Question about Vizio L32 32 in. LCD HDTV
32inch started turning green and fuzzy when you turn it on.
Would go back to normal after a while, now stays green and fuzzy pretty much all the time. Tv is 1080 and is only about 1and1/2 years old. Please advise
SOURCE: VIZIO 42" Plasma HDTV
I have the same TV. It started doing the same. Now it will shut off completely(no yellow light). Unplug overnight doesn't seem to help but sometimes it comes back on after a day(plugged in).
Posted on Oct 16, 2007
SOURCE: VIZIO L32
my tv goes in and out on it's own geedevil
Posted on May 19, 2008
SOURCE: Vizio flat screen tv screen goes all green (no
if you have comcast you can use your remote to change the tV program from cabke to DVD then change it back to cable. your image should come back.
Posted on Apr 24, 2010
SOURCE: the tv is 2 years old. it would turn off after
Had the same issue with my Vizio Plasma VP322HDTV10A. At power up it would turn on and off a number of times before it would stay on. In thinking it might be the power cord, I pulled it out and replaced it with a spare I had and it would not power up what so ever. I opened up the case and traced the the internal power coord to it's source and this lead to the main power supply board. I found three capacitors on this board with buldges on them (which the tops of the capacitors should be flat). I found a web side (SHOPJIMMY.COM) which had the parts I needed to repair the TV myself. the following is how much it cost to replace the needed parts
LG EAY42539401 Power Supply
sj-EAY42539401
$ 67.16
Vizio VP322HDTV10A Cable Kit
$ 29.36
LOC: DA
Subtotal
$ 96.52
Also Included Photos of the board with the failed capacitors
Posted on Nov 28, 2010
rohntech
  • 422 Answers
SOURCE: I have a 2 year
i think you unconciously program the tv on its timer mode and it is still not yet remove. check it out on menu, find the time set it off. if you already done it then the system i.c. has the problem
Posted on Jan 28, 2011
Coleman evcon furnace
How old is your furnace? Does it have a circuit board that controls everything, or are there separate controls for each function?
Nov 19, 2013 | Heating & Cooling
My toshiba 32inch tv wont turn on
A lot here would depend on the model number as there are a lot of different ones with different issues.
Got a model number?
Mar 28, 2012 | Televison & Video
When TV is first turned on, color looks like a reverse negative in a photo, picture is mostly black, white, and purply pink. TV picture then shuts off, power light indicator stays green, sound stays on....
we had a SONY Rear projection and we had that problem turned out to be a bad fan and caused the main control board to fail thus the same problem contact the company and see what the warranty covers
Jan 02, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
Samsung LCD cm07 good then bad picture, powers off and on
well this could be a power supply issue try this web site they could have the part www.discount-merchant.com
Ness
Jan 05, 2010 | Samsung HLN5065W 50" Rear Projection...
My XBOX 360 is green and fuzzy, if you reset the game it will work for a little while fine but then goes back to the green fuzzy screen.
It's starting . The G.P.U is breaking away from
the main P.C. board . It will get worse with time.
You have three options
1 Send it to Microsoft ,wait 2-3 weeks and keep
your fingerd crossed.
2 do and x clamp mod on it this will get it
back to normal for 1-3 mounths.
3 Have a shop re-flow the G.P.U. back to
the board this is the most durable repair
cost will very 70.00-80.00 the 35.00 fix
is some else doing and xclamp mod that
you could have done yourself.
If you need more info just ask.
Rob
Nov 28, 2009 | Microsoft Xbox 360 Console
Picture "pulsates", becomes small and fuzzy
Ur convergence is dead.Need to buy the convergence kit use it parts.U know how to solder right?Tries these websites Ebay.com,Tv Repair World.com,or Shopjimmy.com.
Sep 20, 2009 | Philips Magnavox 9P6034C 60" Rear...
How to fix fuzzy pic & red,blue,green lines on your screen?
Typically this is due to a convergence chip failure. This repair can be done pretty easy with the proper instruction. Have a look at this video to help determine if you truly have a convergence problem.
Jan 26, 2009 | Toshiba 57H82 57" Rear Projection...
Tv gone black and white
try letting it run for a little while sometimes it just needs time to warm up after not being used for awhile. unfortuntly i am not completly sure but i will look up more information on this.
Jan 03, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Vizio L32 32 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
