Question about Thermador SC272T Electric Double Oven
Wiring diagram for thermador sc272tw double oven
Wiring diagram
  • 1314 Answers
SOURCE: Thermador Convection Oven
well im not terribly familer with thermadors wiring but pull the top off and find the tech sheet then look for a device call a thermal fuse or tco thermal cut off most times they are on top or on the back of the oven yours should have one for each oven bet the one for the top is open can happen if there installed in to close a space
Posted on Jan 30, 2008
  • 5 Answers
SOURCE: thermador c302 door hinges
487746 is the part number for the 30 inch model and
487747 is the part number for the 27 inch model if this is the parts you recieved then the should fit there should not be much difference
Posted on Jan 15, 2009
  • 8 Answers
SOURCE: Lighting panel in my electric Thermadore double oven is dim.
The cap replacement worked....saving $250 (every 2 years !!!) I posted it on another site...now its making its way around the web....its the only value added thing I've done on the web (sadly!).
Posted on Feb 06, 2009
  • 8 Answers
SOURCE: The LED control panel on my Thermador double oven is out
I solved this. Its a vaccum flourescent display. The voltages that drive it are reducing because the capacitors on the control board deteriorate with temperature. Replace the 3 capacitors and its good as new.mine still working after 2 years...$.20 at radio shack...or have a repair place do it for you...saves $250 for a new board
Posted on Dec 11, 2009
  • 189 Answers
SOURCE: oven takes forever to heat up
Hello- Check these things first-  Door seals tend to get stiff over time. This is normal. Door hinges can become loose or get bent a bit, causing door to not close tight. This little gap can allow heat to escape, causing extended pre-heat times and frequent cycling of elements. If door doesn't seem to pull shut tightly- hinges will need to be replaced. If oven appears to operate normally otherwise, this should solve problem.  Let me know if the info helps- have more if needed- Thanks  - Ed
Posted on Mar 17, 2010
I have Thermador double oven. It wouldn't heat up (top and bottom). I replace Control board and digital display. Now the bottom oven heats up but the top one still not working. Could you pleas
Double check each connector to be sure it is installed (aligned on pins) properly. Also check wiring diagram for a safety limit thermal switch. If it has one, push to reset it.
Jan 16, 2015 | Thermador SC302T Electric Double Oven
Oven doesnt work
yes there is. check the wiring diagram for location. some on top of oven and some on side of unit.
Feb 04, 2014 | Thermador SMW272 Electric Double Oven
Help!!! Need Replacement knob kit for my Thermador double oven!
these are NLA. No Longer Available.
Try to get something that is acceptable to you and fits by researching "oven Knobs" at repair clinic dot com and selecting by looks and size.
Nov 09, 2013 | Thermador SC302T Electric Double Oven
Thermador CM302 f63 error code
overheat situation. check oven sensor and soldered pin points for sensor wires at relay board. Resolder if needed.
Feb 10, 2013 | Thermador C301U Electric Single Oven
CM302US Thermador Double Oven F34/64 Problems need schematic diagrams
air flow/fan issue. either bad fan motor, air flow switch or relay board.
Nov 29, 2012 | Thermador C302U Electric Double Oven
I am getting an F64 on my thermador electric double wall oven after a few minutes of preheating my upper oven, and the oven turns off. What des this mean?
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Jan 05, 2011 | Thermador SEC302 Electric Double Oven
Heating element in upper oven heats to about 300 degrees and temperature will not increase.
That seems to me like it could be an issue with the sensor. Ohm it out. It should be around 1100 ohms if it is any good. Check for shorts from each wire of the oven sensor to ground. I have a manual and a TIP I wrote about these Thermadors.
Thermador 301/302 wall oven repair manual
Sep 28, 2010 | Thermador SC302T Electric Double Oven
Thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from Newark.com. I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
Nov 16, 2008 | Thermador SMW272 Electric Double Oven
Jan 30, 2008 | Thermador SC302T Electric Double Oven
Thermador SC272T Electric Double Oven Logo
73 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
