Question about Philips HTS3450 System
Stuck disc (similar problem)
My surround system also won't open it's door to allow the disc to be removed (or placed in in this case). I can hear the mechanism trying to work but the door is stuck. Any suggestions Doctor?
  • joshnorman Jan 09, 2009
    Same system, same problem, door starts to open but never does, used to open after several tries, now it won't open at all.
  • monterrapin Jan 29, 2009
    I got mine fixed... It was a simple case of a rubber band. The one that was from the factory was dry rotted beyond belief. I simply opened the player, bought a $1 bag of assorted rubber bands from Staples & found one closest to the size of the factory band & installed it. It opens & closes better than ever... Good luck!!
Easyq, i can't speak for all of them, but my hts3450 does not have a hole.
Posted on Jun 22, 2010
    Scholar:
  • 144 Answers
In the front of the tray there a small whole, try bending a paperclip straight with a small hook at the end and careully stivk it in that whole. Than gently try pulling it back thus opening the tray. Remove your disc and do not put any other disc in it but try to close the tray by using the button. If it closes, try to reopen it.
Check your disc for any dirt or perhaps some remains of stickers.
Be carefull with homemade discs, they might have a stickered label on it which can cause problems such as getting your tray stuck and not opening anymore ;-) .
Posted on Jan 29, 2009
I have an acer aspire x1200-b1601a with a cd/dvd drive that will not open without putting the tip of a knife along the edge and prying it open. the "magic" pinhole is behind the case's cover and cann
CD-ROM, DVD, or other disc tray not opening Locking device or software installed First, verify no locking software installed that prevents the tray from opening. If you are unsure, reboot the computer and as it is booting up, eject the tray. If the tray can eject as it is booting, but stops working after loading your operating system, something is being loaded that is preventing the drive tray from opening. Programs used to burn CDs are a common culprit.
Bad eject button If you are running Microsoft Windows, open My computer, right-click the disc drive icon and choose the option to eject. If this ejects your CD-ROM drive tray, the button on the disc drive is defective, and it is recommended that the drive be replaced.
No power to computer or disc drive If you have recently installed a new optical drive or you have moved the computer, the power cable to the CD-ROM may have become loose or disconnected. Reseat the power cable to make sure this is not the problem.
CD stuck within drive If you suspect that a CD may be stuck within the drive, the tray needs to be ejected manually. Look for the small manual eject hole that ( not the head phone jack) located on the front of the drive. Unwind a paper clip and place one end of the paper clip into the hole to eject the CD-ROM tray.
If CD-ROM tray opens part of the way, pull it gently to see if you can get it to open fully. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become damaged or dislodged. But usually, a stuck CD is blocking the way.
Caution: If you are able to open the CD-ROM drive using a paper clip, we do not recommend continuing to do so. This is meant to be used as a temporary solution; the drive should be replaced.
What to do if CD or DVD stuck in drive? Note: This document is for disc drives with a disc in the drive that prevents the tray from opening. See our CD-ROM, DVD, or other disc tray not opening document, if the tray is not opening at all or doesn't seem to be getting power.
If the CD or DVD is not set into the disc tray correctly, it could be sticking up above the surface of the tray, causing it to get stuck with then tray tries to open. In this case, it may be possible gently shake the computer and move the CD or DVD into the correct place in the tray, allowing the drive to open. However, use caution when doing this, as you do not want to shake the computer too much, or you could damage other components.
If this is a desktop computer, you can prevent damage to the computer by opening the computer and removing the disc drive in order to shake or rotate the drive. When the drive is out of the computer, you can manually release the tray by inserting a paperclip into the manual eject hole.
In the case of a laptop computer or a slot load disc drive, since the CD or DVD does not sit in a tray, it cannot be shaken in order to adjust the disc. If the disc is visible you may be able to move the disc a bit by hand, enough to allow the drive to eject the disc. Again, be careful in doing so, as you could damage the disc or drive in the process.
If you're still unable to get the disc out of the drive after following the above steps, it may be a damaged drive and should be replaced. If the disc in the drive is an important disc and you believe the drive is bad, the drive can be disassembled in order to remove the disc. In the case of a laptop or computer with a slot load disc drive, the computer needs to be serviced in order for the drive the be replaced and the disc to be removed.
reference: http://www.computerhope.com/issues/ch001487.htm
Jan 03, 2015 | Acer Computers & Internet
The dvd door doesn't open
plug out the player for 5min from wall power and then plug in.
else you wil have to open the player and push it out manually.
Sep 04, 2008 | GoVideo Televison & Video
How do you open the base unit to remove the cd changer magazine
The top cover is held on with 4 clips (similar to those on a car door card) so needs to be gently prised off, this will expose screws etc to enable the bottom cover to be removed.
Ive done this with my system but it does not really help solve the problem, I still can't get to the jammed disc!!
Jul 07, 2014 | Bose Lifestyle 30 System
My bang & olefson cd 50 will not play. hear "spinning" sound when disc inserted.
THE CD50 DOOR MECH IS BELT DRIVEN IF THE BELT IS WORN THE DOOR OPEN/CLOSE SWITCH WHICH IS TRIGGERED BY THE MAIN CAM UNDER THE MECH MAY NOT BE FULLY CLOSED OR THE SWITCH MAY NEED CLEANING,ITS A LEAF SWITCH.THE MOST COMMON REASON FOR THE DISC TO SPIN BUT NOT READING DISC IS DISC MOTOR NOT GETTING UP TO CORRECT SPEED.IT CAN BE REMOVED,DISMANTLED AND LUBRICATED BUT CARE MUST BE TAKEN TO MEASURE THE TURNTABLE HEIGHT,BEST MEASURED FROM THE BASE OF TURNTABLE TO CHASSIS WITH FEELER GAUGE,CAUTION THE MOTOR SHAFT HAS SEVERAL VERY FINE WASHERS INSTALLED DONT LOSE THEM.
May 21, 2014 | Bang and Olufsen Beocenter 9300 Shelf...
My laptop win8 has a CD jammed into it by inserting it not secure in the tray. The door would not open. I then inserted a paperclip into the pin hole which released the door. The CD was not there and I...
you can remove the disc drive they are made to be replaced once you slide it out is only a matter of 4 - 6 little screws ant the cover pops off remove the disc and reverse the procedure piece of cake. :)
Sep 30, 2013 | Computers & Internet
Door won't open.
Hi Walter, this is called the Chucking arm and is made to hold the disc in place when the Pickup assembly is lifted into place. Often times an analysis will show you that the arm is not being lifted due to a lack of grease (Lubrication in the door mechanism) or that the drive parts- motor and a belt are not transferring the energy well enough. I would start with a belt of the correct size and then it may be fixed.
Dec 12, 2012 | Audio Players & Recorders
I have an Aiwa Surround Sound Theatre system Model #cx-nmt720. Has a 3 disc player, am/fm, and 2 cassette decks (one on right allows recording/dubbing) Everything works great except cassette...
The unit may be damaged or may just need adjustment- only a tape deck technician will be able to answer the question after seeing the unit. To answer it remotely like this, is really an impossible task.
Nov 03, 2012 | Audio Players & Recorders
My 2005 Honda Odyssey driver's side manual sliding door won't open/unlock - I hear the lock mechanism moving when I activate the power lock/unlock, but the door cannot be opened no matter what i...
More than likely the connecting rod that goes from the door lock actuator to the locking mechanism itself came unattached. These rods are usually held in place by a small piece of plastic that the rods "pop" in and out. The only other thing i can imagine possible is that the door lock itself is actually seized up. In order to attempt to fix this, you would have to remove the door side panel to see the inner workings of the door, and this is quite difficult on most side sliding doors (i have a 2000 pontiac montana w/dual sliding doors). Hope this can help you solve your problem.
Oct 24, 2011 | 2005 Honda Odyssey
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
LG DRT389H will switch on OK but will not allow Disc draw to open, & will not react to ''menu list'' or any buttons on the remote OR on the front of the machine. When switched on, shows...
Hello!
There is really no better way than to remove the case cover and access the mechanical loading disc tray of your unit,
You will need to remove all screws to remove the case cover. Inspect the mechanical loading disc tray. There is usually a left disc not properly placed in the loading tray that causing the jam.
Check also if there is no broken teeth on the gear that drives the movement of the tray. You can lubricate it with oil or greese to help it move freely.
Sep 04, 2011 | Televison & Video
Philips HTS3450 System Logo
336 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
