Question about Ovens
Creda Electric EDO210 and EDO212 oven will not turn on. Red service light on
According to elderly mom, the oven does not turn on to heat. She state that a red light in on in the front of the oven. Neither the top or bottom work.
  • 27 Answers
SOURCE: bottom oven not working
If its brand new, most possibly the electrician did not bridge the mains connection. It sounds like an installation fault. There is usually a jumper between 1-2-3 on the L connection on the mains, and a jumper between 4-5 on the N connection. Oshie
Posted on Jun 26, 2007
catriver
  • 878 Answers
SOURCE: Electric Oven Won't Heat
Rob, sounds like it was just installed. You need 240V on this unit. On the terminal block in back where the power hooks up, it should read 240V across the two outer terminals and 120V from each end to center terminal. Im ruling out the thermal cut out because you never used it. I would start with the power source first. The display sounds like it's getting the 120V it needs to funtion, but I don't think your making the loop for the 240V needed for the bake and broil. Catriver.
Posted on Jul 13, 2007
  • 25 Answers
SOURCE: GLEB27T8ABA Frigedare Double wall oven electric
check the fuse/breaker for the bottom element
Posted on Dec 12, 2007
  • 833 Answers
SOURCE: Re:Electric Convection oven does not heat up. Convection fan works, light works.
It is probably and electrical service issue. If this is a North American unit, it uses two electrical circuits to provide power. You must find and reset the breakers and check that the wiring is operating as intended. Less likely: It could also be a manufacturing defect. DeLonghi uses screw compression connections on some products. Sometimes, they don't work well.
Posted on Dec 21, 2007
barkencoa
  • 3463 Answers
SOURCE: bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Posted on Dec 17, 2008
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
@need user manual for model #EDO210
I found this. You will probably need to call the number in bold. Are you actually in the UK area? That's where Creda came up as.
http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do
Feb 11, 2011 | Creda Ovens
Oven not heating
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 30, 2010 | Creda Europa E010E Electric Single Oven
My c561e creda main oven(fan assited)will not heat up.everything else works
Most likely it is a blown heat element, you could check it if you have a multimeter or continuity tester.
Dec 15, 2010 | Creda Europa E010E Electric Single Oven
Creda Europa Oven an Grill Big oven has Stopped working what would be possible causes
do you mean there isnt any power going to it or it dosent heat up or it just gets warm more detail please
Dec 05, 2010 | Creda Europa E010E Electric Single Oven
Where is the thermostat located in the main oven of my Creda Europa Solar oven. Thanks
Depends which thermostat you are referring to.
Thje main oven stat is on the control panel, and is marked with the temp, the sensor being located at the top rear of the oven compartment.
The other stats are located at the top of the oven outer casing under the the top cover. you need to remove oven from housing to access these.
Oct 29, 2010 | Creda Europa E010E Electric Single Oven
I have a Tecnik TKC 8522 double oven - I can't get the bottom oven to heat up. When you turn it on the fan comes on, but the red light doesn't come on and the oven doesn't heat up.
If the red light does not come on, then this suggests that the oven thermostat or control switch is fault.
Even if the element was faulty, the red light shuld still come on.
Sep 25, 2010 | Tecnik TKC8522 Electric Double Oven
My Creda convection oven does not heat up. The
THIS SOUNDS LIKE THE ELEMENTS HAVE BURNT OUT TO FIX FIRST TURN OFF THE POWER THEN LOCATE THE SCREWS HOLDING THE PANEL INSIDE THE OVEN REMOVE ALL SCREWS AND PANEL THEN REMOVE THE ELEMENT FROM ITS PLUG CONNECTION TAKE THE ELEMENT TO A ELECTRIC AND PLUMMERS SUPPLY STORE REFIT ELEMENT AND YOUR OVEN SHOULD WORK FINE .
Nov 20, 2009 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
