Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Frozen water on the bottom of frezzer - Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
  • 4 Answers
Hi there, it sounds like the freezer needs to be unplugged and defrosted, now if it does this automatically which some do and the ice water that was frozen goes through a pipe and out through waste water outlet, after it is completely defrosted you should turn down the freezer dial by at least one digit and keep a check on this to make sure that its not over freezing and causing this problem, on some models the automatic defrost does not work as it should , and even when they do work it is not defrosted enough , so do it manually for a perfect job, note that any food that is in the freezer can be wrapped in news papers while the work is been done , they will be well frozen for the time it takes to defrost , you can speedup the defrosting with a bowl or pot of boiling water placed in the bottom of freezer, make sure that the water outlet is not blocked with food debris..
hope this will be of some help to you.
cassyjoe.
Posted on Nov 07, 2012
Where is the water tube to see if its frozen FGHB2844LF5 dbl door bottom frezzer
Hello Wally, thanks for your post!
Based off the information you have provided you would like to know the location of the water line inside of your Frigidaire refrigerator. The water line is located within the wall of your refrigerator it is not accessible. The best way to clear out a frozen water line is to disconnect power from the refrigerator for at least two to three hours. This will help defrost any ice build-up within the refrigerator. I hope this information is helpful to you. -Matt
Dec 03, 2015 | Electrolux Frigidaire Gallery FGHB2844LF...
I have a ffa90 futre fridge & bottom frezzer. the fridge is frezzing the food in the door & in the fridge. have tryed water in botles & they get ice on it .in the door the food frezzers so
Find where the supply air is coming into the fridge part. It comes from the freezer and could easily be supplying -18 air direct to the door. This would give you a 2 in the fridge but anything in the direct air path could freeze.
Sep 07, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
.i have a side by
Hello, Thank You for using FixYa. I will be helping you today.Yes sounds like the drain tube frozen or blocked.Remove the back cover in the freezer and the drain hole is in the center bottom is it covered with ice? You can use hot water to thaw it or a hair dryer. Im sure its just frozen and be careful not to poke the aluminum evaporator it sometimes takes a little while to get the drain all clear.You will see and hear it drain when its clear.
Thank You and please rate my answer if it was helpful..
Jun 13, 2011 | Maytag Refrigerators
I have a side by side kitchenaid and the frezzer works every two days I find the bottom or floor of the frezer has ice built up,if I dont remove it The ice melts and leaks out the front of the frezzer,I...
Remove the back panel and get to the drain trough. Using a hair dryer heat until it starts getting a lot of water. Dry with towel and repeat. After several minutes take some boiling water and pour in the drain trough and let set. Do this with ref off. After about 30 minutes the tube will be cleared again. Hope this helps. Rick
Apr 27, 2010 | KitchenAid Superba KSRS27CN Side by Side...
Model MSD2756DE WHEN IT DEFROSTS WATER RUNS OUT THE FREZZER DOOR , I NEED TO CLEAN OUT ICE BUILD UP ON THE BOTTOM OF THE FREZZER EVERTY COUPLE DAYS OR IT BUILDS UP AND RUNS OUT. THE ICE MAKER LINE IS NOT...
It sounds like you have a frozen drain. google your specific model on how to take the freezer panel off and take a turkey baster full on hot water and run it down the drain line unitl it clears. Once its clear if you have a calrod heater (it will look like an electric bake element on an oven) take a piece of heavy copper wire (ground wire for a recepticle) and run it down the drain line about an inch and a half. This will conduct heat from the element down the drain line during a defrost cycle and help prevent the problem for happenening again.
let me know if this helps
Jan 24, 2010 | Maytag Refrigerators
Water leaking from left side of frezzer out the
There is a restriction in the condensate drain. You should be able to press a piece of tubing against the drain opening (inside fridge) and BLOW (NOT ****) through the other end. this should clear the obstruction. The obstruction would be slimy goop, sooo again -
NO ****!
Sep 15, 2009 | Jenn-Air Refrigerators
Water under the bottom of the frezzer
I would thaw all ice out use hot water in the drain hole. also use a heat probe in the drain hole. Is the drain tube straight or does it have a trap in it.
Mar 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore water on floor
Hi!!! You could have a plugged drain line. Open your freezer door and remove the bottom tray and look to see if you have ice on the bottom if you do then its a frozen drain line get a hair dryer and and apply heat to the bac evaporator fins and all the ice..sometimes also some sxs refrigerator model leak a small amount of water right after you use it..Good luckk..
Jan 03, 2009 | Kenmore 57029 Side by Side Refrigerator
Water keeps filling bottom of lower freezer in my refrigerator
sorry, about the timing, you have aclogged drain tube, your "self-defrosting" refrig isnt able to allow the derforst water to escape( tube if frozen) so it baks up into the frezzer area and eventually will drip into the frig. you will need to remove the back cover of freezer sect, and with a hair dryer remove all the ice from the drain trough area and clear the frozen drain tube area
Sep 23, 2008 | Refrigerators
Ice in bottom of frost free freezer
the heaters to defrost the coil may not be working
Jun 24, 2008 | Maytag MSD2454G Side by Side Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
46 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
