Question about Music
I have a yamaha silent guitar nylon strings with b-band under sassle pick-up ,but the volume of the strings is uneven, i checked the route and it looks perfect to me ; the pick-up it self looks perfect to me and the saddle too is perfectly flat and right thickness; what caan I do to improve this uneveness?
ginko
  • 19396 Answers
SOURCE: Fender Jazz Bass E string saddle vibrates down
Hi Mike,
If the sound is like a string vibrating against something, ensure that is not strings (usually G) vibrating against the bridge.
Ensure that the two screw on the saddle are well in place.
Ensure also that the vibration is not coming from a string vibrating against the frets, in that case you can fix the problem by adjusting the action and rectifying the bow of the neck.
In either case, if the sadde and neck bow are cause of vibration, try tweaking the saddles a little, and lowering the position of the saddle a bit downward. Try also to rectify the neck. turning the apposite screw.
Posted on Mar 13, 2009
  • 161 Answers
SOURCE: guitar astat
To me this is a natural reaction to having the volume all the way up, when you touch the strings your stopping any vibration from taking place there by stopping the static, or the other problem could be that your pickups are set up much to close to your strings, try to lower them and see what happens, a bad cord could also be the culprite.
Posted on Mar 19, 2009
SOURCE: Acoustic Guitar - Poor Sound Quality/Tone
might just be the pickups and their age. or a faulty cable
Posted on Apr 02, 2009
  • 17 Answers
SOURCE: I need the part number
These are actually (unfortunately) unavailable for purchase, but if you take it to any local guitar tech, they'll be able to make you a new one from a saddle blank. It shouldn't cost more than $20.
Posted on Mar 05, 2011
  • 5603 Answers
SOURCE: Fishman Prefix Plus preamp on my acoustic guitar
You could try boosting the bass and reducing the highs on the EQ setting, however there MAY be a probllem with the pickup, not the preamp.
Posted on Apr 05, 2011
I have a Yamaha 12 string fg230 red label,575925 .what year was it made?
here is Yamaha 's Serial Number Wizard site. Yamaha Corporation of America
Also check out here..this is even better
Serial Number Chart For Acoustic and Classical Guitars
But in looking your number up I cant find a reasonable explanation. No letters...and there are 6 digit numerical numbers but they dont match yamaha's codes...I would call yamaha and talk to a tech at 1 (714) 522-9000 Good luck
Feb 26, 2015 | Yamaha Music
My RR3 Jackson Guitar has corrupt sound.
It may be the nylon strings are not compatible with your pickup. The pickups rely on varying magnetic fields from the strings to produce the sound- nylon is not magnetic unless doped with a ferrous material.
Either find doped strings, find a way to dope them or switch back to steel.
You can check the pickups themselves indirectly with a soldering gun or tape head demagnetizer held close to them- you will hear the line frequency quite well if the pickup is working.
Jan 28, 2012 | Jackson Rhoads RR3 Guitar Electric
D10sce will not work when plugged into the amp. the cord is nine ( works with my electric.) battery is new. when you turn up the volume on the controll, you can hear it in the amp, just no pick up sound.t
SUBSTITUTE Change the guitar for a friends to see if the amp is really OK. Try your guitar in a friends amp to see if the guitar is OK If the guitar is at fault its either the battery, the connection cord, the little pre amp in the guitar body (you can't fix that) or you have put nylon strings on the guitar which needs stell strings for the pickup to work. Good luck
Feb 13, 2011 | Washburn WD10SCE Cutaway Acoustic-Electric...
The d string on my yamaha ev 204 electric violin has no volume w/ the volume is turned up . Any suggestions?
Hello, what a great violin to own, I am jealous. Each string on your violin has a pickup sensor under it. So, what you have are 4 sensors (one for each string) and the signals are then fed into your violin's electronics and mixed there to provide a wonderful rich sound. The sensor under the D string has a problem. I would look there first and in the electronics package last. The best advice I can offer is this, I also am a musician and play violin and 12 string ovation guitar. I have worked on both my instruments, unless you are very skilled in your knowledge of electronics and the delicate work on the sensors on your violin, I would take it to a craftsman (person) that has the skills to change out the sensor. Sometimes it can be a bad solder connection in the electronics, especially with the vibrations that an instrument causes, again, this would be for someone extremely skilled in instrument repair.
Dec 24, 2010 | Yamaha Ev 204 Silent Electric Violin
I have an Ibanez Art 100 and I am having trouble tuning the G string. It seems to sound sour and either a little flat or sharp.
Trace the string from the body to the tuning peg, making sure that there isn't anything rubbing and that the string is routed properly. Compare it's routing to your other strings. When you get to the tuning peg, note how many tines the string goes around the peg. It should go around at least three times (more is better, to a point), and wrap above and below the tail of the string to friction lock it to the peg. If it isn't locked in, the string will loosen itself over a period of time, making it impossible to keep it tuned.
Hope this helps! Regards, --W/D--
Jul 12, 2009 | Yamaha Electric Guitar
What kind of strings are best for washburn X 10
the washburn X10 is an electric guitar.
first thing you you want to make sure of is that you ask for electric guitar strings
next consider what kind of music your are playing...
heavier music or really moody warm tones your going to want thicker strings
med to heavy guage
if you want clear crisp tones than go with lighter guage
light to med
lighter guages are also easier on the finger tips.
the sizes usually refer the the smallest string on the bottom or the first string.
9 is the light 10-11 is med 12 is heavy
you might also want to consider nylon coated strings
they last longer
have great tone
easy on the fnger tips
but they cost more
Feb 26, 2009 | Washburn X10 Electric Guitar
Electric guitar pick up doesnt work?
se3veral things have to be ruled out, start with the cord that your using to your amp, is it good? next is the volume on both the guitar and amp also good, the last thing that should be wrong is the pickup itself unless a wire is broken off of it, you can usally check this from somewhere on the back of the guitar, if all the wires are good, check the two volume controls and on the back of the amp check the wires going to the speaker.
Jan 25, 2009 | Fender Squier Std Strat Mn Car
Electric Guitar wont play through Amp
the buzzing is indicative of an open ground connection, check the cord by substitution or with an ohm meter, if the cord is good look at the connections to the jack inside the amp ( im guessing you built the amp from a kit). Is this a solid state amplifier? Tube amps have lethal votages and should not be experimented on without knowledge of electronic safety. Also if there is more than one input to the amp try plugging the guitar into another one and see if its still the same.
Dec 30, 2008 | Yamaha Electric Guitar
Old yamaha electric guitar
Santana's had quite a few guitars, take your pick:
1972 - Gibson Les Paul / Gibson SG Special with Humbuckers / Gibson L-6S
1975 - Gibson SG Special with P90 pickup (Woodstock Festival)
1976 - Yamaha SG 175B / Gibson SG Special with 3 Open Coils
1982 - Paul Reed Smith (PRS) Custom
1988 - PRS Santana II with PRS Santana III nickel-plated pickups and .009-.042 D'Addario strings
Nov 10, 2008 | Yamaha Electric Guitar
Music Logo
95 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
