Question about Philips Magnavox 51MP392H Rear Projection Television
White looks blue
Everything white on the screen looks blue, especially if there is a dark background. Not only is the white bluish, the white has a haze around it that is bluish in color. Sharpness is gone, appears that the blue is not focused.
  • robpharmd1 Jan 08, 2009
    Most likely is related to the deflection coils but TV was never hit hard and has not been moved. Hue is adequate- adjusted in every direction and the blue shadow (haze) around the white continues
    Thanks
    Sergeant:
  • 233 Answers
This problem is caused by contaminated coolant in the BLUE crt.
It has grown bacteria and the bacteria is bluring / fogging the picture. You need to remove the blue crt, drain out the old coolant (which I suspect will look like apple juice or apple sauce) Once this is done, clean out the crt lenses, and the surface of the crt under the lense. Once cleaned, reassemble, and refill with new, crystal clear crt coolant, re-converge, and it will be a night and day difference!
If you need a service manual for this set I have uploaded it in the resources / technicians corner section of techlore.com.
Posted on Jan 17, 2009
    Scholar:
  • 100 Answers
Usually there's a HUE setting for color problems. try to go and play with the HUE whih is usually beside the contrast, brightness....etc.
if that didnt work, then there's a problem with the deflection coils focusing, either from shipping or a hard hit. if its still under warranty send it back for repair.
let me know if that helped, good luck :)
Posted on Jan 05, 2009
Hard to read
Tablest have different screen cofig parameters. Look for it in your Setting menu item.
Apr 24, 2015 | Tablets & eReaders
You can see the red blue and green lines on my tv it is like it is out of sync
I'm not sure what you mean by the "lines". If you mean the image looks like "double" (or triple!) vision, then you need to adjust the red/green/blue convergence. This is especially noticeable with white images on dark background (like text of credits). If this is it, check you manual or explore your menu via the remote. Sometimes convergence can be a problem if the tv was moved or experienced large changes in temperature... or sometimes all by itself!
Jan 22, 2011 | RCA D61W20 61" Rear Projection Television
My sony grand wega gives a blue shade on the black background which is the problem
HI, Check the menu set up of the TV. There should be an alignment feature that aligns the blue, red, and green colour projectors. If the blue is out of alignment that is likely why you can see it on the dark backgrounds. The set up normally puts a white cross on the screen and you select each of these colours and then move the cross over the white on with the arrows on your remote. Once all are aligned correctly you shouldn't be able to distinguish between different colours and hopefully this should get rid of your blue shade.
Oct 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Background has a bluish tint instead of white
the lens , glass inside your scanner is dirty with dust you need to clean this up and calibrate once again cheers
Nov 26, 2008 | Canon CanoScan 9950F Flatbed Scanner
Bluish hazy texture on my screen
It sound like the light engine is going out or already out. I would take it to a certified Hitachi dealer have them check it out then I would call Hitachi to have them fix it for free.
Nov 14, 2008 | Hitachi 50VS69 50" Projection HDTV
White objects (especially text) on a black background produce a white halo effect around the white lettering. When playing a PS3 game I noticed that the blue color appeared black, as though I had no blue...
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Aug 27, 2008 | Philips 9P6040C 60" Rear Projection...
Mitsubishi rear projection tv white screen goes dark and....
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0157" use the audio button to select "video chroma" adjustments, use the video button to select item "68 - AG1", use the adjust button to change the setting to 0, then press the enter button to store the change
Mar 04, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
161 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
