Question about Mr. Heater MH175KT Open Flame Utility
New kerosene heater will not ignite
Fan comes on will not ignite
  • Anonymous Jan 26, 2009
    I have same problem.Heater wont ignite.
My Dads heater is doing the same thing i took it apart and found the fan has a device in it that builds pressure and forces it into the tank pushing it ut to the nozzle that sprays the fuel, The fitting that hooks to the fan part was broke in shipping. but am now having trouble finding part.
Posted on Dec 13, 2009
Buffalo12980
  • 625 Answers
SOURCE: reddy heat/scheu kerosene space heater no ignition
Typical kero heater uses either a spark ignition or a hot surface. The hot surface igniter is very fragile. A small bump may break the elements. Flame is detected by a photocell, signal is sent to the lockout relay board. Change the igniter costs about 50 bucks.
Posted on Nov 29, 2007
tbugger
  • 232 Answers
SOURCE: Kerosene Reddy Heater, fan comes on, but it won't ignite
Your description does not leave much to go on, because you don’t state the model heater that you have. You see, there are 2 different technologies that come into play on portable kerosene heaters. First there is the older version spark plug type heater, and, second there is the newer computerized type with Hot Surface Ignitor (HSI) technology.
Since you state "There is no electricity getting to the plug", the KEYWORD here is PLUG. I am going to assume that you have a spark plug type heater. NOTICE: if your heater has HSI technology- disregard this post because it will not apply.
Causes for "no electricity to the plug":
  1. no electricity to the unit
  2. a defective Safety Control (reset)
  3. a defective photocell
  4. a defective Ignition Control (transformer)
  5. loss of ground to the Ignition Control
I am including a link to some troubleshooting tips for spark plug type heaters. These heaters are relatively simple, but, be careful. Stay away from the fan and take precautions from the obvious shock hazards. Troubleshoot each of the above until you find the problem.
Posted on Dec 04, 2008
  • 653 Answers
SOURCE: my 110,000 kerosene heater will not lite igniter
Pardon all of the gobbldy gook that follows but this should put you in touch with a local heater repairman. http://rd.business.com/index.asp?bdcz=go.dex.bf.e&bdclooka=akaa&bdclook=true&bdcr=2&bdcu=http%3A%2F%2Fwww%2Egoogle%2Ecom%2Faclk%3Fsa%3DL%26ai%3DCApLarKvPSo2BM4m2tQOvu%5F2pCY2M4G7fyfL5C9fLzdIxEAIgmE4oDFCPh9nQ%2Df%5F%5F%5F%5F8BYMnmwIzYpOARyAEBqgQfT9AMrxZLcHDjKnbI%5Fem1UGmTep5nDsZlopr4xY9IkQ%26num%3D2%26sig%3DAGiWqtzydku0M5xKJYt6p4aH6TBZvwnKtg%26q%3Dhttp%3A%2F%2Fc26%2Erd43%2Ecom%2Fadserver%2Fkclick%2F43755%253Fphrase%253Dheating%252Brepair%252Botisville%252Bmi%2526csdest%253D2%252Bu26%252Bl341%252Bc76%252Bts%252Bmcgoog&bdcf=&bdcs=2F2870E0-1D71-40C3-8572-DA7DF3A9D8BD20091095228958_bravo&bdcc=azaf&bdch=BDC200&bdct=20091009143129&partner=dex&pos=1
Posted on Oct 09, 2009
  • 149 Answers
SOURCE: Desa Reddy 110BT H.S.I Series, igniter goes out
flame sensor clean with steel wool usually right next to hsi should fix.
Posted on Jan 16, 2010
SOURCE: when filled with kerosene then plugged in, the
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Posted on Jan 20, 2010
My mr. Heater contractor series 75,000 kerosene heater won't get hot the blower isn't kicking on its getting fire and it's got kerosene in it but it won't get hot the blower won't kick on?
Kerosene Torpedo Heater Repair + Test - YouTube
? 12:08
https://www.youtube.com/watch?v=k1nRieTELnk
May 25, 2013 - Uploaded by InductiveExperiments
I repair my "Reddy Heater" torpedo heater by installing a new ... I replaced spark plug, filters,photo cell, new K, it has fuel spray,spark but it won't ignite now! .... I removed my motor andhot wired it to an outlet and it worked fine. but when hooked up ....Mr. Heater 36,250 views ... Get video URL at current time.
Torpedo Kerosene Heater repair & HOW they work - YouTube
? 9:30
https://www.youtube.com/watch?v=ve0nzByP6SU
Dec 6, 2013 - Uploaded by sixtyfiveford
Could not find my manual and the Mr. Heater (75k),web site let me down for a pdf. Opening the .... Thanks for the video -- helped me get mine working again ... Fan runs also just won't fire Any help would be great Thanks.
Mr Heater Kerosene heater cleaning and maintanence ...
? 9:06
https://www.youtube.com/watch?v=2EzoWdZLExg
Jan 11, 2016 | Mr. Heater Heating & Cooling
I have reddy pro 170 i plug it in , the fan & igniter comes on for 10 to 15 seconds then shuts off ,blew through fuel line and nozzle still same result, i do see fuel mist coming out nozzle ,i dont k
You must make sure the mist is not to close to the igniter . If it is it wont be misty enough to ignite. And make sure its in the path of the mist. If its new return it to the store.
Feb 07, 2015 | Reddy Heater Pro-Tough Kerosene/Diesel...
I have an all pro 60,000 btu flex fuel heater. all pro went out business. i need a new igniter .... can anyone help me find this part ?
Try www.desatech.com. From the main page, click on kerosene heaters. Some igniters should be at the top of the page that comes up. See if one matches yours.
Jan 14, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Kerosene Reddy Heater, fan comes on, but it won't ignite, it just blows kerosene out the front. There is no electricity getting to the plug. Please reply soon, I need it tomorrow!! Thanks
Dec 04, 2008 | Reddy Heater-30-55,000 BTU Variable
All Pro Heater
most parts for kero heaters are interchangable. go to desatech dot com for parts. check for a reset button for your heater. if no reset, does the fan run? your unit can use one of two ignition parts. a spark generator with a spark plug or a hot surface igniter. the unit uses a cad cell flame detector. you might need to replace this.
Nov 18, 2007 | All-Pro Kerosene Garage Shop Heaters - All...
Mr. Heater MH175KT Open Flame Utility Logo
604 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
