hp Whisperflo Pump
If I open my whisperflow pump, so I have to replace the seals
    Top Expert:
  • Pentair Master
  • 6,889 Answers
If seals leaking probably ruining bearings replace whole unit less headaches
Posted on Jun 07, 2016
2 Suggested Answers
  • 366 Answers
SOURCE: 1hp whisperflow pump, seal change. How?
Make sure breaker/power to pump is off. Remove the six bolts holding the wet end to the seal plate. Remove the diffuser to expose the impeller. Remove the screw in the middle of the impeller by turning clockwise (left hand threads). Remove the dust cap at the rear of the motor and use a wrench to hold the shaft while you remove the impeller by turning counterclockwise. Once the impeller is off, remove the four bolts holding the seal plate to the motor. Press the old seal out of the seal plate and clean it thoroughly. Remove the ceramic part of the seal from the impeller and clean it thoroughly as well. Apply a thin coat of lube to the seal plate and impeller where the new seal will go. Remove the new PS1000 shaft seal from the box (being careful not to touch the ceramic or carbon face with your fingers), press the metal part into the seal plate carefully, try not to bend the metal and make sure its completely seated against the seal plate. You can now install the seal plate back onto the motor and secure with four bolts. Press the ceramic part into the impeller, use cardboard or paper between your fingers and the ceramic face. Once you have seated the seal into the impeller, hold the motor shaft and thread the impeller on until snug, then reinstall the stainless screw, remember it is left hand thread so you'll have to turn it counterclockwise. Reinstall the diffuser over the impeller and then install the wet end onto the seal plate using the six bolts, don't overtighten them.
It is a good idea to replace the tank o-ring when taking to pump apart, but if the o-rings are in good condition, just apply a light coat of lube and reuse them.
This is a general guide for replacing a seal, if you have trouble removing the impeller, you may need an impeller wrench and a tool to hold the motor shaft.
I hope this helps, if you have any specific questions, email me at mail@leisurepoolservice.com
Posted on Oct 28, 2009
Pump has big air bubbles and vacuum stopped working
check intake union to see if loose or leak if all ok pump seal could be leaking on intake side or could have debris in impeller clean out with a piece of wire
Jun 29, 2012 | Pentair 1.0 Hp Whisperflo Pump
Whisperflow pump making loud squealing noise
The noise is likely either the seal or a bearing in that order. If you are mechanically capable of working on the pump yourself then you can purchase a seal and gaskets at a pool supply store. If the bearings are bad then the motor needs to be replaced. In some cases a bearing can be replaced but usually it is more work than it is worth.
Aug 09, 2011 | Pentair 1 hp WhisperFlo InGround Pool Pump...
Have a pentair 1 HP whisperflow pool pump. It makes a loud high pitch sound when turned on. Sometimes when first turned on it won't but quickly will begin making the loud high pitch sound. Almost...
Are you sure that you have it wired the right way. it has a setting for 220 or 110 the pump will run if it is not wired correctly however it will be varey ******* the brushes inside the motor resulting in a loss of efficiency
May 22, 2011 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
Winding noise with some water leaking from the motor seal. Water still flowing but sounds laborous.
The shaft seal more likely than not needs to be replaced. If your shaft seal has been leaking for any length of time, the bearings could be damaged and this should be replaced. The whisperflow uses a PS1000 shaft seal and is fairly easy to replace (most seals available online or at most swimming pool retail stores). It is best advised not to run the pump until you have had this inspected by a licensed pool technician or have changed out the seal.
1) Make sure breaker/power to pump is off. 2) Remove the six bolts holding the wet end to the seal plate. 3) Remove the diffuser to expose the impeller. 4) Remove the screw in the middle of the impeller by turning clockwise (left hand threads). 5) Remove the dust cap at the rear of the motor and use a wrench to hold the shaft while you remove the impeller by turning counterclockwise. 6) Once the impeller is off, remove the four bolts holding the seal plate to the motor. 7) Press the old seal out of the seal plate and clean it thoroughly. Remove the ceramic part of the seal from the impeller and clean it thoroughly as well. 8) Apply a thin coat of lube (I prefer Magic Lube or Lube Tube) to the seal plate and impeller where the new seal will go. 9) Remove the new PS1000 shaft seal from the box (being careful *NOT* to touch the ceramic or carbon face with your fingers), press the metal part into the seal plate carefully, try not to bend the metal and make sure its completely seated against the seal plate. 10) You can now install the seal plate back onto the motor and secure with four bolts. Press the ceramic part into the impeller, use cardboard or paper between your fingers and the ceramic face. 11) Once you have seated the seal into the impeller, hold the motor shaft and thread the impeller on until snug, then reinstall the stainless screw, remember it is left hand thread so you'll have to turn it counterclockwise. 12) Reinstall the diffuser over the impeller and then install the wet end onto the seal plate using the six bolts, don't overtighten them.
Check the pump for operation and you should be good to go!
Dec 07, 2010 | Pentair 011515 WhisperFlo FullRated Energy...
I have a 2HP Pentair Whisperflow pump that has stopped working after only 2 years. When I turn it on, it just makes a humming noise even though the impeller is free. Any ideas?
Thank you for posting your question here on Fixya.com.
It could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Oct 23, 2010 | Pentair 2hp Whisperflo Pool Pump In -...
Oct 28, 2009 | Pentair Pool & Spa
Onga pool pump running but not drawing water from pool
Take out the pump pot basket and stick your finger in the hole towards the motor (make sure the motor won't kick on!!). What you should feel is the impeller. It has five grooves in the face of it and each one needs to be cleaned of foilage and debris. With every hole clogged in the impeller you lose 20% of your motors effeciency. With whisperflow brand the pump pot basket is poorly designed where debris like pine needles go straight through.
Griffin Pool Services
Las Vegas, NV
Sep 29, 2008 | Pool & Spa
Pentair 2.0 Hp Whisperflo Pump Logo
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
