Question about Sony STR-K750P
No Dolby Digital light on my sony STR K750P RECEIVER
I cant get the Dolby Digital light to come on on my Sony str k750p Receiver it only Plays in 3.2/1 mode , I have a dvd player with the coax monster cable hooked from the sony dvd players Digital COAX Orange plug to the Orange COAX IN PUT PLUG on my Sony STR K750P Receiver it sounds good , but the Dolby Digital light wont come on . when I check the Display on the receiver it say,s it is playing in 3 . 2 _1 my E mail is harrywar@yahoo.com . I have the remote , but no maniual I got the receiver in good will . can you help harry
I have a Sony STR-K750 receiver running with a Samsung 50 inch series 6 tv.There is a digital lead running from the Austar receiver to the Sony receiver for sound.I have a Hdmi lead running from the Austar...
Run both audio and video to the tv, then use the tv optical audio out to go back to the receiver. The problem is, when you split the signal, the tv takes longer to decode the hdmi signal =, thus delaying it from the original audio signal.
Aug 06, 2013 | Sony STR-K750P A/V Receiver
Why does my Sony STR-K750P AV receiver automatically switch to Video 2?
Some models of systems will switch to a new source automatically if the source sees a new signal coming on. Try disconnecting the device on your Video 2 to see if this is the case.
I have seen the IC or component(s) in the switching circuits become defective and cause unpredictable or faulty operation. This can also be a fault condition you are seeing.
Apr 02, 2017 | Sony Str-k750p Av Reveiver
Sony digital audio video control center STR-K750P (protection- what is that?) no sound
What is the device code for the Sony STR K750P? I'm tying to set up a universal remote control and need the 4 digit code.
Sep 26, 2010 | Sony Audio Players & Recorders
How can i get the dts sound field to work. Shouldn't it automatically switch to that sound field. I have a samsung bluray dvd that hooked up to it.  The dolby pro logic and pro logic 2 indicator...
If you are playing media that has both dolby digital audio and dts audio, your player and your receiver will decode the first audio codec listed first by default unless you select it otherwise yourself. If your remote or receiver has an A.F.D. (auto format decode) button, press it until your display shows that the sound source is dolby digital or DTS, whichever sound mode it was you wanted when you started your DVD.
Dec 12, 2009 | Sony STR-DE597 Receiver
Sony str-de675 cuts out in dts mode
Your optcal line may have a break in it ! try another opt cable or try useing the digital cable out!
Dec 13, 2008 | Sony STR-DE675 Receiver
Sony STR-DE545 receiver
You should have access to receiver's format from remote or front panel. If the unit was moved around a lot and for a long period, the micro-processor may have locked due to ambient static electricity. Try unplugging unit for seversl hours, then re-try
Aug 19, 2007 | Sony STR-DE545 Receiver
Sony STR-K750P Logo
23 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
