Question about Yamaha RX-V661 Receiver
The receiver works great but there are no longer any lights on the front. We checked the manual and can not see where there is a fuse or light bulb to change help
    Top Expert:
  • Yamaha Master
  • 14,553 Answers
If on the front display it is either missing a voltage source (connection or bad part) or the display itself is bad.
Posted on Nov 08, 2012
My internal light is no longer working....bulb seems fine..could it be a fuse?? If so....which one as no specific fuse listed in manual
Hi Robert, In most cars if the tail light fuse blows then the interior light stops working as a warning the tail light fuse has blown... Check the tail light fuse...
Mar 31, 2016 | Cars & Trucks
Front and rear light blown
Hi, Anonymous you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day. Why are my bulbs blowing
Thread Tail light bulbs blowing dealership says it the bulb socket 400 http://absolutelyscooters.net/service-manuals.html
CPI Scooter Parts Racing Planet USA
Free CPI Motorcycle Service Manuals for download
Jan 27, 2014 | 2008 Cpi Aragon GP
I put longer handle bars on and when i extended the wires the front left wire hit the shock and now the turn signals dont work and i cant seem to find the fuses or a free repair manual
Hi, Larrydoss74 before diagnosing any turn signal/running light/parking light issue make sure the bulb is good and the light fuse has continuity with a test light. If you have replaced you OEM lights with LED lights you are going to need a load equalizer. If no turn signals work the cause could be a faulty turn signal module or the connector going to it, look for corroded, loose, or broken pins/sockets. Contact spray cleaner is great for removing corrosion. If your speedometer does not function properly it will have to be fixed first because your turn signal module gets the data from the speedometer for normal turn signal function. If your front turn signals don't work use a test light to check for power and ground at the bulb socket, then start backtracking the wiring through every wire connector to the turn signal switch/button and check for continuity, go all the way back to the fuse if necessary to find the cause of the malfunction. If your rear turn signals don't work check your rear fender wiring harness connector first for corroded, broken, loose pins/sockets, power, and a good ground, (the harness connector is usually located under the seat on the front of the rear fender) then keep tracing the wiring look for obvious harness damage caused by the rear tire. If you still can't find the malfunction backtrack from the rear fender wiring harness connector. If one side does not work you could have a faulty turn signal switch or module check for continuity. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Turn signals won flash General Street Bike Discussion
ViragoTechForum com
http://www.groussin.com/multi/XV250.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2005/LIT-11626-18-21_1000.pdf
Aug 10, 2011 | 1996 Yamaha Xv 250 Virago S
Left front signal light want work
It sounds like one of two things. One the light may be burnt out. If you have not already checked it, look in your owners manual for how to access the bulb. You can take the turn signal bulb that does work, into the socket and see if the problem rests with the bulb or the wiring. If the bulb looks fine, check your fuses if you have not done so already. If you do not know which fuses, or where, control your turn signal, look in your owners manual. You may need to check more than one fuse as the light may be protected by muiltiple fuses doing different jobs. If all seems fine here and the light still wont work, check all the wires that lead to the light. Also check to see if there is some corrosion or rust in the bulb socket. That might affect the bult as well.
Apr 11, 2010 | 1997 Pontiac Firebird
Left signal not working
the blinker is behind o next to the brake pedalit coul be the problem brake ligth swich is ataached to bhe brake pedalhold by two screws o pins first check for groud o positive
Jan 11, 2009 | 2002 Chevrolet Silverado 1500HD
1990 Mazda Miata, Tail lights, Interior lights not working! :\
I have a problem with my tail lights in my mazda. Brake lights working great but the light that supposed to be working during night time are not. By the way the front lights are working too! Also the light of the panel inside is not working. Can anyone please tell me how to fix it?
Thanks alot in advance!
Sep 06, 2008 | 1990 Mazda MX-5
Lights out (front panal lsd lights)
I doubt that any fuse blown ot because the unit still works. The LCD panel in these units are very delicate and can easyly break, also there is a small bulb in there that illuminated the backpanl of the LCD. good Luck
Mar 23, 2007 | Kenwood VR-605 Receiver
Yamaha RX-V661 Receiver Logo
129 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
