Question about Marina Aqua-Minder Programmable Digital Thermometer
Aqua minder manual - Marina Aqua-Minder Programmable Digital Thermometer
On 2007 Honda Accord maint. minder, what does code A12 mean?
A13 is broken down to A, 1, and 3.
A means you have to change your oil.
1 means you need your tires rotated.
3 means you need to change your transmission fluid.
Mar 15, 2015 | 2007 Honda Accord 2.4
Turn off minute minder
Hi..
You can turn the minute minder to off on your lg by following these steps.
Go to Menu -> Settings -> Call Settings -> Minute Minder
Tap and Select Minute Minder to off.
Thanks..
Feb 05, 2014 | Cell Phones
2000 Hyundai Elantra will not start. Installed a new battery and will not turn over. Lights do not work as well. The only thing that works when I insert my key is the door dinging. I've had alternator...
Some cars have battery minders that have to be reset once the battery is removed. It is a device that senses low voltage and trips off to try to preserve remaining voltage inorder to start a car whose battery has run almost all the way down. Check your manual ..some minders will reset automatically others have to be manually reset.
Dec 12, 2017 | Cars & Trucks
SVP Aqua Hdv1000 manual
I lost the instruction manual for the AQUA HDV1000, where can I locate one or a copy
Mar 20, 2013 | SVP Aqua HDV1000 Blue Waterproof Digital...
A wrench appears and 34a I don't know what that means and I don't have the manual, it happen two days ago. I put engine oil because it showed 15% oil.
That wrench is a maintenance minder indicator lettting you know that your oil's service life is at 15%, not that the level or amount is low. Have your oil changed and have the maintenance minder light reset.
Aug 24, 2011 | 2005 Honda Odyssey
How to use the 5 button timer
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remianing time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Sep 26, 2009 | Stoves 720EF Electric Double Oven
It beeps when I talk on it
It could be that you have Minute Minder turned on. Go to Settings > Call and check to see if you have 'Min. Minder' turned on.
May 15, 2009 | Xenon XEN 1510T 15.1" Flat Panel LCD...
2005 Honda Odyssey Maintenance Intervals
Maintenance minder is based upon driving conditions and time. Look in your owners manual for a factroy schedule or consult your local dealer/repair shop and request a maintenance interval check list. They will be more than happy to help probably at no charge.
Mar 29, 2009 | 2005 Honda Odyssey
The top and fan oven keep going off because of the timer. I dont know how to get rid of the timer a I never use it. But I donbt want it to cut out th overn which it is doing. Hel,p and info please
There are 5 buttons next to the clock. From left to right they are:-
Minute Minder, Cook Time, Ready Time, Plus and Minus.
It sounds like the timer needs setting back to manual, so to cancel the automatic setting and return to manual operation, press the Cook Time and Ready Time buttons simultaneously.
To cancel any remaining cooking time left on the clock before the alarm sounds, press the Cook Time and Ready Time buttons simultaneously.
If you are interested, to set the time of day, press the Cook Time button and the Ready Time button simultaneously. Then use the Plus and Minus buttons to set the required time.
To set the Minute Minder, press the Minute Minder button, then use the Plus button to set the required time. You can cancel the minute minder at any time by pressing the Minute Minder button and the Minus button until the display returns to 0.00.
To select an alarm tone, press the Minus button to listen to the first tone. Release the Minus button and press it again to listen to the second tone etc. Releasing the Minus button after the tone has sounded will automatically select that tone.
Hope this helps.
Dec 05, 2008 | Stoves 720EF Electric Double Oven
Seat Belt Chime
Belt Minder Deactivating/Activating
Preparation
1. Before deactivating/activating the belt minder, set the parking brake.
Place the transmission range selector lever in P (PARK) (automatic transmission) or the NEUTRAL position (manual transmission).
2. Place the ignition switch in the OFF position.
3. Close all the vehicle doors.
4. Unbuckle the driver safety belt.
5. Place the parking lamps/headlamps switch in the OFF position.
1. Turn the ignition switch to the RUN position. (Do not start the engine.)
2. Wait until the safety belt warning lamp turns off (approximately one to two minutes).
3. NOTE: Steps 3 through 5 must be completed within 60 seconds or the procedure must be repeated.
Buckle then unbuckle the safety belt nine times, ending with the safety belt unbuckled. This portion of the procedure can be done before or during belt minder warning activation.
4. Turn the parking lamps/headlamps ON then OFF.
5. Buckle then unbuckle the safety belt nine times ending with the safety belt unbuckled. After this step the safety belt warning lamp will be illuminated for three seconds.
6. Within seven seconds of the safety belt warning lamp turning off, buckle then unbuckle the safety belt. This will enable the belt minder if disabled or disable the belt minder if enabled.
7. The following sequence of events confirm the belt minder is enabled:
-flashing of the safety belt warning belt lamp four times per second for three seconds
-three seconds with the safety belt lamp off
-flashing the safety belt lamp four times per second for three seconds again
8. The safety belt lamp flashing four times per second for three seconds provides confirmation that the belt minder is disabled.
9. After confirmation, the deactivation/activation procedure is complete. user_offline.gif
Apr 02, 2008 | Car Audio & Video
Marina Aqua-Minder Programmable Digital Thermometer Logo
324 people viewed this question
Top Marina Reptile Experts
windryder
Level 1 Expert
john h
Ned Halaweh
Ned Halaweh
Are you a Marina Reptile Expert? Answer questions, earn points and help others
