Question about Lexmark Wheelwriter 1000 Typewriter
KsMy IBM 1000 power on however it dosen't C Rtn & 1 2 3 keeps blinking, any subgestions
  • Lexmark Master
  • 3,594 Answers
You probably need a keyboard a rebuilt one is 100.00 CONTACT ME @ 216-269-3918
DickyO
Posted on Nov 08, 2012
3 Suggested Answers
  • 3594 Answers
SOURCE: ibm wheelwriter 1000 1 & 2 lights come on and
It sounds like a bad keyboard, you can try my tip under WW1000 or contact Geo. Beyers Co. for a keyboard rebuild @ 800-392-8085 tell them O'Reilly sent you.
DickyO
Posted on May 19, 2010
  • 3594 Answers
SOURCE: WILL NOT TYPE
The keyboard is probably going bad. You can try my tip under WW1000 or contact Geo. Beyers Co. @ 1800-392-8085 for a keyboard rebuild. Tell them O'Reilly sent you.
DickyO
Posted on Jul 09, 2010
IBM Selectric: Why does ball keep typing in the same spot when it gets to middle of the carridge? Space past that spot and it types fine. Hopefully, there is a simple fix. Thanks.
There are 2 black plastic dust covers that get bowed after the years and catch the carrier at the seam where they meet. They may just be loose so first try pushing them down. If that dosen't work take a sharp object and round off the top edge where they meet. If all fails gently remove them it will work fine without them.
DickyO
Apr 26, 2012 | IBM SELECTRIC2 refurbished selectirc ii 2...
I have a lexmark w/w 1000 with beeps and line spacing 1 & 2 blinking ?, what does that mean?\ r\nThanks Alan
Your keyboard is bad. You can try my tip under WW1000 or contact Geo. Beyers Co. @ 800-392-8085, Tell them O'Reillysent you.
DickyO
May 23, 2011 | Lexmark Wheelwriter 1000 Typewriter
Ok i have a jl500/1v2 amp with 2 w6v2 subs and i haveing a problem dont no if the amp is two much for the subs becouse i turn the amp to get more tump and the subs pop and the yellow light filkes so i turn...
its real simple. your under powered.
your W6s RMS at 500 watts EACH and your sending em 250RMS (half what they need)
The 'pop' your hearing is the failure to supply enough power to draw the cone back in time and collides with the next wave of sound.
prove it?
drive a single W6 with your 500/1 bridged.
i'll bet your pop goes away.
long term, get another 500/1 or jump up to a 1000/1v2.
I also HIGHLY recommend JL's in-line audio cleaner. If i recall it was like 60 bucks but waaaay worth it. makes sure that theres no distortion in the source input to your amp(s), which...keeps your subs from trying to reproduce transients and delivers only clear signal to your subs void of all clipping signals. Its an active electronic compoent.
PS: if you are pushing 12W6's, i had the same setup once...I had W3s connected to my 500/1 and upgraded to the W6s...had the same issue your describing, and then got the 1000/1. happy ending.
May 03, 2011 | Jl Audio 500/1V2 Car Amp
I have a jl audio 1000/1v2 my probem is the low volt ligth blinking and dosen t work wath shut I do
The low voltage light would indicate that there is not enough power reaching the amplifier through the power wire. Are you using 4awg or bigger wire? Is the amp grounded well? Does this happen all the time or just at high volume?
Try checking your power and ground connections and ensure that you are using the correct size of wire.
Mar 11, 2011 | Jl Audio 1000/1V2 Car Amp
I got this Pacific Digital model 1930-24 in a yard sale. It needs a power supply/adapter. Where in canada can I purchase one and is this power supply common. I have a disc drive back up unit for my PC that...
Possibly not. It depends on what the power points are on the connector. The Pacific Digital 1930-24 uses the following pinout voltages: 1 = +12VDC ; 2 = +5VDC ; 3 = RTN/CMN ; 4 = +5VDC ; 5 = RTN/CMN. The pinout DOES NOT follow a clockwise or counter clockwise position. The pinout starts at the bottom with pin 1 by itself, above it is Pin 2 & 4 above that. On the opposite side is 3 with 5 on top. Or you can view the following image: http://img7.imageshack.us/img7/7204/minidin5p.gif
Again, that is the pinout for the socket on the 1930-24. Some iOmega external CDRWs have the +5VDC and RTN pins swapped. So they would not be a good alternative to use.
Jul 25, 2010 | Pacific Digital X-treme CD-RW Burner
Ibm wheelwriter 1000 1 & 2 lights come on and
DickyO
May 19, 2010 | Lexmark Wheelwriter 1000 Typewriter
Where can i get a ac adapter for a Pacific Digital 1930-48
If you can get an adapter with the correct connector, you could try to make your own power adapter, or even convert an iOmega adapter.
Mar 18, 2010 | Pacific Digital Computers & Internet
When istalled the PCI card into my desktop. Once plugged in, the power keep switching on and off by itself.
it dosen`t matter it keeps on blinking, it suggests that its working fine, if at all it stops blinking that suggest that the data is not transferring through that, it means its not working.
Mar 11, 2010 | Linksys WMP300N Pre-802.11n Wireless...
Lost power cord
Ebay, or if you arent into auctions you can try directly from pacific digital, they can ship to you. Tell them you didnt have one when you bought it, maybe they will give it to you for free.
Aug 12, 2009 | Pacific Digital (U-30106) CD-RW Burner
Jl 1000/1 popping fuse
well you need to check to see if nt no shottage with the amp and also check if the fuse is not to low amp 20,,,, 25 if not put the amp in a separet 12 volt battery
Dec 10, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Lexmark Wheelwriter 1000 Typewriter Logo
50 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
