Question about General Electric GSS25JET Side by Side Refrigerator
Wondering if my digital Multimeter can confirm thermistor is bad. what reading should it be giving?
    Top Expert:
  • GE Master
  • 9,472 Answers
It sure can! Take a look at this video.
Posted on Nov 09, 2012
How to test a thermistor
hi u will need a multimeter digital or analogue...I f u r using an analogue meter set it to the 20 k ohm setting a good thermistor should read about 10 k ohm in resistance ..this is only a quick test to test properly it will have to b heated up to its cut of temp .......good luck
Sep 18, 2015 | Dryers
How to replace the thermister
as there are several thermistors are u sure u are replacing the right one? if so u just cut the wires leaving enough length to connect the new ones and twist tie with but connectors. its easy job when checked with multimeter after setting thermistor in cold ice cup for about 5 minutes the olm reading should be around 16,300 olms give or take 5 percent if its not its bad , I say that bcuz just checking to see if it has continuity could give u a false reading as to if its working properly
Sep 28, 2014 | Samsung DV5471AEW Dryers
Fridge doesnt cool enough ,have slide all the way up doesn't seem cold enough
Open the outside vent to gain access to the back of the refrigerator. Located at the lower left is a black cover. It will have a screw in the center top. Remove the screw then using a flat tip screw driver release the lock tabs located on the lower left and right so that you can remove the cover. Once the cover is out of the way you will see on the left side of the circuit board two different harnesses plugged in. One will have four wires the other will have two wires. Unplug the two wire harness, this will disconnect the thermistor and also put the refrigerator in wide open mode. You will need to test the thermistor. This is done by removing the thermistor from the plastic clip on the inside of the refrigerator and submerging the tip into a glass of slush or ice water. Then go out side and with a multimeter, measure the ohms between the two terminal of the plug end, inserting the multimeter probe from the back side of the plug, you should read between 7k - 10k app ohms. There is a chart that you can lookup online that will give you the values of ohms/temp for the thermistor. If the range is not in spec then you need a new thermistor. If it is in spec and the temp does not drop with the thermistor unplugged then you have a cooling unit problem.
Jun 17, 2014 | Dometic RM2852 Refrigerator
Wed6400sw0 change thermistor
You have to remove the back panel no heating could be a bad thermal cut-off hi limit or bad heater if you know how to use a multimeter to read continuity the one that reads open will be the problem a thermal cut-off would indicates a restricted exhaust.
Apr 01, 2014 | Dryers
How test a thermistor
Hi jorge
Hi
To test your thermistor you will need:
Soldering iron
Multimeter or ohmmeter
Follow the directions below to test your thermistor
1...Set the multimeter to resistance mode lowest setting.
2...Hook up the terminals of the multimeter to leads on the thermistor.
It does not matter which lead goes to the terminals, polarity is not important in this test.
3...Heat the soldering iron then heat the thermistor by moving your heated soldering iron tip to it.
Note: Check the multimeter reading as you are applying this heat.
A properly functioning positive temperature coefficient thermistor will show a smooth and steady increase in the multimeter
resistance reading.
A properly functioning negative temperature coefficient thermistor will show a smooth and steady decrease in the multimeter
resistance reading.
4...Look for other signs that the thermistor is faulty.
A steady reading that does not change, a reading of zero or a reading of infinity are all indications that the thermistor needs to
be replaced.
If the change in the readings is not smooth or if there is not any change, then this could also indicate a faulty thermistor.
Please take time to rate me.
Bud
Oct 31, 2012 | Dryers
Control on whirlpool EEZ8OHD055V Blinks twice, no hot water
1) Call Whirlpool. 1-877-817-6750
Have them send 2 new thermistors (temperature sensors located above each element), and then install according to the instructions they give you.
2) Sounds like you have the American brand older energy-smart electric water heater with grey control box on top
Copy following link to exactly identify product and resources
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html#energy-old
3) Two flashes is 'high water temperature shut down.
Buy cheap multimeter from hardware store. Install battery. Set to read ohm, the upside down horseshoe symbol.
Use multimeter set to read ohms, and test thermistors
Copy following link for general service manual showing error #2 and thermistor resistance chart on page 10
http://waterheatertimer.org/pdf/Energy-Smart-troubleshooting-guide.pdf
Oct 07, 2012 | Water Heaters
Kenmore 417-94052500 What should the reading be for gas dryer thermistor. I am testing mine, and it shows 50.0 on my multimeter
Thats kind low actually at room temp it should be appx. 5800 ohms
at 100 degrees it should be 5400 ohms
at 155 degrees it should be 2100ohms
so i would say its bad
GENE
Aug 28, 2011 | Dryers
What does f-03 mean?
Hi
Error F03 in Hotpoint washer means that the thermistor is open. When thermistor turns bad it will not let the water to heat or in some cases will boil the water to extreme temperatures. You’ll need to replace the thermistor to resolve this issue. The thermistor is located in the motor control unit. Inspect the element if its open circuit, it should read 1500-1800 ohms on Rx1 on the multimeter, if not then element is bad. To check/replace the element remove the lower rear panel. Hope this helps...
Daniel
Sep 01, 2010 | Hotpoint Washing Machines
Hotpoint wt746 flashing f 03
Hi
Thanks for using FixYa. By error F03 in Hotpoint washer we mean that the thermistor is open. This will not let the water to heat or in rear cases will boil the water to extreme temperatures. You’ll need to replace the thermistor to resolve this issue. The thermistor is located in the motor control unit. Also check the element if its open circuit, you’ll get a reading of 1.5-1.8K ohms on the multimeter, if not then element is bad. The element is also located in the motor control unit. You can check them by removing lower rear panel.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 22, 2009 | Washing Machines
How do I test a thermal resister witha multimeter
put it on the highest oms rating and put the terminals one on each end and read what the resistance is if it is open meaning it makes no contact then it is bad if it swings all the way over to infinity it is also bad it is shorted, But am unsure if you meant a thermistor? that is totally different let me know if that is what you mean,
May 30, 2009 | 2005 Dodge Caravan
General Electric GSS25JET Side by Side Refrigerator Logo
19 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
