Panafax 321 error code 311
I get printer error 311
  • Jay Cleveland Nov 09, 2012
    The machine a panafax UF-321 the error mesage is " Printer error info code=311
4 Suggested Answers
  • 82 Answers
SOURCE: Pnafax UF-322
do you get the error code immeditely after turning it on or shortly after on
Thank You,
Mikey
Posted on Apr 05, 2008
  • 134 Answers
SOURCE: Panafax UF-885 - Error Code 055
Error 055 is a laser error. the laser is not spinning at the proper speed and may need replacement. There is another solution, where some ferrite cores are added around three cables to reduce electronic interference. Best call a local technician for further diagnosis.
Posted on Mar 25, 2009
SOURCE: error code 021 on panafax UF0890 message in
panasonic uf744 check print info.code=021
Posted on Oct 21, 2009
Erroe/fault 093-311
fault Code 093-311: Rotary Assembly Failure Solution : Power the Machine Off and On CAUTION: Wait at least 60 seconds between powering the machine off and then on again; otherwise, damage to the machine and the hard drive may occur.
  1. Press the power switch to the [O] (off) position.
    NOTE: The machine will remain on for approximately 10 seconds while storing files and preparing for shutdown, and then will power off completely.
  2. Wait 60 seconds, and then press the power switch to the ['] (on) position.
Jun 26, 2014 | Xerox WorkCentre 7232 VSE All-In-One Laser...
What is the problem and solution to error code 420 or 321
Are you able to send fax to another # ?. Error 420 & Error 321 is mainly due to transmission of signals or incompatibility issue.
Try reducing Fax speed and turn off ECM from Fax menu and check.
Regards,
Sean
May 15, 2014 | HP OfficeJet D135 All-In-One InkJet...
I have just changed the drum cartridge on my DocuPrint C525A printer and i have this message: 004-321 Reboot Printer. I have turned the printer on and off but nothing changes. I looked through the manual...
004-321 is a TR0 error, which means the accumulator belt could not find the beginning of belt mark.
The belt is part of the Drum Cartridge. Replace/Reseat the drum cartridge and reset printer, this should correct the problem
Jun 16, 2011 | Fuji Office Equipment & Supplies
Dell 3000 0004-321 error code
code 004-321 Restart Printer will not shut of once I turn off/on the printer
Jan 25, 2010 | Dell 3000cn Color Laser Printer
Error 016-311 xerox workcentre M128
This error code means the Scanner is not installed. The reason for this code could be a bad or diconnected interface cable, or corrupt system software. Check the cables for connectivity. If the problem persists, it will probably require a call to Xerox service. 800-821-2797
Nov 08, 2009 | Xerox WorkCentre M128 Copier
What is error code 311?
It looks as if error code 311 refers to printing using a computer with Mac OS X. I've found a solution on Canon's website that may help you if this is the operating system you are using: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=17160
Hope this helps.
Jul 10, 2009 | Canon Pixma MP480 All-In-One InkJet...
Error Code 720 on Panafax UF-9000
error 720 means unable to connect to the POP server.. incorrect POP server ID or POP server is down
Apr 24, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
Pnafax UF-322
Thank You,
Mikey
Apr 03, 2008 | Panasonic Panafax UF-333 Plain Paper...
jasbo
jasbo
