Question about Apple 12" iBook G4 Keyboard (p/n 922-6132)
KEYBOARD CHARACTERS Z X C ETC NOT WORKING
The bottom line of keyboard characters not working when pressed. What next?
How do you type characters when setting up your email etc.
You will discover the @ character above the apostrophe on the r/h side of the keyboard. Press and hold down the shift key and all the dual purpose keys will become the alternative characters as printed on the keys.
The dot or full stop, or period as the Americans call it, is at the bottom r/h of the keyboard and the shift key isn't needed.
Apr 17, 2018 | The Computers & Internet
Have a new wireless HP keyboard for all in one omni 100, keys do not correspond on screen with keyboard, have tried adding different language keyboards in regions to no avail, what am I doing wrong_+(* ...
It's possible that you have hit the Num Lock key while you had another key pressed. Try the following combinations, one at a time, to see if any of them work. Be sure to test each one before moving on to the next one.
CTRL and NUM LK
Shift and NUM LK
ALT and NUM LK
A lot of times characters will swap places if one of these combinations has been pressed, and pressing the combination again should switch it back. Let me know how it goes! If this doesn't work, we'll try something else.
Aug 26, 2011 | Compaq Keyboard
There are torquoiise characters on my keys, how do I get them to work.
There is a key in the bottom left of the keyboard, next to the Ctrl key, with Fn in the same colour.
Press and hold, then the extra characters will appear with the other keys.
Feb 09, 2011 | Acer Aspire One PC Notebook
I have a TE-2000 cash register and find the instruction manual very complicated. Could you please advise on how to programme a logo message, commercial message and bottom message. Thanks in advance.
Turn your key to PGM enter 2 subtotal enter 0132 and press subtotal now you enter your 21 or 24 characters for the first line and press CA or the lower right hand button. Now enter 0232 and press subtotal and again enter characters and press CA or the lower right hand button.
Follow this for 4 lines and when all done press Subtotal.
I believe the register you have will show you the characters on the keyboard and just use those to make your logo.
Oct 19, 2009 | Casio Parts Cash Register PC Desktop
GENERIC KEYBOARD ALPHA KEYS DO NOT WORK PROPERLY
Numbers do though? If this is the case, try a different keyboard. If the keys are outputting different characters, then you should check the character map, oh wait that should only apply to alternate Operating systems, hum, then again XP does have that accessibility thing... Bottom line: If a different keyboard with the same connection works, just e-waste/recycle/trash that keyboard...
Mar 08, 2009 | HP Pavilion a705w PC Desktop
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
XPS One Keyboard's Characters not functioning
Try to re-sync the keyboard to the computer. Here’s the procedure:
1) Turn the computer on.
2) Turn on the keyboard
3) Press the sync button on the rear of your computer’s left speaker.
4) Press the sync button on the keyboard. ( I believe it’s on the bottom of keyboard)
The sync button has a symbol next to it, (2 arrows going in clockwise direction).
Ensure that the keyboard battery has not run low.
If that doesn’t work, look for a Bluetooth icon in the lower right hand corner of your desktop and double click on it to open the Bluetooth configuration utility. See if there’s a configuration file for the keyboard. If there is, delete it and then re-detect Bluetooth devices.
Hope this helps.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 20, 2008 | Dell Inspiron XPS Gaming Mouse Pad KU170
Gateway Keyboard left shift key adds a pipe character
The driver will not fix the problem, as this is a mechanical problem. I had the same problem and was able to fix it. Instructions with pictures can be found at: http://lotus.kick-***.net/keyboard
Here are the instructions without the pictures:
I had a problem with my Gateway keyboard where whenver I pressed the left shift key, it type a pipe | (verticle line) character. This is the same character that is above the back slash character . I searched the internet and people were suggesting reloading drivers and apparently Gateway was suggesting a destructive reload of the hard drive. That's absolutely rediculous.
After some research, I determined that on some European style keyboards, the backslash/pipe key is between the left shift and the "Z" key. So, I removed the left shift key to experiment. The key simply pops off by sticking a screwdriver under it. (It is not necessary for you to do this).
When I used a little screwdriver to press on the center of the plastic (red arrow) I would get a proper shift key. However, when I pressed to the right (green arrow), I would get the backslash character. If I pushed at the red and green arrow together, I would get the pipe character.
Ah-hah! I determined the problem. The inside of the keyboard is a "universal" type and can be used with U.S. or Europeon keyboard layouts. For whatever reason, the left shift key was hitting both dots under the key. (The dots are visible in the pictures below.)
To resolve the problem, it is necessary to disassemble the keyboard. On the bottom of the keyboard is a bunch of screws. Remove all of the screws. If you have any rubber feet, there is probably screws under the rubber feet. The feet are just held on by sticky taope, so they peel right off.
Once all of the screws are removed the top and bottom halves seperate easily. The circuits stay in the bottom half of the keyboard, so set the top half of the keyboard to the side. The red arrow marks where the left shift key presses down.
Pull back the top layer and you will see the flexible circuits. These are also made up of multiple layers. When a key is pressed it pushes these layers together to complete the switch circuit. The red arrow marks the shift key. The green arrow marks the backslahs/pipe key for European style keyboards. The blue arrow is yet another key that is not used on U.S. keyboards.
Pull back the first layer of the switch circuit to expose the space between the circuit layers.
Place a small piece of electrical tape on the extra backslash/pipe circuit connection as marked by the red arrow.
Now simply reassemble the keyboard and that weird pipe character will never accidentally show up again.
Mar 08, 2008 | Gateway 2520915 Keyboard
Keyboard data entry
Sounds like a classic problem for a driver/firmware update. get an update here before trying anything else- http://www.palm.com/us/support/downloads/tungstenc/tungstenc_update_30.html If it still doesn't solve it you might need to format it and reinstall everything from scratch. Good luck
Apr 22, 2006 | Palm Tungsten C Handheld
Apple 12" iBook G4 Keyboard (p/n 922-6132) Logo
226 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
