Question about Samsung Chromebook Series 5 Arctic White Wifi Laptop/notebook
Now my keys are sticky is there anything i can do?
  • Samsung Master
  • 32,281 Answers
Cannot repair but needs to be replaced. Chrck out this WEB site for a replacement.
Keyboard replacement, LCD screens for mobile phones, Ipods and computer equipment. http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Posted on Nov 08, 2012
Turn sticky keys off
My asus computer won't type anything. I think I turned sticky keys on. What is the solution? Thank you
Jan 05, 2014 | Acer Computers & Internet
Keyboard keys wont type. used on screen keyboard to type this. any suggestions?
You might have "sticky keys" so try this:
When sticky keys are enabled, users can access functions that require pressing multiple modifier keys such as "Ctrl," "Alt" and "Shift" at once by pressing one button at a time. If sticky keys are enabled, it is possible to accidentally turn them on at an unwanted time. After turning off the sticky keys, disable the feature to prevent them from accidentally turning on again.
    • Press the "Shift" button five times in a row to turn off sticky keys.
    • Open the "Start" menu and then click "Control Panel."
    • Click "Ease of Access Center" from within the Control Panel window.
    • Click "Make The Keyboard Easier To Use" from within the Ease of Access Center window.
    • Remove the check-mark beside "Turn On Sticky Keys" to prevent sticky keys from being accidentally turned on.
    • Click "Apply" to save your changes and then click "OK" to close the window.
Hope this helps. Good Luck!
Aug 05, 2013 | Toshiba Satellite L645DS4040 Laptop
Shift or CTRL mouse selection modifiers not working after a few seconds
Hi wdidtd,
It sounds like Sticky keys\Filter keys are activated on your machine (I always confuse the two:] ). Go to Control Panel -> Ease of Access Center -> Make my keyboard easier to use, and make sure neither Sticky keys or Filter keys are marked.
Regards,
TheSmacker.
Jan 17, 2013 | Microsoft Windows 7 Professional for PC
Keep getting F1-8 keypad short code can this be fixed?
You have some junk making the key sticky. Before buying anything use a hot hot damp cloth to loosen up the sticky key.
Jul 06, 2011 | Maytag Gemini 30" Self-Cleaning...
I have a sticky '1' key. Is there anything I can do?
You can buy a cleaner lubricant spray to clean off the stickiness. You can do this online or almost anywhere they sell electronics or computers.
Apr 28, 2011 | Sharp EL-2630P Calculator
How to turn off explorer sticky keys
In the Control Panel (Classic View), open the Ease of Access Center control panel. Follow the link that says, "Make the keyboard easier to use." Uncheck the box that says "Turn on Sticky Keys." You can also follow the "Set up Sticky Keys" link to adjust the Sticky Keys options.
Hope this helps!
Mar 10, 2011 | Microsoft Windows Vista Home Basic Edition...
Sticky "o" key.
Those keys are pressed fit on the keyboard. gently prying it up carefully it will pop loose. Look down at the membrane to see if the key is being impeded by anything , clean an pop back on. Do this carefully as the keys are very thin plastic and the gripper edges are very easy to break off.
Dec 07, 2010 | HP Pavilion dv7-1245dx Notebook
Shift key not working
You have 2 Shift keys on the keyboard. If the other shift key is working then the shift key that is not working is defective. You should consider replacing the keyboard on your laptop. There is no setting on Windows that can disable the shift key.
**Note : If both Shift keys are not working, Try to check if sticky keys feature on windows is on. Sticky keys should be disabled. To disable sticky keys, Click on start and Go into control panel > Accessibility Options, and under keyboard there is sticky keys. Remove the tick and click apply and OK.
**If "Use Sticky Keys" is unchecked, that means sticky keys is disabled.
May 29, 2010 | HP Compaq nc6000 Notebook
Can't type anything without weird things happening the \'p\' prints,
hi, check that Sticky-keys arent turned on.
to toggle Sticky-keys on and off, press the shift key 5 times fast, then either Disable the sticky-keys tickbox, or click Settings for more configuration settings.
when sticky-keys are enabled, you can press shift and release, and the shift key is still enabled. this also goes for Alt, and CTRL.
so if it is enabled, pressing P will attempt to be Ctrl-P - which is print.
Sep 10, 2009 | Acer NSK8458AN Keyboard
Error Beeps On Start Up
Hi!
It could be a problem with the keyboard that it might have a sticky key. Try to check the keyboard for some sticky keys and check if you can still clean them or else replace it. :)
Hope this helps!
Thanks,
Karlox™ :)
Jul 10, 2008 | Computers & Internet
Samsung Chromebook Series 5 Arctic White Wifi Laptop/notebook Logo
242 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
