Question about Refrigerators
Power light blinks wont run
Power went out when it came back on light keeps blinking wont run
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 09, 2012
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
My vaio wont turn on and the green light in the back keeps blinki
The green light blinking in the back indicates that the power supply went bad and is not turning on, go ahead and get the power supply replaced. Normally that light is supposed to be fully lit and green.
Apr 28, 2010 | Sony VAIO VGC-RB53 PC Desktop
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
Power went out now the tv wont turn on, there is just a blinking
Does the power light just blink? Some of the Mitsubishi sets have a receiver built into them; if the power is removed the power light upon return of power should blink for 70 seconds and then go out--then the set should turn on---if the light never stops blinking---2 possible things--set should have a recessed button on the front keyboard(reset) that you can depress with something not sharp and see if after 70 seconds the light will stop blinking; if no, the set now has a damaged receiver(from the back of the set it is a large metal box on the far left side-----the blinking power light is the receiver trying to boot up like a computer---only should happen if power lost---let me know what you find----the receiver if bad is usually no longer available and can only be repaired by removing it and sending out for repair/rebuild.
I do this here for free so if this information helped you take a minute and give me a vote here......ALSO IF YOU HAVE ANY QUESTIONS OR NEED HELP REPLY TO THIS POSTING.
SD TECH
Sep 07, 2009 | Mitsubishi WS-55711 55" Rear Projection...
Power Loss
You will find 4 swollen capacitors in the DM module of value 1000uF 16volt. Replace them.
Aug 31, 2009 | Mitsubishi WS-55711 55" Rear Projection...
Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Jul 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
The power light on my computer keeps blinking and it wont turn back on
I think the problem with the RAM. please open your CPU cabinet and clean the RAM and fix it back. I think it will help you to overcome this problem.
Thanks.
Apr 30, 2009 | Computers & Internet
Lg. screen tv mitsubishi HDTV 1080 SERIES INTEGRATED
i went to turn on the tv and the power button don't work
Jun 02, 2008 | Televison & Video
LCD Monitors x7g troubleshooting
Check some of the other posts as it is probably just a bad capacitor or two and very easy to fix if you can do that sort of thing. I did and mine is back up and running.
Jan 05, 2008 | Sceptre 17" LCD Monitor
Red power light keeps blinking and wont come on
The first thing to try is to unplug the unit from the wall for about 15 minutes,if this does not work you will need the assistance of a servicer to diagnose the problem,if you are familiar with tv service you can check the horizontal output transistor for a short,sometimes it fails for no reason and other times it goes bad along with the horizontal output transformer also know as flyback.Be careful if you decide to check this yourself.
Oct 02, 2006 | Toshiba 50HX81 50" Rear Projection...
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
