Question about Microsoft Xbox Console
Xbox 360 error
Hi again my xbox 360 has stopped working and has a strange problem. okay this is whats going on when i turn on my xbox 360 there is a E 68 symbol on the right hand part of the screen. how do i fix it manually?
  • Anonymous Dec 25, 2007
    will not play disc..records a E68 error
If your xbox 360 has an error reading e68 the best solution is to take off the hard disk drive and insert a memory card
Posted on Jun 09, 2007
SOURCE:
How do I repair the E74 error on the xbox 360
E74 - This error is caused by a cold solder joint under the GPU, (H)ANA-chip or in between. Mostly it is one of the outer solder balls on the side facing the (H)ANA chip so a shim increases the chanced of success quite a bit. Can also be a component that is missing or damaged so look for missing parts near the GPU and the (H)ANA chip. Xbox 360 Error Codes Explained and How to Fix Them
Aug 13, 2015 | Microsoft Xbox 360 Console
Error 40a3-0000-3080-0502-8007-045d
I got this from the Xbox support site for your error code.
Error Code xxxx-xxxx-xxxx-xxxx-8007-045D
A storage device (such as a memory unit or hard drive) was not found during the software update. Follow these steps:
  1. Turn off your console.
  2. Remove all console storage devices, including any USB flash drives, external hard drives or the internal hard drive on the Xbox 360 E console or Xbox 360 S console. Learn how to remove the hard drive.
  3. Add your primary storage device, for example, the hard drive.
  4. Turn on the console
  5. Try updating the console again.
Here's the website if you wish to peruse it further.
http://support.xbox.com/en-US/xbox-360/system/software-update-errors
Post back how it works out!
Jan 06, 2014 | Microsoft Xbox 360 Console
Okay well, ill turn on my xbox and sign into xbox live ill go into my game and get into a game but about 10-20 seconds into me joining the game my xbox just shuts off, what do i do to solve this?
There is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide.....you can download it and get help to fix your console.......
Click here to download Microsoft xbox360 repair guide
Jan 03, 2011 | Microsoft Xbox 360 Console
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
Orange ring
Okay here are a few ways that might fix the Xbox 360.
  1. Turn off the Xbox 360, wait 5 minutes, plug it back in and see if the error is gone.
  2. Unplug both the AV (audio and video) cables and the power cables from the Xbox 360 and wall. Wait a few minutes, and replug everything in and see if the error is gone.
  3. Take your hard drive out of the Xbox 360 and start the console and see if the error is gone. If the error is gone, turn the Xbox 360 back off and replace the hard drive. Then check if the error is once again gone.
If none of the above steps worked, then your going to have to spend some money to get your Xbox 360 back and running.
  1. If your warranty hasn't expired, then you can send it to Microsoft and they will fix it for free.
  2. If your warranty has expired, then you can still send it to Microsoft, but it will cost you about $150.
  3. If you don't want to spend the 150 you can spend a little bit of money and buy a guide to replacing it yourself on Ebay and such. If you do try and do it yourself remember that once you open the Xbox 360 the warranty voids, so if you still have a warranty send it to Microsoft.
Hope this helps!
-Marcus Turtle
Jul 18, 2010 | Microsoft Xbox 360 Console
Red ring
hi there,
your xbox 360 need service open it and remove all dust around the fan and prosseser every thing fine again.
Jul 11, 2010 | Microsoft Xbox 360 Console
Xbox one blinking red light.. 1 not 3,, first time i seen this, fixed many ps3 ylod,, is it the same fix? looking for help here or a good link on repair info
When you get one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
Feb 06, 2010 | Video Game Consoles & Games
Xbox 360
Well thats very hard to do, the problem is that the xbox is overheating, more specific the GPU, thats why it freezes. The easy way would be to open your xbox an leave it that way, I have a xbox that works just when is all open with the parts expose. Very strange but it works. Also put some new thermal compound on your GPU and heatsink.
You could make the room where you play very cold so the xbox will not overheat or put some big fans near the xbox hoping they cool it down. Or stop playing like 15 minutes every 2 hours so it cools.
Aug 18, 2008 | Microsoft Xbox 360 Console
Xbox 360 reading error
Bad Cdrom/dvd
The laser going bad is a pretty common issue with the drives, since it's a Hitachi that spindle motor could be all gunked up with dirt as well and cause that issue also.
if ya have a Hitachi, if it's a Samsung it could just be the laser.
http://www.llamma.com/xbox/Repairs/xbox_dvd_repair.htm
Dec 17, 2007 | Microsoft Xbox 360 Console
HALO 3 UPDATE
Have you got the internet connected to your Xbox 360? If so, i have two relevent answers:
1: Don't press update, i've heard that the update is not a necessity to playing the game.
2: Contact the store that you rented it from or; Contact microsoft and tell them the problem.
If you haven't got the internet connected to your xbox 360 then it WON'T work.
cheers.
Oct 10, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
152 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
