Question about Sony PlayStation (PS) Console
Ps3 slim picture ic problem
Ps3 picture ic problem how i fix it
Ps3 slim console powers up but no sound and no picture on tv
The issue with two discs in the tray sounds a little people peculiar and hopefully didn't damage the drive. It could be theYLOD (Yellow Light of Death) in which when you power the console on, it will be solid, then blink, then solid again.
Make sure your HDMI, Composite, or RCA cable is secure. Try different cable types just in case.
You can shipped the system back to Sony and they can exchange it for a refurbished system; check out YouTube videos for some fixes, or look for someone who fixes ps3s on Craigslist
Apr 03, 2014 | Sony Playstation 3 (PS3) Console
Sony Playstation 3. There is no picture, only sound through HDMI cable connection to TV from my playstation 3.
Does your HDMI cable was placed properly through the television and in the PS3 unit ? , If Yes then does you HDMI cable have defects ? If No then whats your PS3 ? Slim or Super slim or Fat ?
Oct 26, 2013 | Video Game Consoles & Games
PS3 pixilation, chopy graphics
You might have to much data on the ps3 try cleaning some stuff off
Oct 02, 2012 | Sony PlayStation 3 Slim Black Console
My Ps3 slim won't play gta4 and the episodes from
appallonia3
Unfortunately this is a sign that the data on the drive is corrupted or the drive its self is goning bad. The link below tell you how to fix the issue.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Aug 11, 2011 | Sony Playstation 3 Slim Console
When i turn on my ps3, the green light stays on and the tv screen doesn't even change. i changed the cords to make sure the audio/video wasn't just out. i tried to enter 'recovery mode' but it won't even...
If you have a "slim" ps3, it does not beep 3 times. Try this.
First, with the system off,plug in your old red, white, yellow cables into the tv. (make sure your tv is on the correct setting). Now, just turn on the ps3 the regular way. Did you hear the sounds it normally makes when booting up (the ps3 boot music?). If so, thats good. If you did not, check again that the tv is on the right channel, and if possible, try another set of red, white, yellow cables.
If you heard sound, but do not get a picture, turn the ps3 back off. After the red light comes on, hold your finger down on the power button for about 5 seconds. If you have a fat ps3, it will beep 3 times after a few seconds to get back to regular tv mode. If you have a slim ps3, it will beep once, then 1 more time a few seconds later. It should reset and turn back on. If your tv is on the right channel and the cables work, then you should now see a picture and you know your audio/video is working. You can now try your HDMI cable and it should prompt you to use the HDMI at this point.
Hope that helps.
Mike!
Mar 02, 2011 | Sony Playstation 3 (PS3) Console
My ps3 turns green then goes yellow and then blinks red........ what should i do
sorry but it sounds like your ps3 has overheated. aka the yellow light of death. I have fixed about 5 different ps3s with the yellow light. but it WILL overheat again. you can do the heat gun fix if you are computer savvy. here is the link
http://www.youtube.com/watch?v=4_Ic1_TY-GU
it will work for a few days maybe a week or month if you keep the ps3 super cool, but it will still be damaged.
ultimately you will end up getting a new ps3.( get a slim)
If it makes you feel better, I paid 699 for a launch console, it got the yellow light 2 days over the 1 year warranty and sony made me pay 150 to fix it, thats 850$ for 1 ps3 !!! They ended up sending me another ps3, THAT one got the yellow light too! they wanted another 150 to fix it. so i fixed it myself and sold it to gamestop for 150 and got a slim.
Dec 03, 2010 | Sony PlayStationĀ® 3 (80GB) Console
Red light flashes on PS3 and won't switch on , how can I fix this ?
i need to ask is it a slim or a ps3 with 4 usb ports?
if its a slim there is 2 ways
1. click the buttom
2. press the middle button on your ps3 controller
if its not a slim there is still 2 ways
1 . slide you finger across the power on the ps3
2. middle button on controller
Hoper i hellped ^^
Apr 15, 2010 | Sony Playstation 3 (PS3) Console
My new ps3 slim doesnt display on tv
Well, after seven months I hope you have gotten this issue resolved, if not it sounds like your tv isn't on the AUX channel. Try switching your input to AUX. It should fix the problem
Mar 09, 2010 | Sony PlayStation 3 Slim Black Console
Ps3 error code 8001050f
Here’s what’s going on right now: something with the PS3’s internal clock has borked in some pre-slim models. This is not a PSN issue; it has to do with your PS3’s clock. This clock is NOT related to the OS clock. It seems to be a leap year bug. Setting your clock ahead will do nothing. All PS3s around the world were affected at the exact same time.
Does this affect me?
-If you have a Slim PS3, you’re good to go. Continue playing it as normal.
-If you have a “fat” PS3, you may be affected. Some fat PS3s have worked ok, but it seems a good majority have been bugged.
What does this bug mean?
-If affected, your date and time has been set to a random past date. This prevents you from signing into PSN, playing any PSN games, or using any DLC. Your trophies will also not display correctly or be able to sync.
How do I fix it?
-You can’t. Even if you don’t sign into PSN, it won’t help. This is a hardware issue.
So, what do I do?
-Wait 24 hours. Other products that have had similar bugs have corrected themselves after the “bugged” day. On Monday around 6pm central time, all PS3s will automatically correct themselves…maybe.
-If that doesn’t work, we’ll need a firmware update from Sony, which should be a pretty important priority for them right now.
Did I lose my data/themes/etc?
Your save data/games/dlc/themes are fine. They’ll be fixed when the PS3 is fixed. Trophies are uncertain right now, but they’ll be fine if you’ve synced them before the PS3 was bugged. Unsynced trophies are an unknown right now.
If I have a bugged PS3, can I still use it?
It’s probably not a good idea, as I have no idea what will happen to the trophies you earn during the bugged time. Movies/media will work fine.
xz
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
PT-47WXC43G
no the ICs wear out the PS3 could contribute a little. But you will need to replace both STK392-110 Convergence ICs. You can get them at this link with free instalation instructions with pictures so you can do the repair yourself. Here is the link
http://servicemanuals.vstore.ca/
Apr 24, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Sony PlayStation (PS) Console Logo
107 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
