Question about Breville BES830XL - Die-Cast Programmable Espresso Machine
How do I replace the Magnetic Valve Assembly part in a Brevelle BES830xl Espresso Die Cast machine? The part looks hard to get to and the machine looks hard to disassemble.
  • 1,238 Answers
Yeah your right so I suggest you to call a service or send it to the nearest coffee machine repair shop.
Posted on Nov 08, 2012
Breville870xL loud noise when press brew buttons
The noise is caused by a (so-called 'magnetic' or sometimes 'three-way') solenoid valve's piston/plunger not seating properly or jamming when the solenoid is energized. This can be caused by too much gap between the plunger and the cylinder it's in, by roughness in the finish of the parts, or wear and tear - and indicates a faulty solenoid valve.
A bad solenoid isn't something that's repairable. It needs to replaced. There are two solenoid valve assemblies in that model, make you you get the correct one.
Feb 02, 2014 | Breville BES830XL
Replace pump breville 800esxl
How to replace the thermostat in the breville 800esxl machine
Nov 07, 2013 | Breville Die Cast 800ESXL Espresso Machine
Problem with frothing unit. I bought my Die-Cast
It probably has a line clogged. It could be from backed up milk, but also could be the water you're using. Those things are finicky about have filtered water, especially because when the water heats up it can deposit calcium etc. onto the inner water lines. Only use store bought filtered water.
Oct 28, 2013 | Breville BES830XL Die-Cast Programmable...
Magnetic Valve Assembly Part Number: BES820XL/198 leaks
Step 1: Unscrew back cover (4 torx screws and 2 phillips screws) and remove.
Step 2: Slide top warmer forward (may have to force with palm of your hand) disconnect ground wire.
Step 3: Remove valve assembly. While standing at rear of machine it is located in the rear upper left corner (on a 830xl), remove 2 phillips screws and disconnect wires taking note where they are connected. Remove split castanets from conecting tubes (push on one side then slide them off) making sure to also remove grommets.
Step 4: Instal new safty valve assembly reconect all disconected tubes with excisting grommets and reconnect all wires.
Step 5: Remount assembly with screws, reconnect wire to warmer top, slid backward into place and replace back cover with screws, connect to power, fill water tank and turn on.
Oct 16, 2012 | Breville Die Cast 800ESXL Espresso Machine
Die Cast 800ESXL Espresso Machine: Breville 800 EXL espresso machine pump not working...
I have the same problem. I used my machine for one day to test it when I had it brought into Vietnam then packed it while our house was being built.
Now it won't pump water or produce steam.
To add insult to injury Breville advice "They don't give service manuals to the public"
May 17, 2010 | Breville Die Cast 800ESXL Espresso Machine
Although machine is turned off water pumps through to the over flow tray(power button is not pushed on )
Sounds like a check valve on the pump or the power switch is not operating properly, if off and pump is still working.
Mar 07, 2010 | Breville Die Cast 800ESXL Espresso Machine
Chrome on steam wand wearing off
Posted by compliance12@embarqmail.com
I have a Breville Die Cast 800ESXL and due to wrong cleaning process, I have to buy the steam wand. I tryed to find them in Breville.com but they does not have this part available for sale. Where can I buy this Steam Wand for my Breville Die Cast 800ESXL.
PLease let me know ASAP, at compliance12@embarqmail.com
Thanks
Oct 12, 2008 | Breville Die Cast 800ESXL Espresso Machine
Wont power on
try runnig white vinegar through the machine to clean scale. there are probably descale solutions that you could buy as well but for mt the mild acetic acid in the vinegar helped to free up my valve.
Apr 28, 2008 | Breville Die Cast 800ESXL Espresso Machine
Breville BES830XL - Die-Cast Programmable Espresso Machine Logo
192 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
