Manual to fix Matag atlantis MAVT634aww washer
Leak at drive shaft going into tub
  • 90 Answers
SOURCE: maytag atlantis leaking in the tub
replace water valve
Posted on Jan 06, 2008
vest6
  • 196 Answers
SOURCE: My maytag atlantis mav6200 only spins on whites cycle
Try running the machine in another cycle the very next time you use it. I'm trying to determine if this is machine fault something else.
If you just used the machine wait for about 1/2 hour before starting it again.
Posted on Jan 15, 2008
SOURCE: water dripping into tub
One of your water solenoid valves are either going bad or stuck open with a little sediment. Find out which is leaking by turning off one of the water lines to the washer. If after it is turned off it still leaks try turning the first water valve back on the turn the other water valve off. This will help you determine which solenoid valve is having the problem. Once identified it is easily replaced.
Posted on Sep 29, 2008
garing
  • 998 Answers
SOURCE: Maytag Atlantis MAV6250AWW won't rinse or spin?
clean motor rollers(belt may be slipping)
9vopy...paste)
Posted on Aug 31, 2009
SOURCE: I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Posted on Feb 06, 2010
Trying to remove aggitator from maytag atlantis I removed fabric softener part need to get the shaft of aggitator off trying to clean my softener keeps leaking out after wash is done
i believe all you have to do is put your fingers underneath the bottom of the agitator and pull up and the whole agitator pops up to remove it out of the tub.
Apr 08, 2011 | Maytag Atlantis MAV6000 Top Load Washer
My matag atlantis just stopped working. It will
no reset, check the receptical you could have tripped you house circuit or fuse
Feb 06, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis Model MAVT634AWW the spin cycle rpm has become too low to properly wring out clothes.
My maytag washer will not drain and is leaking from the bottom. What do I need to do to open up the inside of my washer and does anybody have any ideas on how to fix this problem???
Nov 26, 2009 | Maytag Washing Machines
The washer tub leak
Sounds like you have a hole in the outside of the tub sometimes something in a pocket like a nail or something will wear a hole in it. If that's the case it can be fixed but is tough one to fix. You will most likely have to remove the tub there is a kit to fix this with. You will have to drill the hole a little larger to fit a bolt. I have made them, take two rubber washers one for each side of the hole and two large metal washers one for each side over the rubber washers ,a bolt to fit the hole you had to drill in the tub tighten it down pretty tight so it won't leak. Put the nut side of the bolt on the outside of the tub so it don't hang on anything.
Check & see where the water is running down before doing this, be sure it has a leak or you will spend a lot of time & work for nothing. Hope this helps
Feb 02, 2018 | Maytag Washing Machines
Maytag atlantis will agitate won't spin
I had the same problem with my Atlantis a couple of months ago. It turned out to be the bearing for the tub drive pulley. When you look under the washer there are three pulleys. The one for the motor is ont he left, the drain pulley on the right and the big one in the middle for the tub. What I found is that when the bearing went bad, the tub would fill and turn for washing, but it would not turn at all for spinning. I could turn the pulley by hand but the tub refused to budge. I removed the main pulley and could see that the bearing had exploded. You can't buy just the bearing but the whole pulley kit is like $35 so I got off easy. I put the machine back together (which is tricky) but it works fine now. The pulley kit comes with complete instructions but it's really straightforward. The tricky part is that you have to pull down on the end of the drive shaft in order to get the retainer ring onto the pulley. That can be difficult if you don't have a lot of room to work or have a partner to assist. You can replace the whole thing or just the bearing and save the pulley for a rainy day if you want. I opted for the whole replacement. But I saved the old. cause ya neva know!
Jan 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis Top Load MAV6250AWW Drum Leak?
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Oct 22, 2008 | Maytag Atlantis MAV7260B Top Load Washer
Jan 14, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
