Question about Hanns.G Corporation JW-199DPB 19" LCD Monitor
HANNS-G MONITOR BLACK SCREEN JUST FLICKERS
HI THERE I HAVE A 19'' LCD MONITOR HANNS-G POWERS UP
GREEN LIGHT FLASHES BUT BLACK SCREEN ALSO FLICKERS VERY
FAINTLY . IS IT THE INVERTER.
  • afrazee May 19, 2009
    I have the exact same issue. When the monitor is powered on even without being connected to the computer, it flickers as described above. After it warms up, it will operate normally.
I have the same problem. I leave the computer on for awhile to warm up the screen. I don't know why, that seems to help. I turn off the screen on the bottom right and do that a couple of times. Behind the screen I unplug and plug and unplug and plug the screen in again. After it gets going, it works all day. But at night I like to turn off the computer to rest. So I have to do this every morning.
Posted on Mar 26, 2009
    Genius:
  • 1,913 Answers
When u power the computer press F8 key then enter in enable vga mode.
then if u able to enter then chagne screen resolution to 1024*768
Posted on Jan 05, 2009
Screen keeps displaying "adjusting...."
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | Hannspree HANNS.G HU196D - LCD display -...
Monitor suddenly went black.If on/off button pushed screensaver briefly flashes on but then back to black screen.Green power light is on but nothing on screen when using computer
Try to replace all bad capacitor on power inverter board and turn it on. Hope it will work perfectly.
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jun 28, 2011 | Hanns.G Corporation HW191D 19" LCD Monitor
What does it mean by dead cells?
I assume this is related to your LCD monitor.
I think you mean dead pixels. The LCD monitor has tiny pixel elements, one for each red, blue, green color and each one of these colored pixels are turnes on by a transistor. When a transistor fails then the colored pixel it controls does not light up. This is a dead pixel and it shows up as a tiny black dot.
If the screen displays a blue screen, a dead blue pixel will appear as a tiny black dot in the blue screen.
You normally would not notice a few dead pixels unless they are grouped together.
Sep 20, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
Flashing green led on my hanns-g HX191D
Try it on another PC fIrst.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | Hannspree HANNS.G HX191D 19" LCD Monitor
Hanns-g 19" HX191d monitor blank screen. Power led is intermittent flashing green. Does not show 'no signal' when powered up alone. Has this monitor died or is there a way to fix it?
This type of issues is caused by parts called capacitors that have failed and are keeping the power supply from starting up correctly. You can rebuild the power supply board by replacing the bad capacitors and this will bring the monitor back to full working order. Here is a link to information showing what parts need to be replaced with pictures and parts list.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_31&products_id=194
I hope this helps you.
BuddyMc
Oct 14, 2009 | Hannspree HANNS.G HX191D 19" LCD Monitor
Hanns.g hx191d only green led flickering but no display graphics
Hello Joe,
Your monitor has a power supply that is going out. if you can solder you should be able to do the repair yourself, it involves replacing a few parts but its not that hard to do. Go to our web site at: www.ccl-la.com/badcaps.htm and look at the pictures and repair guides. Open your monitor and replace any capacitors that look like the ones in the pictures and you should be back going. We have a repair guide for the HW173 monitor that should be very close to your model.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Sep 12, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
Model HU171D Hanns.G... Monitor is on but blank screen appears...
I think the data wire may be disjoined in the Center. try to replace the data cable and reply me.
Aug 19, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
I have a ViewSonic VE910b 19" That the display stays black
What your both experiencing is a slow degradation of the inside light bulbs. Just like what happens to regular fluorescent bulbs, they slowly flicker out.
Best to buy a new monitor.
Take apart your old one, you'll find burnt out bullbs on the upper and lower chassis deep inside.
Apr 22, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Envision EN7410e monitor
hi this is jannet and am expert to solve your issues kindly call us to this numaber +1(518)348-9393
Oct 06, 2017 | Computers & Internet
Hanns g 19 inch monitor
No direct experience of this specific monitor, but LCD monitors in general seem to be susceptible to power supply failure due to the relatively cheap capacitors they use and the high working temperatures.
Turn it off, leave it for an hour or two, then take off the cover and look for bulged or leaking cap's on the power supply board. If the tops are not flat, they're probably duff, and need replacing with equivalent spec ones. Probably 105'C high temp - I got 105'C 470uF 35V ones for my monitor from Ebay at about a fiver for a pack of ten.
Aug 27, 2008 | Hanns.G Corporation HX191DP LCD Monitor
Hanns.G Corporation JW-199DPB 19" LCD Monitor Logo
2,399 people viewed this question
Top Hanns.G Corporation Computers & Internet Experts
nm8r
Level 1 Expert
Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
